Transmission & Drivetrain Gearboxes, Differentials, Clutches
ls tranny help!
Old Dec 7, 2011 | 03:17 PM
Lao17's Avatar
Default ls tranny help!
So I recently bought a 98 integra and the tranny was out. So I end up buying a new tranny and put it in. Drove the car for about a week. I started to hear this clicking noise as the car rolls.. you could hear it coming from the passenger side. after driving it for a few weeks. One night I drove down the block put it into 2nd and it stopped going. Its starts up and everything but when trying to put into any gear it just like its in neutral and doesn't go into any gear.. any help would be great.
Old Dec 7, 2011 | 04:31 PM
94EG8's Avatar
Seagull Management
Default Re: ls tranny help!
Check to make sure the axles are seated properly and that neither axle is broken at the cv joints. If that checks out suspect a blown diff.
Old Dec 7, 2011 | 07:37 PM
Lao17's Avatar
When I try to put it in gear it won't go into any gear at all.. it sways back and forth like its in neutral.
Old Dec 15, 2011 | 09:34 AM
MR.johnson's Avatar
make sure bitch pin is installed, then pull trans and inspect..
Old Dec 15, 2011 | 12:35 PM
RWfab's Avatar
Sounds like a shift linkage or and axle has popped out.
weshall0308
Feb 10, 2014 06:29 PM
i hate rice
21
Jun 18, 2006 11:21 AM
Ignitecivic
May 3, 2005 09:02 AM
Nextelbuddy
May 18, 2004 06:56 PM
