Transmission & Drivetrain Gearboxes, Differentials, Clutches
odd differential request
Old Jan 5, 2012 | 08:47 PM
Spawne32's Avatar
Default odd differential request
Im trying to determine from this picture that acura provides, what type of LSD I can use in my b18b1 from my 95 teg....
The oem differential part number is 41010-PL4-315 ...
im wondering what exactly sets them apart between the B16...GSR trans and LS trans.....
Old Jan 6, 2012 | 12:00 PM
David @ Synchrotech's Avatar
Default Re: odd differential request
^^^ This picture is of an automatic transmission. There is not an LSD option for the auto Integra. If you have a manual transmission you can use an aftermarket B16 LSD. The Manual B16 and B18B uses a LSD with ring gear hole diameter of 109.8mm and the GSR/ITR B18C uses the 116.8mm hole diameter ring gear.
LocoJoe
Dec 26, 2011 09:54 AM
mhewitt
Aug 29, 2010 12:49 PM
twentyhurtz
Aug 9, 2009 10:21 AM
Ti3d in
Mar 16, 2009 02:46 PM
crexer
May 14, 2004 04:23 AM
