Transmission & Drivetrain Gearboxes, Differentials, Clutches
Quick question! b18 LSD.
Old Jan 16, 2012 | 08:09 AM
lil_foy's Avatar
Default Quick question! b18 LSD.
Hey guys,
Just a quick question, i've done heaps of reading and i'm putting a b18 os giken diff+ 4.9 into my b16a2 box, i've got the first counter gear, ring gear, counter shaft, collar, needle bearing. So everything for the swap, what i'm wondering though is what diff bearings do I use? I haven't been able to find a solid answer, but thats probably from just reading too much.
Thanks guys.
Old Jan 16, 2012 | 09:05 AM
Gearspeed-Performance's Avatar
Default Re: Quick question! b18 LSD.
Since all B-Series Hydro cases are the same you will use the bearings that go with the Differential. Assuming you are using a GSR/Type R B18 diff...then use Type R/GSR offset ball bearings 91005-P80-E31
Old Jan 16, 2012 | 12:42 PM
lil_foy's Avatar
Awesome! thankyou for the quick and easy reply
88 EF Hatch
Apr 25, 2011 07:56 PM
92boostedeg
Jun 13, 2007 05:34 AM
m3bluegsr
May 21, 2004 02:08 PM
Mikes01GSR
Feb 20, 2004 08:44 AM
slofu
Apr 24, 2003 03:54 PM
