Transmission & Drivetrain Gearboxes, Differentials, Clutches
Manual conversion
Old Dec 18, 2011 | 12:38 PM
Hondakid95's Avatar
Icon2 Manual conversion
Hey everyone i have a 98 ek hatch automatic. I recently just bought a ex manual tranny with the shift linkage. I have no clue what else i need to do fully do this. i think i will need a new computer unless i can find someone to chip it, as well as a clutch pedal, and clutch line. But if any of you would like to walk me though on what i will need that would be cool!. Ps ive been wanting to do this forever so dont tell me to buy a manual ek instead.
Thanks!!!
Old Dec 18, 2011 | 02:22 PM
MR.johnson's Avatar
Default Re: Manual conversion
Search. This has been covered 1000's of times
Old Dec 18, 2011 | 02:24 PM
gsrauto98's Avatar
+1
But i'll be nice...
https://honda-tech.com/forums/showth...ht=auto+manual
took me all of 5 seconds btw
Old Dec 18, 2011 | 02:35 PM
10psiLsEf2's Avatar
clutch
flywheel
axles
ecu
clutch assembly
clutch master cylinder
motor mount for tranny
Old Dec 20, 2011 | 08:36 PM
95eh9civic's Avatar
U need a clutch/flywheel/clutch and brake pedal/clutch resivor/clutch lines/auto to manual tranny mount(very important to get this mount if not ull have alot of future problems cause ur transmissions will set at an upward angle) I only know this cause I done it on one of my cars...ull need axes not a 100% sure if auto axes will work been told they will but not sure...u can use ur stock auto harness just gotta wire a few things up search for wiring diagrams on here...u need a manual ecu...an a manual gauge cluster...I think that should b all...hope this helps u out I'm bout to do this to my eh9 so when I do ill post pics an a full how to...oh an the shift linkages
Old Dec 21, 2011 | 04:01 AM
94EG8's Avatar
Seagull Management
Only applies to '92 - '95 Civics and '94 - 01 Integras. '96 - '00 Civics use a different mount setup, Simply use the metal upper transmission bracket from any '96 - '00 5 speed civic.
Old Dec 22, 2011 | 04:27 AM
BobbyRodriguez's Avatar
Don't the trans mount have 2 be moved in an auto?
Old Dec 22, 2011 | 11:10 AM
SOSOJDMEF2's Avatar
clutch assembly
clutch
flywheel
axles
ecu
oh and a 5 speed tranny mount
Old Dec 22, 2011 | 02:24 PM
94EG8's Avatar
Seagull Management
Not in a '96 - '00 Civic. If it's a '92 - '95 or a '94 - '01 Integra and you want to forgo the auto to manual swap mount and cut off the automatic pocket mount welded to the frame and weld on the manual version then yet it needs to be moved about half an inch (i can't remember it it goes ahead or back, it's been a few years since I did one)
Oh and automatic axles are the same, B-series too, but the b-series intermediate shafts differ between automatic and manual.
Old Dec 23, 2011 | 07:38 PM
Hondakid95's Avatar
ThankS everyone for the help!
Old Dec 28, 2011 | 12:14 AM
bserieskid95eg's Avatar
Jus did a 94 auto to manual swap nd this thread help me a lot i haven't drop motor in yet as I'm waiting on my auto to manual tranny mount... jus want to say thanks for everyone help
Old Dec 28, 2011 | 11:39 AM
Hondakid95's Avatar
just put the clutch pedal in last night! now i need a clutch line,,, any ideas where i could get one from?
Old Dec 28, 2011 | 11:41 AM
Hondakid95's Avatar
Thanks! im just going to get a set of axles just incase. and yeah man throw some pics up!
Old Dec 28, 2011 | 11:42 AM
Hondakid95's Avatar
oh okay thanks for the help! saved me some money.!!
Old Dec 28, 2011 | 12:01 PM
94EG8's Avatar
Seagull Management
It has to come from a '96 - '00 Civic. Junkyard is your best bet.
mugenmarauder
Jul 25, 2014 11:38 AM
HYBRIDCIVIC007
Jun 3, 2011 08:23 PM
Turbo_DelSol
May 30, 2009 04:32 PM
Midori Green
13
Dec 6, 2006 04:56 PM
GG-SquadDB
Sep 17, 2005 02:22 PM
