Clutch problems!! Help
Hey guys so two days ago i was driving my car and felt that my clutch was acting all weird and stuff. Then today i go to drive it and it doesnt want to go into gear!!
So thats when i realize that my clutch pedal has about 2-3 inches of freeplay before i actually push the clutch in! also, to get my car into gear i have to pump my pedal about 5 times and then it will go into gear. And sometimes when i push the pedal in all the way, its up against the floor....and the clutch still hasnt been fully pushed in
If anyone knows what i can do to figure out what the problem is or help that would be great!! Thanks. And BTW when i first bought my car in may, the clutch pedal used to stick a little bit. then after a while it stopped....i didnt mess with it. And its a stock d16y8 with a s40 transmission. Thanks again for any help you guys!
hey so now i cant drive my car. The clutch wont engage, and there is no pressure at the clutch petal. I stopped at a stop light and then i couldnt get the car into gear. Is it just the slave cylinder, or should i buy both the master and slave?? Thanks guys!
Hey thanks guys, well i did. i checked it last night and it had little fluid there. So i ordered a new master cylinder. But the squeaking noise that i said earlier it seemed to come from the slave cylinder, since it was coming from the front of the car while i was pumping my clutch. So should i just get one of those also?
madeinchina
Transmission & Drivetrain
May 16, 2011 12:38 PM
