Transmission & Drivetrain Gearboxes, Differentials, Clutches
car wont shift into gears stick
Old Nov 26, 2011 | 09:13 PM
95civicdx5's Avatar
Default car wont shift into gears stick
hi i was wondering if anyone knows the answer to my question. I have a 95 Civic DX 5 speed stick. When the cars off it will get in all the gears fine but when it its started it will not go in any gear also when put on reverse it grinds. i pump the clutch bout 10 time when started in neutal then all gears work when started. if i dont start the car and put int into gear then start it the car will move so i know its not the clutch plus it pulls in rpm and mph. pls any answers to help . thx in advance.
Old Nov 28, 2011 | 01:19 PM
FloppyDonut's Avatar
Default Re: car wont shift into gears stick
check master and slave cylinder for leaks? are you having to fill up clutch fluid continuously?
redacura
Mar 3, 2013 04:30 AM
95civicdx5
Nov 26, 2011 09:50 PM
jlowellintegra
Jun 18, 2011 11:43 PM
13BT
14
May 29, 2010 09:02 PM
SteelCityKid
Jun 14, 2002 10:12 AM
