Transmission & Drivetrain Gearboxes, Differentials, Clutches
Shifting without using the clutch
Old Feb 3, 2012 | 07:30 PM
whited's Avatar
CRX God
Default Shifting without using the clutch
So I am going to replace my drive train, so I figured I would try to learn to shift without the clutch. I have a 88 CRX Si with a DX tranny, a stock heavy flywheel, and a B&M short throw. Didn't take too long to figure out, but I am still missing the shift about 20% of the time. I have seen videos of people doing it at low RPM, but I have been doing it at high RPMs.
The DX has very wide gearing, so 1->2 and 2->3 is taking longer than using the clutch still, but 3->4 and 4->5 is almost instant.
This is what I learned:
1. Do not look at the tac, drive as you would normally. You have to feel, and hear when you need to engage the gear.
2. Releasing the gear is easier if you spike the accelerator, or if your neither accelerating or decelerating.
3. Engaging the gear is easier if your RPM is falling. The same is true with down shifting. Engage with a quick smooth movement.
4. Do not hold the shifter against the sncryo, you are holding the sncryo still at that point.
5. If you don't get it in gear, do not try a second time. You will just grind it. This is true if you get pass the syncro and not in gear, or if you don't get passed the syncro. Put it in neutral, and use your clutch.
Old Feb 4, 2012 | 03:13 PM
MR.johnson's Avatar
Default Re: Shifting without using the clutch
Old Feb 4, 2012 | 05:10 PM
Mista Bone's Avatar
D Tranny Guru
This both saddens the tranny builders due to the abuse, but also makes us happy with the higher than expected repair bill when they get tore up.
98R-1144
Jun 27, 2008 07:40 AM
suken19
Mar 21, 2006 10:00 AM
Bjorn20
26
Nov 13, 2005 01:00 PM
.M.
Jul 13, 2004 04:26 PM
Red2001GSR
Feb 18, 2002 08:14 PM
