Clutch/ Pressure plate
Okay so i have the transaxle off, but; i tried a 11mm, 10mm, and even US measurments but none fit the bolt holding the pressure plate on. WTF! they are not stripped and they arent regular bolts this is my first DIY clutch job but really. is there a special tool or something.
D Tranny Guru
Re: Clutch/ Pressure plate
and they are only "spark plug" tight at 19 ft/lbs.
If removing the flywheel to be resurfaced you'll need a 17mm 12 point socket as well, the only two 12 point sockets I use regularly.
Yuta
11-09-2015 09:41 AM
hayabusa160
06-18-2008 01:28 PM
