Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 civic code p1773 problem?
Old Apr 22, 2013 | 02:34 PM
dom_p88's Avatar
Default 2002 civic code p1773 problem?
So i replaced the tranny due to it not goin in reverse or drive. now the D light is blinking code 1773 A/T Clutch Pressure Control Solenoid valve B Circuit. i replaced it and cleared codes and it still blinks the same code. i cleared it several times and still nothing car moves slowly with me pushing some gas.
i traced the wires from ecu to solenoid and nothing is broken.
Any suggestions
Old Apr 22, 2013 | 04:17 PM
lazlong's Avatar
Default Re: 2002 civic code p1773 problem?
Well, the good news is that this code is electrical and cannot be caused by anything mechanical.
The first part of this a review since you already replaced the solenoid:
1. Disconnect the solenoid connector
2. measure resistance across the solenoid.
Is there 3-10 ohms resistance?
YES- step 3
NO- Replace the solenoid
3. Disconnect ECM/PCM connectors B and C. (Looking at the ECM/PCM in the dash, starting at the bottom is connector A, above that is connector B, then C, etc.)
4. Check continuity (ohms) from B16 (black/red) to body ground and from C8 (brown/white) to body ground.
Is there continuity?
YES- Whichever wire shows continuity needs repaired between that terminal and the solenoid (or just run a new wire).
NO- step 5
5. Re-connect the solenoid connector
6. Measure resistance (ohms) from those same terminals to body ground.
YES- step 7
NO- Repair the open between that terminal and the solenoid on whichever terminal shows no resistance (or run a new wire)
7. Disconnect ECM/PCM connector A (bottom connector)
8. Measure continuity (ohms) from A23 (brown/yellow) to body ground and A24 (brown/yellow) to body ground
YES- Check for loose terminals and repair as necessary. If the terminals are OK then you need to update or replace the ECM/PCM.
No- Repair the wire between A23 and ground or A24 and ground or repair the poor ground (G101).
G101 is the ground from the engine block to the radiator support. I would look at that ground first.
Old Sep 25, 2024 | 03:11 PM
cm634428@gmail.'s Avatar
YES- step 3
NO- step 5
YES- step 7
Should I have the battery undone
asocallocal
Jun 6, 2010 11:30 AM
Rukusmasta2
Mar 4, 2006 09:21 AM
zccr-xsi
Nov 4, 2005 10:36 AM
XzzYzzX
Sep 29, 2004 01:01 AM
integracivic94
Aug 22, 2004 08:42 AM
