Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 civic ex p0135 code!! Light stays on!!
Old 04-21-2013, 03:29 PM
Novz's Avatar
Default 2005 civic ex p0135 code!! Light stays on!!
I got the check engine light on and reading code p0135 which a is the primary o2 sensor. I replaced the o2 with a OEM denso but the light stays on. Thought it was a bad part but tried for the second time and no luck. Could thus be bad wiring or short some where or do I need my ecu flashed because its not reading my o2 or where should I start?? I'm sure someone knows..
Old 04-21-2013, 04:40 PM
lazlong's Avatar
Default Re: 2005 civic ex p0135 code!! Light stays on!!
Start by re-setting the ECM/PCM: With the car OFF, remove the #6 fuse from the under-hood fuse/relay box for at least 10 seconds
Old 04-21-2013, 10:35 PM
Novz's Avatar
Is disconnecting the battery or resetting with the scanner the same?
Old 04-22-2013, 03:26 AM
lazlong's Avatar
I know you can re-set with the scanner but, don't know about disconnecting the battery.
HondaPH22
07-14-2006 12:06 PM
MiMiK
10
06-20-2006 01:49 PM
micr0m0nk
05-01-2006 02:07 PM
vuthe32
09-23-2004 06:10 PM
General Kills
05-24-2003 07:10 PM
Quick Reply: 2005 civic ex p0135 code!! Light stays on!!
