Engine knock?
Old Nov 1, 2020 | 04:34 PM
Jordan T's Avatar
Default Engine knock?
I’m fairly new to working on cars and I’m 99% sure that it’s engine knock but I need to know for sure. I had a video of the sound coming from my engine, if anyone could tell me what could possibly be wrong that would be great. Thank you.
File Type: mov
Old Nov 1, 2020 | 04:35 PM
Jordan T's Avatar
Default Re: Engine knock?
Also, took it for a drive around the block since I just got it running, it has little to no power, if that helps answer my question at all.
Old Nov 4, 2020 | 12:02 PM
Makinnoyz1's Avatar
That most def sounds like a spun main bearing to me (but I should note that im listening in a very loud plant through computer speakers at the moment). Does the engine have oil pressure?
Old Nov 4, 2020 | 12:58 PM
iwannarace's Avatar
Drop the oil pan if possible. If there is metal in there, it most likely a bearing issue. Stop driving it. If it is s bearing the more you drive it the more likely you are to have the bearing spin and potentially damage the block (Throw a rod).
Just went through this myself. Motor ended up seizing at idle RPMs thank goodness. Crank is trash, but will be rebuilding the block.
