I
Old Jan 17, 2021 | 12:48 PM
Shane Stroup's Avatar
Default I
I Have a 2001 honda accord v6 3.0l EX I I turned on the car this morning and the check engine light was on so I hooked up my ODB scanner and had six codes all misfire codes I then checked to see if I can find out if there was just a single cylinder misfiring by testing each one no change in the motor when disconnected
Old Jan 18, 2021 | 12:25 AM
Davey7847's Avatar
Default Re: I
Clear the codes . And see of they return.
A good scan tool should be able to tell you which cylinders misfired
Is it misfiring now?
misfires can be from plugs, coils or even maladjusted valves.
Tomneu10
May 14, 2020 10:42 AM
Krael
Aug 30, 2018 09:47 PM
BigT2424
Jul 19, 2016 02:45 PM
nknoll
Aug 25, 2013 06:56 AM
wayne wells
May 1, 2009 02:30 PM
