Vss based rev limiter? B16
Old Mar 14, 2021 | 09:37 AM
Bottlefedz28's Avatar
Loved
Default Vss based rev limiter? B16
Is there a ref limiter if the ecu, isn’t getting vss feedback? Changed. My trans fluid the other day and had to fill through the vss hole because the fill plug was stupid tight and I was I. A hurry. Vss dropped right back into place with no difficulties. Ever since then it’s been hitting what feels like a limiter around 6500-7000 rpms. Not sure exactly where because it was u expected and I wasn’t really paying attention to the tach. It doesn’t feel like a miss or like it’s breaking up. Feels like a hard limiter, as in it stops all acceleration and rpm bounces a bit
Old Mar 14, 2021 | 02:35 PM
Full_Tilt's Avatar
Default Re: Vss based rev limiter? B16
stock ECU?
With a chipped ECU, you can set up launch control, where you have a lower RPM below a certain speed. This can be an issue with VSS issues since the ECU will limit the revs when it thinks youre at zero speed.
Old Mar 14, 2021 | 05:52 PM
Loved
Originally Posted by Full_Tilt
stock ECU?
chipped p28 on chrome. I didn’t tune it nor have I seen the tune. What you’re saying though was definitely something that had crossed my mind. Wasn’t sure if there was anything there from the factory that would have a vss based limiter tho
Old Mar 15, 2021 | 04:12 AM
Full_Tilt's Avatar
Whoever did the tune/basemap probably set the launch control at 7k rpm
Old Mar 15, 2021 | 07:30 AM
Loved
is there a trick or something to installing the vss then? It dropped right back in the trans with no issues. Guess I should probably go over the sensors wiring
Old Mar 15, 2021 | 09:02 AM
Full_Tilt's Avatar
Its usually the electrical connector. Ive had luck jurry rigging them by sticking a piece of a paper clip in there to help it make contact, but the best thing would be to just replace the pins and connector shell.
Old Mar 15, 2021 | 09:58 AM
Loved
thanks for the help
Skidmark1845
Jul 31, 2020 03:38 AM
Nick998
Engine Management and Tuning
Dec 30, 2008 12:19 AM
Eee Pee
13
Aug 26, 2002 10:01 PM
