Kpro engine compatibility
Old Jan 12, 2021 | 06:24 PM
JimmyCreedog's Avatar
Default Kpro engine compatibility
I have Hondata Kpro4 installed in my 04 Civic. I'm curious about if its possible to do a LS V8 swap down the road after I blow this engine.
Mainly I want to ask if anyone knows if the kpro can control 8 injectors and 8 spark plugs? Would it require running waste/split spark and injection?
Old Jan 12, 2021 | 09:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Kpro engine compatibility
It cannot run 8 fuel injectors using the Injector Drivers in the stock ECU... there may be a way by using an additional fuel injector driver/controller that would normally be used for staged injectors or slaved injectors. Hondata makes such a device... now whether it would work for a V8 or not... I am not sure.
Old Jan 13, 2021 | 12:49 PM
spAdam's Avatar
Loved
Community Favorite
Wouldn't be worth the effort or money involved, even if it could be done. Just use a universal EMS of your choice.
Old Jan 13, 2021 | 05:56 PM
Guess that 5.3 build is gonna have to go in another chassis. What trans is good to use with K20 rwd swaps? Still not sure if I want to keep it manual and street registered or go powerglide for a RWD 4cyl turbo Civic drag car.
Old Jan 13, 2021 | 09:22 PM
spAdam's Avatar
Loved
Community Favorite
I mean, if you’re going to go to that level of fabrication then trying to stick with a stock ecu is somewhat pointless. Any reason you’re so committed to running kPro that it dictates your engine choice?
Old Jan 14, 2021 | 06:24 AM
Money, i guess. I already have the Kpro installed and street tuned. I've been building my car to be somewhat engine agnostic.
What 4 cylinder turbo engine would you go with for some good affordable power. 4G63T? 2.3L Ecoboost? SR20?
Old Jan 14, 2021 | 07:43 AM
spAdam's Avatar
Loved
Community Favorite
Well if you want an "engine agnostic" ecu, then anything that's not a modified stock ecu is a better option. The good news, people seem to buy/sell used K-Pro/S300/etc setups for just about what they paid for them brand new so you wouldn't lose much. Why isn't a K-series engine on your list?
070-racing
Feb 2, 2017 01:21 AM
f4it
Feb 11, 2008 12:32 PM
turbo89civicb18hatch
Mar 17, 2004 08:56 AM
h22civic95coupe
Jun 29, 2003 09:38 AM
g2turbo
May 10, 2003 01:36 PM
