B16A Dyno Tuning
Old Sep 29, 2020 | 12:29 PM
Wolfeman2001's Avatar
Default B16A Dyno Tuning
So I just got my rebuilt JDM b16a swapped into my 97 civic. The motor runs and the car drives. Iv read some forums that say to get the motor tuned after the 500 mile break in process. Is this true?? I do have a cold air intake and a 4 to 1 header with a 2.5in straight pipe. The head gasket also is different so the compress is a little lower than stock because the guy who build the motor made it to handle boost. I know that it’s recommended to get a tune after you put on new aftermarket parts so everything runs correctly. I called the tune shop and they said because I have a p30 obd1 ecu I should get hondata s300 chip for a tune is this correct?? Or am I ok to run the motor without a tune. Iv never had to dyno or tune anything and I don’t want to get screwed over or get the wrongs parts because the guy said it would be around $1000 for the chip and tune. Can someone please help me out with all this?
Old Sep 29, 2020 | 06:00 PM
BiggieBert's Avatar
Loved
Community Favorite
Default Re: B16A Dyno Tuning
If you are just running an intake/exhaust, you don't need a tune, you could maybe squeeze a pony or two out of it with a tune, but it is not necessary. Now, if you put aftermarket cams in there, yes get it tuned.
Old Sep 29, 2020 | 06:12 PM
The guy I called said I’d be running lean because of the cold air and the 4 to 1 header and exhaust is this true ?
Old Sep 30, 2020 | 10:53 AM
DaX's Avatar
DaX
Loved
Community Favorite
A tune would definitely make it run better. Is it necessary? Nah. Others will staunchly disagree, but 20 years ago we were slapping I/H/E on Civics and driving them on unmodified ECU's without a problem. If this car is just a daily/weekend warrior, I honestly wouldn't bother with a tune.
Old Sep 30, 2020 | 03:58 PM
BiggieBert's Avatar
Loved
Community Favorite
You could always add a wideband o2 to verify if you are running lean and go from there.
Old Oct 11, 2020 | 10:34 PM
civic ek sir's Avatar
Icon6 Re: B16A Dyno Tuning
the first step you need to see the spark plug condition it will give you an idea of how is your AF, getting wideband is the most accurate way to see that. if it shows that it's lean you can fix it by getting FPR and raise the fuel pressure.
I will not spend $$$ to get Hondata for sample step.
Old Oct 12, 2020 | 11:50 AM
eh2_Trav's Avatar
Your o2 sensor will add/subtract a percentage of fuel to get you back to stoich. Stock ECU have up to 45% change so I think youll be fine. This is the primary function of the 02 sensor. But you'll never know how much power you're making now vs after a tune. Get someone who tunes on crome to chip and tune your car. Should be about half of what they want for Hondata if you're on a budget.
twistedintegra707
Oct 15, 2006 10:40 AM
b16a27
Dec 4, 2005 10:43 AM
tianporn
20
Oct 7, 2005 12:20 AM
herbalist
10
Oct 4, 2005 04:44 PM
xstalkrx
May 25, 2003 06:07 PM
