405A b20 crower base map request
Old Feb 12, 2020 | 08:31 AM
Pablomg's Avatar
5 Year Member
Default 405A b20 crower base map request
Hey! Anyone has base map for b20 405A 11,2:1 ( or around ) and fuel pump?
Old Feb 13, 2020 | 11:14 AM
BoostHatchFreak's Avatar
Default Re: 405A b20 crower base map
You need more compression for those cams. They are very hard to make idle below 1200rpm and are very choppy like a big block chevy. Hope this is for non daily use only and you have some great springs and valves in your head
Old Feb 13, 2020 | 12:15 PM
Pablomg's Avatar
5 Year Member
Is good compression, the 405a are not more than a itr cam with 10 ° less duration. The LSA is much higher ( 113° and 104° itr ) and ABDC is lower too ( 44° and 45° itr ).
The only thing that could really affect is the intake lift that is equivalent to a stage 2 vtec (12.1mm). I can leave the idle at 1000 rpm and it keeps working problems smoothly. I was only interested in some reference map since I don't have the knock tool and I have the conservative map
Old Feb 20, 2020 | 10:15 AM
416Gang's Avatar
Default Re: 405A b20 crower base map request
You can get a chip basemap from here. http://www.phearable.net/ecu-chippin...p-basemap.html
You are better off getting the car tuned.
JDMswagSerf
Feb 7, 2016 02:50 PM
rexracer626
Jun 24, 2010 06:28 AM
ser13
Engine Management and Tuning
Oct 28, 2009 07:11 PM
Hybridize
Jun 5, 2009 07:47 PM
ser13
May 29, 2009 05:31 PM
