Vtec wiring help
Old Oct 8, 2020 | 09:53 AM
Jace Johnson's Avatar
Default Vtec wiring help
I have a 1999 Honda Civic Dx with a b16a swap. I’m having problems with wiring the prior owner did. What color is the vtec pressure switch wire and what color is the vtec solenoid valve wire? Thanks
This is connector A, is this red wire with a yellow stripe the solenoid valve wire?
Old Oct 9, 2020 | 10:05 AM
bumpstick's Avatar
Default Re: Vtec wiring help
That’s the purge solenoid wire.VTEC pressure switch is blue/black pin 10 in the C connector
VTEC solenoid is green/yellow pin 12 in the B connector
