Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
problem with starter
Old Feb 7, 2013 | 08:29 PM
backjack's Avatar
Default problem with starter
Hi there, I am an owner of a civic vtis (02) and i have a problem with regard to my starter. When I turn on the ignition switch there is no power going out to the starter unit and as a result the engine wont start.
What could have been the issue or the problem with my electrical....
Can someone help me out there...
Thanks............
Old Feb 8, 2013 | 09:08 PM
toyomatt84's Avatar
Sanji
Default Re: problem with starter
Did you test the battery?
Old Feb 9, 2013 | 01:57 PM
weepingnutka's Avatar
Does it tick or just nothing
Old Feb 18, 2013 | 07:35 PM
backjack's Avatar
I already check the battery and its in good condition.
When I directly connected the positive line to the starter, the engine got no problem starting.
When I turn on the ignition key, there is no clicking sound but a complete slince.
Thanks...
Old Feb 18, 2013 | 08:16 PM
It Wasn't Me's Avatar
Manual or automatic transmission?
Have you checked your starter relay? It's under the dash. Look here.
Old Feb 19, 2013 | 08:08 PM
backjack's Avatar
its automatic.........
Old Feb 20, 2013 | 06:57 AM
lame05's Avatar
Checky relays, then do v-drop test and ohms on all from the battery, p/n switch, pcm, fuse box, and finally the starter. I worked on one that something with fuse box failed and it wast giving power when relay closed
UgandaHonda
Dec 30, 2011 07:04 PM
mugen94
Aug 9, 2009 03:16 PM
AP1Shocker
Dec 8, 2006 01:27 PM
mingchi69
Jul 14, 2003 06:14 PM
junya16
Feb 26, 2003 08:31 AM
