Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Quick release problem!! Help!
Old Jan 14, 2013 | 01:10 PM
Eman.'s Avatar
Default Quick release problem!! Help!
So I'm switching my stock steering wheel with a nrg hub and quick release. I'm on the last step and there's the black plastic piece for the air bag. I can't seem to get it off is there acres or something or just all clips? Any help is appreciated!
Old Jan 14, 2013 | 05:37 PM
lazlong's Avatar
Default Re: Quick release problem!! Help!
Are you trying to get the airbag or the steering wheel off?
Which part number?
Old Jan 14, 2013 | 05:43 PM
toyomatt84's Avatar
Sanji
Are you referring to the Clock Spring perhaps?
Old Jan 15, 2013 | 09:34 PM
01_civic's Avatar
^that probably
Old Jan 16, 2013 | 09:06 AM
K24_Y61P's Avatar
This thing?
If so its the clock spring and there is a hidden tab underneath the topside. It a pain to get off.
Old Jan 17, 2013 | 06:27 AM
Eman.'s Avatar
Yea with the wires o have it pretty much disconnected but it's the top part that won't come off. Thanks guys do the help I'm going to try to take it off once I get home
Old Jan 17, 2013 | 09:06 AM
K24_Y61P's Avatar
The tab is in a horrible spot, it cant be seen. We used a very small flat-head and looked at an old one to locate where the tab should be.
Old Jan 17, 2013 | 09:26 AM
Eman.'s Avatar
Yea I can't find it -.- where is it? On the inside?
Old Jan 17, 2013 | 05:50 PM
01_civic's Avatar
i eventually broke mine taking it off...but then again... i didn't need it and it wasn't gonna function anyway.
Old Jan 17, 2013 | 09:01 PM
toyomatt84's Avatar
Sanji
Its on the backside, facing the cluster. Try inserting a small screwdriver in the backside, to separate the Clock Spring from the hub.
Old Jan 22, 2013 | 08:41 AM
Eman.'s Avatar
So I found the clip in the back but it's still not coming off, is it hard to take off once it's in clipped? And there still a thing of wires connected to it ill try to get a picture of what in talking about
Old Jan 22, 2013 | 08:56 AM
Eman.'s Avatar
http://www.flickr.com/photos/iso-dope/8406297674/http://www.flickr.com/photos/iso-dope/8406297674/ by http://www.flickr.com/people/iso-dope/, on Flickr
Old Jan 22, 2013 | 09:09 AM
K24_Y61P's Avatar
Ill see if I cant get over to my car tonight and get a picture. To get to the clip there is a slot directly under where the SRS wires go into the unit. Slide a longer narrow flat head in there and wiggle it around.
LaEzEnT
Oct 23, 2007 05:54 PM
Peruviann
Oct 6, 2007 08:55 PM
ek_will
Dec 29, 2005 07:45 PM
sushib01
Aug 22, 2004 10:26 PM
travis
Dec 27, 2001 12:56 PM
