Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Welded/locked diff
Old Jan 6, 2013 | 11:52 AM
tummy's_em2's Avatar
Default Welded/locked diff
Thoughts on welding/locking the differential in 02 lx?
Old Jan 6, 2013 | 01:02 PM
doood's Avatar
been there done that
Default Re: Welded/locked diff
only going in a straight line? sure.
have fun trying to take a turn.
Old Jan 6, 2013 | 01:11 PM
toyomatt84's Avatar
Sanji
That'll be a great way to destroy other parts of your car. The only safe way to provide better power output to the ground, will be an LSD.
Old Jan 6, 2013 | 01:26 PM
Last LSD I found was $1400 for em2
Old Jan 6, 2013 | 01:37 PM
toyomatt84's Avatar
Sanji
That's typical pricing for name brand LSD's. If you don't mind doing some work when you get it, you can always do the budget-minded LSD and rebuild it when you get it. It'll need a rebuild when you get it, simply because they're not put together very well from the manufacturer (there's already tons of information out there regarding rebuilding them to make them perform).
OBX LSD: http://www.racingpartdepot.com/servl...RENTIAL/Detail
Old Jan 6, 2013 | 02:05 PM
Now that's a much better price! Are you talking disassemble and reassemble to make it perfect? Or did I misunderstand that?
Old Jan 6, 2013 | 03:17 PM
toyomatt84's Avatar
Sanji
Yes. They typically come with a horrible finish inside, and would easily lead to problems. Taking the time to knock off burrs, re-arrange the conical washers for proper pre-load, and cleaning up any casting leftovers would definitely yield a longer life for your transmission. Also, if you can, try and measure the run-out. In recent times, there haven't been issues, but the older ones they made were problematic.
Old Jan 6, 2013 | 04:29 PM
That sounds like fun... Do they make a Different 5th gear I can toss in there to give better highway MPG while I've got it apart??
Old Jan 6, 2013 | 04:56 PM
toyomatt84's Avatar
Sanji
The 5th gear you have is already the longest you're going to get from a D17 manual transmission. If you change out your final drive to one from an HX transmission, you'll get better fuel economy... but your 1-4th gears will suffer on acceleration.
https://honda-tech.com/forums/honda-civic-2001-2005-78/d17-tranny-gear-ratio-2169563/
Old Jan 6, 2013 | 05:08 PM
https://honda-tech.com/forums/showthread.php?t=2169563
Maybe a trans shop will have something to fit? If its like s rwd. Trans it shouldn't be hard to do it, primary shaft and secondary with the gear?
Old Jan 6, 2013 | 05:17 PM
toyomatt84's Avatar
Sanji
Yeah, its a standard primary/secondary shaft layout. I do not know if the previous generation D-series transmission gears will work or not. I do not know the diameters of the p/s shafts to give any sort of solid information.
Old Jan 6, 2013 | 05:27 PM
I'm sure if I asked, someone here would have it. Or google
Civic HX 121
Transmission & Drivetrain
Jul 2, 2012 09:06 AM
NonovUrbizniz
Jan 20, 2009 01:01 PM
discman
Jul 8, 2006 03:10 PM
citrusdrop
Oct 23, 2003 10:59 AM
ToneyTigre
Oct 7, 2001 07:04 PM
