PDA
View Full Version : Road Racing / Autocross & Time Attack
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138
  1. Does anyone still make a dry sump system for a B series??
  2. EM1 Si classification
  3. steel wheels
  4. 5th gear Vtech seems weird and tops out at 143mph
  5. Who can ship a 3 piece front end to the UK?
  6. World Time Attack Challenge Sydney
  7. B20/vtec build for Endurance racing on the cheap?
  8. Axles and endurance racing, what to buy/look for?
  9. Transmission fluid for OSGiken diff
  10. B18C oil temp on track/circuit
  11. Distributors and endurance racing. Where to buy?
  12. New 2017 Honda Civic Si Sedan Turbo (FC1) hits the track on Hoosier slicks! [VIDEO]
  13. Mid Atlanic: Alive and well?
  14. Mjalaly's "Attack" on Oil Starvation in a custom project
  15. Power steering? AC? Lose them? '93 del Sol weekend track car
  16. EG Hatch or DC Integra
  17. KS/KaizenSpeed Rear Trailing Arms
  18. Oil/water temp options for HPDE
  19. HANS / Head restraint recommendations.
  20. Reliable motor/transmissions for track
  21. NASA HC H4 Build-- New LS Motor Maint. Opinions Needed
  22. Two cars and what to do. 91 hatch 99 integra
  23. Suggestions Needed: 16" Lightweight Wheel Set 4x100 For Circuit/Road Race purposes
  24. My 1991 Civic DX build/progress
  25. Swapping a 91 Civic DX to Si trim for Solo HS/STS
  26. Play in Steering Wheel at High Speeds Through Corners
  27. SMF Civic wheels
  28. Wilwood DPHA pad options?
  29. brake on a honda fit
  30. Racing Oil Recommendations: Part 345,420
  31. Stolen Racecar, Nova Scotia, Canada
  32. Before I mod, what scca class am I in?
  33. Half mile dirt track tips and tricks
  34. Open Lapping (May 22, 2017) - 5 videos (1993 Honda Civic del Sol Si - built NA d16z6)
  35. Far North Racing "Autocross to Win" now a book on Amazon!
  36. cheap way to setup the e brake for rallycross
  37. Honda wins Indy for 14th time.
  38. Best Replacement Options for Old Suspension Components?
  39. Honda Civic Coupe d16a difference???
  40. Is Honda Challenge in the mid-west dead?
  41. Front steering Column juter under threshold braking
  42. Custom Length Front Lower Control Arms
  43. Type R Clone Class/Points, NOT Hype R Poll
  44. Who would win?
  45. What tires to run for a Hyperdrive????
  46. 2003 Spoon Integra Type R Vs. Integra Type R
  47. RE71R vs RS4 Tire Review
  48. 2008 Acura TL S Type Front Suspension Torque Specs
  49. Stoppa's EK Coupe Debut at Dover Raceway Jamaica April2017
  50. Low compression / Trouble finding piston rings
  51. Brake plumbing for adjust proportioning valve
  52. Swapping pads betweeen street & track... re-bed the brakes?
  53. Holley HydraMat for road racing- Useful?
  54. jaytuner123's Quest To Road Race a 2006 Accord V6 MT (J30a4 engine)
  55. Civic EK vs Civic EG for HPDE: handling/feel
  56. LoveB's EG Circuit-track car
  57. 15x8 tires for solo and track days
  58. WRC 2017, Toyota Yaris WRC
  59. hpde del sol fun
  60. Looking for a really light fixed seat, suggestions?
  61. Odd Rear Suspension Woes on 90 Civic Wagon (RTA Bushing?)
  62. 2000 Integra Gussets w/ Roll Cage
  63. Formula 1 Austin vacation, tips for a first timer?
  64. Looking for autocross instructor
  65. Jordan Cox Civic EG at Bathurst 12 hours
  66. 93 hatch
  67. Shocks/Struts and Springs
  68. Information On R engines and Swap info
  69. Honda CR-Z as track/HDPE car
  70. Plexiglass side windows?
  71. Advice/Suggestions Request: Bolt-In Roll Cage Options for EG Civic
  72. Northwoods Shelby Club has added a second Road America event (April 29 & 30)
  73. Suggestions on use of Vibrant's "Exhaust Sleeve Clamp"
  74. Is there any utility to use a CB7 Chassis as RR/AutoX base?
  75. Camber gauges
  76. Is there a preferred option between manual rack or power steering for circuit use?
  77. RE Using Arp extended studs
  78. MRLS 1:44.9 Lap in B Series EK
  79. Let's Talk Bushings: PCI Bronze or Sphericals
  80. 2017 Northwoods Shelby Club Events (Road America/Autobahn/Blackhawk/Gingerman)
  81. SPARCO Roll cage? EK4
  82. brand new 14" cast wheel with flow formed barrel in the works
  83. STICKY? New to Auto-X? Read me! Beginner's Guide
  84. well driven sohc vtec on street tires @ BW13CW and WS
  85. Camshaft Choice Opinion: Skunk2 Pro 1 or Pro 2
  86. Need Help - EF Hatch Si Track Prep
  87. The Official Formula 1 2017 Season Thread
  88. Project Delly-Ohh for SLB/GTA/SEMA 2017 build thread
  89. Found some rust while removing sound deadening - any issue as track car candidate?
  90. Acura integra vs 240sx
  91. Traction Bar For Road Racing
  92. Oilite Clutch Pedal Bushings
  93. What? They don’t make great Hondas any more?…What about the Fit?
  94. JRZ Double adjustable dampers
  95. ASR Revolver RTA Bushings
  96. flying gravel eg6
  97. Double Clutching
  98. Drop Spindle for honda civic eg 92-95
  99. The truth behind bump steer
  100. SHG Motorworks EP3 Touring car build
  101. Creating a b20/vtec dirt track project: Suggestions regarding the build
  102. Is this rubbing normal, or more clearancing
  103. Request Assistance: Custom Adjustable Upper Control Arm Honda/Acura with Heim
  104. Oil temp and coolant temp for built B20
  105. 3BrothersRacing BB2 Prelude Road Race Car
  106. N/A or turbo
  107. prelude h22 cam suggestions
  108. Top Hats for Koni 3011
  109. Oil Pressure Fluctuation and Hard Cornering
  110. Flex-a-Lite Oil Cooler Kit Leaking
  111. Big chassis face off, I need technical info
  112. Target Oil Pressures and Oil Recommendation
  113. RCREW Brake Master Cylinder Brace
  114. Added a Vent to my Looped PS Rack
  115. TRACKED!! All-motor NA d16z6, close ratio transmission - VIDEOS!
  116. What are the advantages/disadvantages of swapping proportioning valves?
  117. AMP Bracket Enduro SCCA
  118. ep3/k20a3 questions
  119. Civic EG Integra LS swap race car build wiring question
  120. PZ Tuning Will breaks FWD Unlimited record at Gingerman Raceway
  121. Front Brake Lock-Up
  122. OS Giken Review
  123. Wivel - New tool for your car performance and skills measurement, feedback needed!!
  124. Tire question
  125. 2016 Race Videos.
  126. Koni yellow race shocks with GC top hats.
  127. R7 good for autoslalom?
  128. New R Division Time Attack EK build
  129. 2016 Civic type R eligible for HPDE/Track Day/Honda Challenge?
  130. Gsr Eg Hatch Build Thread
  131. 94 integra starts but starter sparks fire
  132. B series ek build thread
  133. Best light weight battery 2016
  134. LSD Question - Wavetrac VS Mfactory
  135. I have never been so excited to drive a honda
  136. Help, my swapped EG Hatch has been sitting in my garage for the past decade...
  137. DelSol roadrace woops. Setup advise needed.
  138. Fast spooling turbo that's doesn't break the bank?
  139. FUCA learnings of RR98ITR make benefit glorius humbling of prey...
  140. NJMP slip and slide
  141. Can hardrace pillowball bushing be rebuilt?
  142. Synchrotech MTF
  143. Prepping for MAP Proving Grounds 2016.1
  144. b20 403 crower
  145. and sometimes, it rains
  146. Honda Tech Lurker - Looking to start a build - Best platform?
  147. 93 civic hatch fuel filter probs help!!
  148. Pops out of 2nd gear autocrossing
  149. Turbo dc2 for hpde, how much tire is enough?
  150. Motor City Roundup Track Day 8/18/2016 Grattan Raceway Belding MI
  151. Seat for 250lbs +
  152. 24hr of Lemons 92' hatch
  153. Anyone discard these uca part?
  154. Rear bump steer L/R inconsistency EG Sedan
  155. F20B Pistons & Rods
  156. Feedback for ksport road race suspension?
  157. That new rocket bunny for the EG.... sex.
  158. RE71R Tire pressure questions
  159. Buddy club race coilover where?
  160. Boosted B in a race series??
  161. Very well done autocross video
  162. Clutch is too far awaaayyyyy!!
  163. Tesla Model 3 Virtual Reality First-Ride
  164. Korney's Honda Civic Drag/Auto cross/road course videos
  165. starting from scratch... honda civic SI 2010
  166. What wheel setup for the track?
  167. Civic EG brake pads compound F-R
  168. Honda CRX Aerodynamics
  169. Wich one is better for road racing Rsx or ep3?
  170. PCI trailing arm bushing install into DA?
  171. spring rate ratio vs. weight distribution ratio
  172. What would you do??
  173. Essential first track day tip: JUST GO ALREADY
  174. Brakes on Short Notice
  175. HPDE Tire Choice
  176. GPS Track Time 2016 Autobahn and Blackhawk Farms Dates
  177. good videos of mixed stock cars?
  178. This is my 2016 autocross thread - Atlanta region SCCA, SMF class
  179. Tube Frame CRX
  180. 2015 SCCA Solo National Championships Music Video
  181. SCCA budget build eg8
  182. Road Racing ??
  183. Looking for your support
  184. 4 Lug vs 5 Lug based on Wheel/Tire/brake setup
  185. LAGUNA SECA - TURN 6 TECHNIQUE ADVICE
  186. Samco Radiator Hose Question
  187. 2016 Northwoods Shelby Club Open Track Events (Road America/Autobahn/Blackhawk)
  188. Front BBK swap to Rear brakes
  189. Honda powered Ligier wins 24HRS of Daytona!
  190. Ingalls adjustable upper arms
  191. "around the foot" parts for touge?
  192. 2016 PTE Build for WCMA-1990 Civic Si
  193. PCI Rear Diffuser
  194. Will it Overheat...
  195. First gen Fit auto X spring rates
  196. Basic Integra track/hpde setup
  197. Where do I start?
  198. New to performance driving, Suggestions??
  199. AutoX tech/classification questions.
  200. Anyone running mfactory plate lsd?
  201. Suspension Refresh Advice
  202. Seats and cage
  203. motor mounts
  204. MVP Track Time 2016 Track Events (Come Drive With Us)
  205. Best coilovers for the track?
  206. Opinions on my aero idea...
  207. How much is too much?
  208. 225\245 40 17 instead of 15...
  209. Gsr vs ?????
  210. The Official Formula 1 2016 Season Thread
  211. Track Days and Fresh Paint
  212. Canadian chumpcar build
  213. B Series Baffled Oil Pan Necessity
  214. Boersma Racing Time Attack Civic Super Lap Battle
  215. Anyone here using an Accord wagon for HPDEs?
  216. Pikes Peak International Hill Climb turbo stroker B16 1st gen CRX build
  217. When NT01's go bad
  218. eg civic sts build
  219. Integra turbo issue
  220. 2015 Regional Racing Season Recap.
  221. NSX Koni/GC problem. Looking for input.
  222. Tube Chassis/Roll cage Fab shops in SoCal OC??
  223. Honda h2 prelude questions
  224. Anyone using wilwood combination prop valve
  225. Thoughts on using factory 3-point harness with sparco evo II on track?
  226. Dilemma With Engine Package
  227. Circuit of The Americas (COTA) February 26-28, 2016
  228. Cutting out lower core support...
  229. Anybody watching World Time Attack??
  230. has anyone ordered custom na bseries cams?
  231. need help!, roadraceautox account
  232. Will the to goes in or out when raising?
  233. Will the to goes in or out when raising?
  234. What dataloggers are you autocross folks using?
  235. Cooling setup for your track/Time attack Honda turbo cars?
  236. CRX Rally car
  237. 3 Hour Canfeild race at AMP. Nova Scotia, Canada.
  238. H2 Honda Challenge Suspension Setups
  239. Input on rear bumper mounted water coolers (liquid to air intercooler)
  240. K20a2 has bent rods 4 times now
  241. SCCA/NASA prep shop in the Carolinas
  242. Tips for beginners...
  243. best race motor options.
  244. Quick suspension help.
  245. h2 east coast champs race
  246. WRL GP2 Honda Civic win at Gingerman
  247. Odyssey PC-680
  248. gutted dash to no dash
  249. Chumpcar Sebring 14 hour
  250. Autocross question
