- B16 EK @ Lake Superior Performance Rally
- prelude or h2b civic
- ABS Integra Booster Work with Non-ABS MC???
- The Value of Coaching
- Suspension Cam on Stohr DSR Track Car - Suspension Deflection & Rotor Glow
- Who Broke the Sandbox
- Ej2 suspenssion setting
- B16A Internals
- Sebring 14 hour chumpcar
- what can i do without under the hood?
- Global RallyCross race EG6 vs. 996
- K20a2 swapped civic vs s2000
- Wanging it out at Wangtoberfest event. Gingerman Raceway 10/15/11
- Sad day for racing - Dan Wheldon perishes at Indy 2011 final
- water pump failure
- What size oil cooler are you using?
- New Time Attack Company in SOCal
- $105 Track Day@ Streets of Willow Springs- Oct 29 in Socal
- Tire and wheel choice dilemma, opinion appreciated.
- What would capture your interest? - car reviews / articles
- dog boxes for circuit racing ?
- Oct Socal NASA HPD Honda Challenge Raceweekend, wow!
- (Y) rated 15in tire
- Lake Superior Performance Rallies in Houghton, MI Oct 14-15
- Bathurst 1000 on Speed TV
- [NASA-SE] 2011 Great Pumpkin Run, Oct 22-23, CMP
- What if The Beatles never made Sgt Pepper?
- VIDEO: NCRC HPDE Buttonwillow CW#1
- Maitence on your track car
- Replace Hub?
- First Track Day, Some pics and Video
- 2011 NASA Champs HPD HC Race Report from Croiset Racing
- FS: Oct-Dec Race Tires or Wheels ONLY
- FS: Oct-Dec RACE CARS Only
- FS: Oct-Dec Race PARTS ONLY
- Weird little shields over rear brake calipers
- Recommended tire size
- Buttonwillow track day
- Ridge Motorsports Park NW
- Soft pedal, running out of ideas, need answer fast
- Koni raised prices on 8041_Race?
- Weekend Warriors (Coupes)
- The final word on crank dampers is .....
- Shaving tires
- The difference between a pro driver and you!
- How to design your own Formula SAE body using Autodesk Inventor
- First Track day this weekend.. Need Brake pads?!?!?!
- ITA race (and win) at Pacific Raceways
- Axles keep popping out w/ Kaaz diff
- When do I know I got enough spring?
- Front hub failure - Thoughts ?
- Measured my roll centers last night...
- "Get Started Racing" Autocross School at V.I.R.
- nascar door bar heights? and cage wall thickness question
- Calling all BOOST
- Koni Sleeve vs. GC Sleeve on 8041_RACE
- JDM EG SiR - Which AutoX Class?
- The EF-Bomb Chronicles
- Oregon Raceway Park
- Anyone use Rhino Ramps?
- 2 die in Silver State Classic crash
- Wider vs lighter?
- In-car video from NASA Nationals. H1-Kevin Helms
- Infineon Raceway Hyper Drive $50 per day!!!
- Newbie ignition help..
- Pics from NASA Championships @ Mid-Ohio
- R888 SALE 205/50/15 Heads Up.
- Sept 24-25 Streets of Willow Track Day
- What we know...what we knew...what gets forgotten...everything and nothing...
- OsosiK Media
- S2000 Roll Bar Hardtop
- Oil cooler setups with temp and pressure gauge
- Opti-Grip tire temperature sensor package - opinions?
- WangtoberFest - October 15th @ Gingerman Raceway
- Autocrossing brake pads
- noob trying to get into roadracing/time attack
- Post your OFF's...
- GRM Oct 2011 Racing Brake Pad comparison test at VIR
- Wangfest @ Gingerman Raceway Vids
- Heel-toe brake pedal effort
- alumalite 4x8 1/4" double sided for $109
- Sheriff's Track Autocross in an S2000 - 9/11/11
- Loose rear end under hard braking
- Anyone running a bigger than stock rear sway bar w/o a subframe brace on a DC2???
- 15x7 integra off set... spacer or no spacer?
- Boost by Gear vs Boost Controller
- SFI vs. FIA vs. ISO ratings
- Aerodynamic Cooling of Automotive Disc Brakes -Master's Thesis by Stephens
- Mission Raceway, BC, ITA Race
- Brake Theory, Well a Part of It.
- Quest for suspension
- AMR engineering vs revalved koni yellows
- Oil cooler hook-up question
- Autocross classing and build
- NASA Nationals 2011
- Incar video H2 EK civic Roebling Road
- Questions for endurance road racers
- Any Bad things to say about a Quaife QDF6U LSD?
- difference of 1.0 , 1.5 , 2.0 plate LSDs?
- The Ridge Motorsports Park.
- Putnam Park Lapping Day - September 9th
- $200.00 Reward
- Run through the field in a GS.R
- Continental Tire Grand Am Discovery Channel...
- Underhood heat evac. without cutting hood? Ideas needed.
- Dear RR98ITR,
- Building B18C1 for track time
- Suspension travel
- Royal Purple Sponsorship application
- Sept Honda Tuning Features:HPD SoCal HC-H2 Nat'l Champ Meris Motorsports Honda Civic
- TCRA Event: WSIR OCT 1-2
- nationals. how ready are you?
- The Heart Of Racing - EG Hatch time attack build from Australia
- Brake Pad help
- Steering shuffling
- Shifting rear sway bar
- what wings are you guys using???
- Crazy AEM deal spotted
- Top speed of a B16A equipped Civic @ Mid-Ohio?
- Track EG with k20 suspension advice
- Tons of track time available for Sept. 5th @ Gingerman
- Recommended Motor Oil for track use
- Battery location
- Time-Attack VIDEOS - from CSCS Aug 21st 2011
- Boosted Miata Time Attack VIDEO - 2 GoPro`s and one hand held cam
- UK Track pictures and a plate diff Q
- NASA-SE: Savannah Sizzler, Sept 3-4, Roebling Road
- HPDE In car vid of prelude
- Some shock pr0n for those interested in such things
- "How you comin' on the kaa?"
- Roger Foo EG civic at Laguna Seca 2001
- roll cage
- Bucket List Racing Del Sol ready to race again!
- NASA Championships: HPD Honda Challenge
- Exedy Hyper Single
- If You Need a Laugh Today..This is Your Spot. *INDYCAR Content*
- Just Got NASA Rookie Permit, First Race, Video.
- did dc2 won any majoy race in history?
- Racepack G2X compactflash card formating procedure?
- Nasa Southeast Roebling Road Sept3-4
- Some Alcon/Stasis Big Boy Brake P0RN :) For the other car...
- Anyone have CRX ITA Car?
- Kaaz 1.5 LSD users...
- Regional Road Racing: NASA and SCCA classifications
- $98 Track Day@WillowSprings-SOW- August 27-28 in Socal
- Brake Ducts For EK 99-00
- Sept 17-18: South Carolina Region SCCA PDX, Club Trial, Double CCPS and ECR at CMP
- rear trailing arm design on EF+ Honda's...
- New hood vent installed and ready to test!
- San Diego Military JDM ROll Call (HPED, AutoX, Road Race, Time Attack).. Whos Out THE
- Need help finding a driver
- what would be a better track car? ap1 or a b18c5 eg hatch
- Bisimoto tuning of a Road Race BMW
- B16 Ford escort RWD
- Kosei TS Lug Nuts
- SCCA Colorado Rallycross
- My trackday / time attack build
- Is there a demand for a groupbuy Mfactory custom gearing (longer 1st and 2nd)?
- Free Kirkey seat, what seat mount?
- wilwood dynapro or ap racing 11 inch kit for 300whp turbo integra
- tie rods
- Back to work. This is fun, right? (+parts wanted)
- 2011 Solo Nationals. Who's going?
- DARTON SLEEVES INSTALLATION IN NJ!!!?
- How to blow a K20. Cal speedway honda challenge h2
- The Gear Thread
- Toyo RA1 gone for good???!?
- Import expo time attack Mosport, Ontario, Canada
- Other racing forums
- Wheels (and tires)
- Tyre decisions - Input welcome!
- $112 FOR Buttonwillow on Sept 17-18
- What shift knob do you prefer in your Track car?
- NEHC at NJMP
- New brakes for s2k
- Perfect Race Weekend
- 06+ Civic Si Big Brake Question
- Hoosier R6's
- homestead HPDE Erme August 20
- Fuel vent line, spewing 1/2 quart of Fuel?
- Need help from the guru's! K series DC2. What class should we run??
- Help on front diffuser.
- You've heard of political correctness?
- Kazz LSD Speedo Gear..
- What is this lip called??
- Multiple Questions Regarding Honda Challenge Rules
- H2 vs. H4/ITA vs. PTx vs. "other" fun/cost/why? Q and A
- TireDB - Tire selector database website
- ITR Brake Conversion On 2000 Si
- Stage Rally Racing in WV - August 12th-13th, 2011 Showshoe, WV
- 24 hours of LeMons - Arsesweatapolooza T-Hill
- VIR....real racing....well at least going fast legally
- Best tires
- For some things a Lambo is better than a Type-R...
- New Guy
- Free Austin 2012 Formula 1 Tickets
- VIR this weekend
- ITA integra LS fluids
- NASA-TT classification question
- Shannonville Lapping Full Track Aug 1/2011 9am-5pm
- FARA Racing @ Homestead Miami Speedway August 20, 2011
- CSCS @ Mosport ~ VIDEOS ~
- Question on rear hubs
- Recommendation for helmet
- Spokane County Raceways, ITA Race
- FS: July-Sept Race PARTS ONLY!
- Want to start autoX
- how to spend 11k
- i've said it before and i'll say it again
- Pacific Raceways fun
- FS: July-Sept RACE CARS ONLY
- FS: July-Sept RACE TIRES or WHEELS
- NASA honda challenge July 30-31 roll call
- ROLL CALL: Who is going to Mid Ohio next month for NASA Nats warm up?
- Getting back into AutoX.
- braking issues at Expo11
- need info to weld diff please, running dirt track
- What oil pan are you using?
- TIRES for Road Racing (Willow Springs and Fontana)
- NASA Honda Challenge SO CAL - AUTO CLUB ROLL CALL
- My first track day - Nurburgring
- k20a Engine Help for Track Race use only!!
- Auto-X Wagon?
- KINGS PERFORMANCE RR CIVIC wins STU @ Roebling Road's Double SARRC SCCA ***VID***
- brake pad help for track days....brake upgrade on a civic
- Edo kickin more ass in the DA
- MotoIQ Pacific Tuner Car Championships @ Willow Springs - Recap
- I know you guys think I only crew, my cage is finally done!
- 25$ Ignition Modules on ebay?
- Cluelessmale's THread (I am a little slow, FYI)
- How to contact SpecialProjectsMotorsports?
- TRM wheels shakedown
- Old School Honda Challenge Anyone?
- Should I continue with my CRX ?
- Presentation and intentions with my EK honda
- What class am I?
- CSCS Time Attack
- New 99 ITA / H4 Integra
- Mishimoto OIL COOLER TRACK DATA?
- I disconnected my rear swaybar and I don't miss it one dam bit
- Grand-Am Spec LSD Available.
- EX 10.3" vs Si 9.5" brakes AutoX
- Roll Call for Honda Challenge Mid-Atlantic Heatwave Event @ VIR
- are there ANY ebay headers that are ANY good?
- NASA-SE: Firecracker Run, Charlotte(CMS), July 2-3
- Pics and Video: Thunderhill 6-24-11 in the Evo 9
- Who is going SCCA Roebling Road July 2-4
- First time on R-comp woes
- Good Quality 12V Portable Air Compressor?
