Advice/Suggestions Request: Bolt-In Roll Cage Options for EG Civic
Looking for a bolt in roll cage for my EG6. I've been looking to go with Cusco. Any suggestions on other options? I don't want to weld and prefer a bolt in cage.
Ridin Dirty in Cali
re: Advice/Suggestions Request: Bolt-In Roll Cage Options for EG Civic
What in gods name is that thing behind those seats?
It looks like a harness bar? ya don't want one of those ever.
I'm sure this is why you are asking about roll cages.
Helpful hint Go to Google Type Roll Cages-Honda-tech.
You will have a plethora of bolt in options to read about and make an informed decision on.
Another question.. why do you have the turn signal indicator on a stripped down trackish car?
Re: Advice/Suggestions Request: Bolt-In Roll Cage Options for EG Civic
If you are really looking for a track certified or approved cage, Autopower has a solid platform. As for Cusco, I know that a lot of sanctioned organizers do not approve of the Cusco design. You need to check for the other manufacturers. I know for sure that Autopower has SCCA/NASA certifications for specific models of their role bars and cages.
Scott, who thinks that you can take every precaution and still end up going thru the cheeze grater...you accept that or you don't do it...
A quick glance at the Cusco USA site will show you that their D1 bolt in cage is an appearance accessory only and so only a douchebag would install one in their own or anyone else's car. None of the permutations of their Safety-21 model FIA bolt in cage look to have a main hoop diagonal and are hence not compliant with SCCA rules for production based touring type cars.
Scott, who thinks the newer the car (ie the more crash safety engineered into the structure) the less important the cage...that said if you're gonna do it do it right - especially with respect to side impact protection...
https://www.youtube.com/watch?v=d9n9pGQxHP8
Scott, who isn't sure he's got all the details correct...details like was it even Chad...but the takeaway would be the same...
Last edited by RR98ITR; 01-30-2017 at 01:36 PM. Reason: Trust No One...especially myself...
I like to party
SCCA rules require a diagonal bar off the main hoop? News to me.
Which word douchebag? Uh-oh, that came out wrong...Which word? Douchebag?
I'll admit my GCR (which I double checked prior to posting) is a few years old, but there's No Whey they have deleted that.
Scott, who used to fly thru the air and impact the ground with his body directly...I really prefer being belted within two concentric safety structures...
Moderator
... Chad had Kirk cage...Chad had Big Crash...Chad live...Chad look hard at remains of car and cage...Chad maybe surprised he live...Chad give Kirk much credit...Chad want others live too...
Cusco D1 "rollcages" do not meet SCCA or NASA requirements, and even if they technically did I wouldn't use one. They don't even look "right." If I remember correctly, the JEGS kit is weld-in and made to meet NHRA (?) standards. I think both the Kirk and Autopower kits are fine and know people who use both in competition (SCCA & NASA Time Trials). What I found when I was considering buying the Autopower bolt-in roll bar was that by the time I added the main hoop diagonal (yes, as required, see below) and the freight shipping it cost the same amount of money as having a professionally built custom roll bar installed, so I went that route. It was certainly cheaper than the cheapest Cusco D1 too.
From the SCCA GCR:
9.4. ROLL CAGES FOR GT AND PRODUCTION BASED CARS
B. MAIN HOOP
2. Main Hoop Bracing a. Main hoops shall incorporate a diagonal brace. The brace shall either be in the plane of the main hoop, or extend from the top of one rear brace (described in 9.4.B.2.c) to the bottom of the opposite rear brace. Automobiles with mid mounted engines can have the lower mounting point attach to the frame of the automobile within six inches of the main hoop. In the case of braces in the plane of the main hoop, the brace must span at least 50% of the width of the main hoop, and at least 75% of the height of the main hoop as shown in figure 12.
Link to SCCA GCR, roll protection starts on page 108:
http://cdn.growassets.net/user_files...pdf?1472053873
From the SCCA GCR:
B. MAIN HOOP
What Josh said about the relative cost of bolt in cages vs pro/custom is good. If you just want a 4-point roll bar for track days then any good retail bolt in is fine. About the time you need a cage (because you're going to race the car) you really should find the best local fabricator you can (who has experience building SCCA compliant cages and has a good business reputation).
One little detail thing about cages - the rearward braces from the main hoop must run to the spring/shock upper mount areas and NOT all the way back to near the rear bumper mounts. The rear of the car (especially a front wheel drive car with the gas tank ahead of the rear axle line) is a crush structure - let it do it's job. I mention this because I've seen this done wrong and I wonder what the hell they were thinking (they probably Were thinking but just Wrongly).
Scott, whose cage was built by a formula and sports racer fabricator and while good enough could have been better...so look at lots of cages, think yours thru thoroughly, don't skimp - pay what it costs, and travel if you have to...
SCCA.. is that good enough?
the Autopower Race rollbar is approved. The one with the removable diagonal bar is approved for certain events.
NASA rulebooks also mention certain restrictions.
For the most part, the cusco bar is not approved because it does not have the diagonal bar in the main hoop and the A-pillar bar has a dual bend in down-tube. You can find such information by doing a Google search for NASA or SCCA rule book, or safety regulations. I've done some research, I don't know it all, but I have read bits and pieces of the rulebooks prior to purchasing the Autopower rollbar for my car and installing it.
I have a OMP bolt in rollcage, does require welding, I hate it , cantfit properly with 6"3.
