Civic EG brake pads compound F-R
Hi, I need some advice on brake pads compound for my time attack EG. I currently use the wilwood Dpha caliper with hawk dtc-60 in front and stock caliper rear with hawk blue 9012. I have good stop, but at high speed braking the rear is way to sensitive and lose control. The weight is 2,100 and use dot R-compound tires. Thanks for the help
Spongebrad Squarepants
Re: Civic EG brake pads compound F-R
I have used the same compounds without similar results.
I went to a XR2 for a bit more bit.
What are your alignment settings?
The only time that I've had that issue, I had some sort of debris in my left rear caliper. Threshold braking into fast brake zones was gnarly to say the least. Finally after two brake bleeding sessions, the debris flew out and it was back to normal.
with Integra calipers on my EJ2, I'm doing HP Plus up front, stock in rear.
That's with stock power.
Friend with B16B is running DTC60 up front and stock in rear. He also has integra calipers.
Are you checking your tires with a pyro meter?
Personally, I ran 2.8 in front, and 1.8 in the rear. 2.8 in the rear seems like a lot?
I know what squirrely feeling you're having, and for me it was the weight transfer and the rear getting light...aero can help, it did for me somewhat by adding a wing.
Wait, I just noticed you toe'd out in the rear??? set that back to 0 and I assume you might have more control.
A few questions/comments:
1) Are all of the suspension bushings in good shape? Are they OEM, hardened rubber, poly, or spherical? I know that people mentioning issues if poly is used for the rear trailer arm bushing, but I'm not sure what effect it would have on the braking.
2) Have you always had issues with the rear feel unstable under hard braking, or was it only after some recent modification? What I'm wondering about, is the possibility that maybe the rear brakes are locking up too easily, and that people are thinking about too much rear camber or possibly the rear pad compound causing it. Also, what size rotor do the front Wilwoods use? I thought I read something about them using somewhat of a small rotor, so just thinking about the possibility that the fronts aren't quite as well balanced as they should be.
Personally, on my car (2000 civic hatch), I'm using around camber of -3.5 front and -2.5 to -2.6 rear which seems to be a good average setting. I originally used Carbotech XP10 (front) and AX6 autocross (rear) brake pads, but after I switched to Raybestos ST43 front pads, I felt that the fronts were locking up earlier than the rears, so I switched to Carbotech XP8 pads for the rear. What I'm getting at, is maybe the Hawk Blue pads for the rear are too much and causing most of the issue for you. - Jim
Personally, on my car (2000 civic hatch), I'm using around camber of -3.5 front and -2.5 to -2.6 rear which seems to be a good average setting. I originally used Carbotech XP10 (front) and AX6 autocross (rear) brake pads, but after I switched to Raybestos ST43 front pads, I felt that the fronts were looking up earlier than the rears, so I switched to Carbotech XP8 pads for the rear. What I'm getting at, is maybe the Hawk Blue pads for the rear are too much and causing most of the issue for you. - Jim
clement_h
05-22-2003 07:45 PM
