- Koni + GC + GC Top hat, which height should i use?
- H2 Civic Dyno Results
- what happened MFactory????
- power steering?
- converting to rear disc
- Wide front fenders
- High Speed Light Brake shakes, should I be worried?
- Okay, where do you guys find wide 4 x 100mm wheels?
- Rally Links?
- Increase rear brake bias?
- Brake Caliper options
- 24 hr of Daytona
- Autopwoer Roll Bar
- replacing brake hoses
- Anyone racing without swaybars
- Sage Racing Singapore ?
- Thread pitch for 10.9 bolt
- I need more downforce (aerodynamic experts please)
- Vehicle Transport across country..
- Safety wire help needed.
- Is this a good suspension set up?
- anyone using rugged radio ST 16-U ?
- 22mm ITR rear swaybar OR 24mm ASR rear swaybar?
- Video from GT Live at VIR
- HF Front Swaybar for sale $100 shipped
- choosing a new tire ?
- sphearical tierod end??
- Honda as a learner?
- lightweight battery
- Buddy Club seat rails!
- bolt in cages
- Exhaust Silencers?
- Wet versus dry autocross setup questions
- Civic EG road race suspension questions (did a search.. answers not there)
- It's a lot of work to go racing.
- can you change 88 crx rear lower controll arms to 89 in sts2
- TT and Open track with COMSCC
- Choosing tires, not so easy...
- 225s on EG Hatch?
- Building ITC '91 Civic, any reject parts out there?
- H22 in Road Race Project civic
- Numbers for track days?
- Suspension setup.....opinions?
- Where to find: Nylon tow hook.
- Cage builder near NEPA???
- REM Treatment to trans internals?
- What does your water temp gauge read while running?
- Sparco EVO 1 & 2 & 3
- 16 Hours of Lemons at CMP in 08?!
- 15x6.5+35 w/ 225 (front); 15x7+43 w/ 205 (back), opinion?
- all you guys from jersey...
- Anyone here run with trackdaze group before?
- BEST SAFETY DEVICE ?
- Eastern Pa Solo AutoCross Event October 2008
- never autocrossed before but gonna try it....
- staggerd for autocross...thoughts..
- 15 inch rims for autocross need help asap!!!!!!!!!!!!!!!!!!!!!!!!
- what clutch are you guys using?
- revalving and shortening bilstein questions
- Discounts at Laguna Seca, Willow Springs, and Streets Track Days
- Seating - Autox primarily, track days possibly, street occasionally
- 2008 Solo Rules up
- Harness belts
- A safety decision
- NASA CAGE LEGALITY ?!
- SPONSORING FOR 2008
- Chilibowl? anyone going
- Redline HPDE event, Feb 9th & 10th, need some info.
- Suspension guru's, Macpherson question?
- How can we measure the effects of stiff rear springs vs. larger rear sway bar?
- gsr speed limiter?
- Vehicle Storage - Locations in CA recommended?
- 2008 Redline Time Attack - Buttonwillow, March 29th-30th
- FAL fans and turbo?
- Need an eye bolt in a specific thread size.
- Going to the races NASA HPDE
- UCA variations
- Race setup k20a k20a2 k24a2
- WHAT THE RULES SUPER LAP BATTLE
- Honda Challenge race engine specs?
- extra wide rear view mirror
- New track car or keep the old?
- The Champ Car World Series 2008 thread
- Booo. Dakar rally cancelled..
- Racing an automatic?
- *curious what rails u guys got*
- Direzza Sport Z1 for track use
- tow hook?
- P1 Spec Splitter Kit
- Replacement for Bridgestone RE-01R is Coming
- Anyone notice Autozone rotors went up in price? Any other options?
- Effects of installing top hats on suspension set up
- ? pci rear trailing arm bushing on 91 teg TA
- quick late night ? about autox stock class rules
- Track Pic's from 2007!
- Keep Oil Squirters or Block Them Off?
- Which chasis to build ?
- Autocross and no powersteering?
- RA1's and age???
- higher spring rates and rebuilt koni's help
- how much shorter RACE SPSS3
- ED(EF)/CRX scrub radius
- quick question on oil temp
- 25hr of Thunderhill Story, Pics and Movies!!!
- How long did you wait to switch to R comps?
- Extended top hats........
- Opinion on this 6 pot fastbrake kit and 15" wheels?
- At what point does too much drop = Bad handling?
- Great deal on rims and tires!!
- street/track coilovers?
- ASR 24mm Rear sway bar setup!
- NASA 25 Hour pictures
- H2 civic brake setup
- finding an old racer tony tbone
- Size of K24 engine/tranny
- Rear trailing arm bushings
- Where to get Team Dynamics wheels?
- REDLINE @ STREETS FEB 9 & 10
- NOOB, looking for HPDE setup assistance, searched..
- EVENT ALERT: Vegas Money Race Jan 12,13 2008
- Merry Christmas Racers and HPDErs!
- 15 x 10 and 15x9
- this tall guy needs some help
- spec clutch- is the $200 lighter aluminum pressure plate option worth it?
- Hawk HP+ Where's the cheapest place to buy them?
- Spherical Bearings, Roll Center Adjuster..suspension Help!
- NASA HC 2008 Rules Are Posted!
- who has a cage with a full interior??
- Wilwood or AP racing Big brake kit
- TOGA HV oil pump feedbacks
- My recent trip to J-land for Honda Thanks Day
- We-Todd TRACK day info for 2008!
- what you guys think
- crx road racing guys
- Pics or links to site for proper seat and harness mounting
- New to the site!
- Heavy versus Light wheels - Acceleration Tests and their results
- Starting Autox next season
- Cheap Way to start Road Racing
- interested in renting PTE car? (mid-at)
- NASA racers: Head and Neck restraint w/ SFI 38.1 stamp needed for 08
- Need pics from the 2008 GCR .pdf.
- WMHM track day preparations part 1 !
- 22mm rear swaybar subframe reinforcement
- CV shaft failures, please post experiences
- Most popular/common tire diameter
- 15x7 or 15x6.5
- experience with "drag" brand wheels?
- Damage I might cause my car at Auto-X?
- Anyone know where I can get a tire hydrometer?
- tires or brakes ?
- oil pan baffling/clearance?
- spring rates vs sway bar diameter
- kaaz lsd install help vechile sensor not working
- 2008 MLR Motorsports H1 ITR Paint Scheme
- What is Racing All About
- I want to do AutoX in SoCal
- Road Race Cars - Which suspension system are you using?
- EG Hatch vs. EF Sedan
- auto -x issues trying to fix for next session
- Steering wheel size?
- New track in central texas
- question for the LSVtec road racers out there
- Rally Videoblog Teaser Vid
- reviews on seasonal tire tote?
- ***B18MOBBER RR***
- 96-00 knuckle geometry
- *Official 2008 NASA Northeast Event Schedule *
- the best spring rate for road race....
- Stock ITR AutoX Question - Engine Mounts
- NASA TT/general NASA classification?
- autox my first time in my first si
- Camera Mount Recommendations - Considering a cruisecam
- Has anyone volunteered on track?
- Differences between revalving Koni Sports vs 3011?
- Only a few left! - 2008 NASA-SE Holiday Coupons
- Safety First!
- motul RBF600 vs. Dot 5.1
- master switch
- ***BACK FROM TEST FOR NASCAR BUSCH SERIES***
- Skid plate / bull bar
- New Driver!
- Redline Track Events, Streets of Willow, December 14th
- Which Civic Model for AX?
- Hawk HPS vs HP-Plus on a street/track driven car, whats your preference?
- Ran into a racing enthusiast yesterday
- HART Accord
- Wiring up switchboard?
- Spring rate setup question
- Wanted to get into road racing, but after researching I'm thinking about autox...
- Who has the 25 hour pics?
- OT: THinking of buying a truck today need some help
- Anyone doing the holiday laps around VIR this friday?
- December 16th Speed Trial. Who's going???
- resFederal announces 595RS-R with 140 treadwear rating
- Why are race cars sedans?
- brake rotors
- New to Autocross!
- ASR's 24mm Swaybar Kits!
- Derek Daly to help design a 3.2 Mile road course. Merced, Ca!!!
- Which vendor?
- honda challenge (west coast) how to enter
- Lug Nut Question regarding T1R brand lug nuts
- NEW WCHC Video From My car EdoMoto
- rollbar to cage question.
- tons of questions. preparing for first track day. HELP PLEASE
- Alignment Settings...
- I NEED HELP!!!! WHAT IS THIS PART CALLED !!LOOK!!
- shortened koni yellows
- Research for possible rules revisions
- ITR race project
- 2nd Annual Western States Road Race Classic - Karting @ Infineon Raceway
- Roll cage material
- carbotech xp12
- Question about tracking brand new cars?
- JGTC vs NASCAR
- Dummy headlights?
- project time attack ef9
- Anyone autocrossing the new Si?
- stock pads for really light track use?
- Which material should I use on the end portion on a swaybar?
- azenis vs g-force
- 225/45/15 w/ 15x7 or 15x7.5???
- Time for a new website: Looking for your suggestions & ideas
- Harness Lap belts.... PULL UP vs PULL DOWN?
- autocross setup/advice ***Need Some HELP***
- 25hr of Thunderhill, HERE WE COME!
- tein super racing
- 2008 Track Days Invitation and Holiday Gift Idea
- Corbeau Seats
- I got a miata for 90 dollars.
- EF Racecar guys? Front upper A-arms?
- What is the funniest car you've driven...
- Aerodynamics: BMW roof fin
- Video-First day with New CRX, first real day with FWD
- Im in Florida this week... HAPPY THANKSGIVING
- Track/Semi DD final build list
- Skunk2 Pro-C coilover review
- spring rates
- Wheel studs installed, now rotor does not line up with them, wtf?
- ******Whose thinking about entering in the $2008 Grassroots Motorsports Challenge? I have the car f
- RSX for Road Racing, good or bad?
- Motor question
- PRI Show Dec 6-8
- What do you think of this suspension setup...
- Silly Season mod to do list help....
- What brake lines to yall use?
- Grassroots Motorsports $2008 Challenge 89 Civic hatch
- Hatch wing
- Installing Endyn Oil Breather
