PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. 04 Honda CR-V OPDS sensor
  2. My Evolutions
  3. 2013 CR-V 2.4 excess oil consumption
  4. Drain Plug Gaskets
  5. Honda Cr-v 98 Rd1
  6. 2019 CR-V Touring After Market Wheels
  7. 01 CRV overheating issue
  8. Just signed up for a lil advice
  9. Pink wire next to speed sensor
  10. stops running at warm up
  11. 2013 CRV Fluctuating Temp Gauge
  12. 2011 Cr-v high oil consumption
  13. Need immobilizer brake code for 04 Element
  14. 2001 Honda CRV won’t start when Humid
  15. 06 element bypass oil pressure switch
  16. Gen 2 Heated leather/Heated mirror Swap
  17. Oil Leak
  18. Knock Sensor P0325 Code
  19. Replacement infotainment / stereo for 2016 crv
  20. Immobilizer ECU issues
  21. random low idle stall in 2001 Honda crv
  22. 2002 CRV Headlights won't turn off.
  23. Rear drive shaft snapped
  24. rear drive shaft snapped off
  25. Deactive airbags DEATHBAGS
  26. Brake Light/Fuse Block issue
  27. Blinking D with error codes P0700 and P0753
  28. 2000 crv main relay clicking
  29. Stripped engine mount bolt on 1998 Honda CRV HELP PLEASE
  30. Transfer case auto or manual awd (same)
  31. First gen cluster / dash light behavior
  32. Flashing green key / immobilizer
  33. Catalytic Converter Rattle upon start up
  34. 2005 crv vibration at idle and takeoff
  35. Need new ignition - what next
  36. 2019 Rear Hatch Batches
  37. Flashing green key light / immobilizer issues
  38. 2004 crv
  39. Honda Element: Prioritizing what to fix from a multitude of problems
  40. Gen1 CR-V chassis
  41. N2012 Honda CRV starting/rpm problems
  42. Honda Element buyers guide, help.
  43. What is the last year CR-V didn't have CVT
  44. Iridium Spark Plugs
  45. 1997 CRV shifting noise
  46. Manuals for Self Service-Maintenance
  47. 2.4L Element external tranny filter
  48. Crv loses power and shuts off while driving
  49. 03 element dies when cold??
  50. 2002-2005 engine swap
  51. 2000 CRV MT AWD; Front Lower Engine Mounts
  52. Warning lights
  53. my first honda (crv 2018)
  54. 2008 honda element, missed or hard shifts
  55. 2007 Crv Power Folding Mirrors Installation......?? Help!!
  56. 06 crv issues starting (brand new battery)
  57. VTV Actuator Bolt Removal
  58. How to disable horn beep
  59. 2006 CRV Power Window Issue
  60. Part number help
  61. 02 into 06 crv engine and trans
  62. Battery will not charge. (not alternator)
  63. 2004 Honda ex crv
  64. Would a dealer trade work?
  65. 2002 Honda CRV intake manifold, throttle body, and cold air intake
  66. 2011 Air Mix Actuator issue
  67. 2016 CR-V AWD maintenance: rear differential fluid
  68. 2016 VS 2018 CRV Seat Rails (Leg Room)
  69. B20Z Crank sensor
  70. 2001 CRV rust- need advice
  71. 2005 Element Codes...won't start
  72. Saving and boosting a 98 CRV with a B18C1
  73. 99 crv not shifting into final gear
  74. Oil Dilution issue fixed on 2019 model?
  75. Gen1 Crv Engine almost cuts off when turning steering wheel
  76. 2018 or 2019 CR-V?
  77. Brake pad replacement and parking
  78. Oil leak-oil pan gasket? 2002 Honda CR-V🚕
  79. what suspension are u guys running
  80. Oil leak, oil pan gasket? 2002 Honda CR-V
  81. Rpms rev when clutch pressed.
  82. 2011 CRV-SE VTC Actuator noise on Startup - This year not in TSB?
  83. Rear Defogger 2000 Honda Cr-v
  84. CVT transmission reliability?
  85. What all Honda/Acura parts will interchange with my RD1.
  86. 2014 CRV Key fob battery replacement didn't work
  87. 2004 Sinking Brake Pedal
  88. VTEC Solenoid Bolt Broken and Stuck
  89. HELP !! Stuck rear driverside door... failed actuator... can’t get the door to open.
  90. Buying a used car need advice
  91. Hey Guys New too this
  92. Honda CRV 1999 A/C issue. Pressures not ok. Not cold at idle speed.
  93. Odd electrical issue with 2012 CR/V - bad alternator or something else?
  94. 2000 CRV AWD-Removed Drive Shaft-Will not move
  95. Heater not working despite work
  96. 05-06 CRV headlights
  97. No gas to fuel pump
  98. column shifter locked on d2
  99. 2006 Honda CRV AUX button on Stereo...
  100. my 2011 Honda CRV tailgate lock and rear driver side door locks just stopped working
  101. Electrical short
  102. 99 honda crv p1399 code
  103. 2005 Honda Element good buy for 3K?
  104. Auto to manual transmission wiring harness
  105. RD1 “CR-V” Third Brake Light
  106. CEL CODE 1167 Wont Go AWAY!!!
  107. 2013 CR-V Automatic Choke
  108. Hazard light and turn sig dont flash
  109. 08 Element AC working intermittently
  110. Bouncy front end after new tie rod installation
  111. 2007 honda crv timing belt or chain
  112. ac on crv not working
  113. 2004 electrical - already replaced alt and battery
  114. VTEC Oil Spool Assembly
  115. Am I doing something wrong or is it just crap?!
  116. Is Honda K20A1 engine Head gasket the same with K24Z1?
  117. gas smell in cabin
  118. Crankcase breather hose connection
  119. 2.2 diesel swap?? 2nd gen V
  120. 1st gear feels heavy
  121. Best brand AC Compressor? 03 CRV
  122. 2018-CR-V issue with gas in oil
  123. p2646 2003 honda elelemt
  124. 2006 CRV
  125. 2018 CR-V how to service rear brakes with electronic parking brake
  126. 2012 CRV TPMS Recalibration
  127. 2007 Diesel itdci bolt torque settings
  128. Having problems with my 07' DII
  129. ABS Code 14, intermittent left speed sensor issue
  130. 2005 Honda Element Battery Light Troubles
  131. 99-00 Civic power window motor fit 98 Crv?
  132. Spark plugs
  133. Headlight: Low beam doesn't work, even with new bulb
  134. Some questions about steel wheels on a Honda Element
  135. Stripped threads on sway bar bushing bracket.
  136. hello Does the new cr v 2019 has Smart Parking Assist
  137. 2003 CR-V Power Window Issue
  138. 97 CRV close to OverHeating with Full Radiator !
  139. Left Headlight fuse keeps blowing HELP!!!!
  140. Garmin Nav
  141. downstream O2 sensor
  142. 2016 crv dome light malfunction
  143. Are all 03-11 Element suspension parts compatible with 02-06 CRV 4wd?
  144. Dash lights on 2006 ex
  145. 2003 honda crv left highbeam will not work
  146. 06 RD6 dome light and lights on alert inoperable
  147. 1999 CRV - need a wiring diagram for power window master switch connector
  148. 2018 1.5 T CR-V Motor
  149. Honda pilot/accord/odyssey sunglass holder map lamp console on crv 1st gen
  150. 2010 CRV Strut Replacement Problems
  151. P0011 Fault Code
  152. i have 99 crv blower motor wont trun off when i start truck
  153. 2010 CR-V 2.4L Engine Missing or ?
  154. 2003 CR-V cranks but won't start
  155. 2000 crv rich cel and cat cel exaust smells of fuel
  156. 2004 CR-V feels like it's driving into a headwind
  157. Brake and suspension issue
  158. Replacment CAT
  159. Diagnose exhaust valve failure '03 Element
  160. driver window wont go go down
  161. 2003 CRV floods and is a pain to start
  162. 2003 Honda CRV ground locations
  163. Lifted offroad crv build
  164. CR-V R20A2 MAF/IAT values range
  165. 98 CRV awd 5 spd with Integra type R swap
  166. 97 crv crank no start?
  167. Transmission fluid change
  168. Honda CRV 2018
  169. 2006 CR-V addling reverse gear lock out after 6 speed conversion
  170. 99 CRV - Drivers power window stopped working and need help diag
  171. H
  172. crv oil filter?
  173. Seats in 03 Element
  174. 1st time engine removal looking for some help
  175. main relay
  176. Transmission Shudder 2008 CR-V
  177. Pictures: 1st gen crv rear diff clutch pack vs 2nd gen.
  178. power steering
  179. cruise control
  180. is it possible to swap a h22 in a 2000 crv with no issues?
  181. CRV motor fro Japan change to USA oil pump
  182. CRV ECU
  183. Stiffer springs
  184. bluetooth in crv 2009 exl
  185. 1999 CR-V quiet thumping when accelerating very slowly
  186. 2000 honda crv (non 4x4) vibration
  187. Repeated Trans Mount Failure CRV EX AWD
  188. CRRepeated Trans Mount Failure
  189. crv ivtec model 2002
  190. 20066 CRV-Brake Caliper pin designation: Which ones go where?
  191. Knocking sound from front end
  192. 2017 CRV reporting problems with multiple electrical systems
  193. Honda CR-V II 2003 K20A4 error P0325 and camshaft wear
  194. 2007 Honda CRV sputters
  195. 99 CRV EX shifter bushing replacment
  196. VSA indicator on
  197. 2019 CR-V
  198. honda crv 2018 touring
  199. worn tyre
  200. 2005 CR-V Idle not the same
  201. Wheel Alignment
  202. 2005 CRV no tail lights
  203. Towing a 99 CRV EX AWD
  204. HELP!! Trying to center rear wheel after 2.5 Rear lift
  205. Tire our side worn
  206. What neuspeed front strut bar fit, 1st gen CRV
  207. 2008 honda element
  208. what are best tires for the best ride in a CRV
  209. The Saga continues now have codes P0505, P1077 and P1505
  210. My 2006 Honda CRV is eating O2 sensors.
  211. 2014 CRV Grinding noise at start up
  212. Purchasing a Third generation (2007–2011) Honda CR-V
  213. Test drove a 1998 CR-V
  214. crv radio
  215. new key with out the key tag (code)
  216. Crank no start 00 honda crv
  217. DIY question pls
  218. 2002 CRV - A/C Problem
  219. Rolling rattling noise on right turns
  220. Multiple fault codes 2005 CRV
  221. Bumper sag
  222. What's the biggest tyre size ???
  223. Engine cooling temp switch, or radiator cooling fan switch
  224. 2016 Honda CRV Alternator Bad?
  225. remote engine start
  226. Rear quarter panel
  227. Assistance Needed: '07 CR-V Diesel - Location of A/C pressure switch
  228. rear disc
  229. RD1 VS EK Chassis Differences
  230. Honda CRV 2002 Oil Leak(s) Driver Side
  231. Cr-v 2014 replaced steering gearbox and DTC 52-01 has been set.
  232. 04 CRV lowering
  233. 98 CRV 2WD conversion
  234. Distributor rotor location 97 CRV
  235. 2006 CRV Fuel mileage Disappearance
  236. 2003 CRV clutch and flywheel
  237. Camber kits
  238. What is the air pressure on the spare tire for 2009 Honda CRV ?
  239. Have codes p1078 and p0325 2002 CRV
  240. 1997 CRV ABS Code issue
  241. I have question with change dashboard
  242. Here is my CRV RD1 97'
  243. New CR-V 2018 purchase questions
  244. HVAC control panel 2014 CR-V
  245. please help, 97 engine swap gone bad
  246. Fuel Gauge is inacurate
  247. Wheel stud replacment 2012 CR-V Front Wheel
  248. Honda CRV shuts off mid driving
  249. Honda Element intermittent vibration
  250. CRV V-TEC SE clutch flat on floor
