Honda CR-V & Element 2WD & 4WD Element & CR-V
No gas to fuel pump
Old 12-16-2018, 09:14 AM
FMOORE145's Avatar
Default No gas to fuel pump
2003 Honda Element EX auto
We had to replace the heater core, so took out the dash. When we put it all back together the car will not start; it is not getting gas to the fuel pump. Replaced the fuel fuse relay, checked all connections, checked fuel fuse. Still no go; any thoughts?
Old 12-16-2018, 07:49 PM
avisitor's Avatar
Default Re: No gas to fuel pump
Long shot ... may be one of the connectors didn't go back on right.
Would inspect some of the connectors that were taken apart for damaged pins?
Especially any ones near the steering column?
Old 12-17-2018, 03:30 PM
FMOORE145's Avatar
Thanks for the reply. I pulled the fuel pump, checked it over and put it back in and suddenly it started up. So, hopefully, fixed for the moment.
Old 12-17-2018, 03:36 PM
avisitor's Avatar
Well, that sounds like it had nothing to do with changing the heater core.
Just another problem that popped up on an old car
CPT Del sol
15
10-05-2011 06:15 PM
B20_ej1
16
04-02-2007 04:14 PM
lgn1281
10-14-2005 08:26 AM
Quick Reply: No gas to fuel pump
