PDA
View Full Version : Honda CR-V & Element
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. ECT (Engine Coolant Temperature) Sensor locations, on a 2008 CR-V?
  2. Help no. Spark
  3. 2021 CRV battery changed = all dash lights
  4. 2008 crv blionking red 'D' light
  5. 1998 CR-V Manual, Best options for torque
  6. Transmission fluid
  7. Car Upgrades
  8. creeping idle issue
  9. 2004 CRV: Brakebooster
  10. Maintenance schedules
  11. 2016 CR-V push button starting issue?
  12. Vtec bolts
  13. 2002 CRV- Bypass A/C with shorter belt
  14. 2006 CRV front cross member
  15. Ecu help for Honda CRV K series 2002-2007
  16. 2003 Honda Crv Fan issue
  17. 2002 CR-V Upstream O2 sensor, way too expensive
  18. 2016 CRV Beeps outside pulling away from a stoplight ..sometimes
  19. help with po1164
  20. 2020 CRV battery goind low intermittently
  21. Why is AWD is always on this winter? 2025 CR-V Hybrid
  22. 2025 Hybrid heated seats not remote starting
  23. Custom CRV Functional hood vent (with rain trays) project
  24. 2025 CR-V Key Fob
  25. 1st Gen CR-V Crank No Start - PGM-FI Main Relay no ground
  26. P75-6 head on CRV
  27. 2026 CR-V Trailsport
  28. Turbo build ideas?
  29. 2001 AWD Auto to manual swap
  30. 1997 CRV, Dash light question
  31. 2003 CRV - Need help with full A/C replacement / Black Death
  32. Injector coding
  33. 01 CRV Idle Issue
  34. 2009 Element TPMS Issue
  35. HondaPartsNow parts diagrams
  36. 2007 CR-V Power Steering Pump recommendations
  37. 2013 CR-V 2WD EXL Short Term Fuel Trim Bad
  38. D-ring that fits 2025 CRV key fob
  39. Need Advice On 2002 CR-V Oil Leak Near Valve Cover
  40. 2005 Honda Element headlight issue; low beam
  41. 2005 Honda Element motor mounts; Beck Arnley vs. OEM?
  42. 2004 Honda CRV surging at 3000rpm
  43. 2nd gen 2004 honda crv replacing rear driveshaft
  44. Manually Locking Drivers Door (Switch above handle), Auto Locks All doors?
  45. Front brake rotors
  46. 2018 Honda CRV - Timing Chain stretched/replacement after only 120k miles
  47. Need Advice On 2002 CR-V Radiator
  48. 2013 Honda CR-V Radio Powers On but No Sound From Speakers
  49. 2005 Honda Element squeak noise disappears after turning the steering wheel
  50. 2010 Honda CR-V EX-L Navigation Unit wiring color diagram
  51. B18 auto trans compatible with B20 engine
  52. What’s a CR-V Millennium edition?
  53. 2020 CRV electrical all windows opened
  54. Engine-light-big-problrm
  55. Rust issues
  56. Help on white smoke on exhaust
  57. Dash lights are out!
  58. The battery light is making me go insane.
  59. Odd sound coming from engine compartment
  60. 2002 CRV-2.4
  61. 2023 CRV EX-L Bluetooth Contact Paring Issues
  62. 2023 CRV EX-L Updates to System Drain Battery, TSB?
  63. Is this piston still useable?
  64. Is Carfax trustworthy, ergo 100% accurate ? . . . if
  65. Did any crv's have power seats
  66. 2008 CRV cranks slow but starts.
  67. Rear brake drums
  68. gen3 07-11 crv ecu mods
  69. Possible cr-v purchase, got Qs:
  70. engine type dilemma
  71. Rd1 crv woodruff keys
  72. NWB Wiper Blades
  73. 2007 CR-V Power Steering Pump
  74. 1997 CRV Master Cylinder w/ABS Info
  75. 2007 Honda CRV With a Crank no Start
  76. Compatible heads for 2014 CRV
  77. USB Unsupported Error Message
  78. B16 V-TEC Head Swap
  79. neutral safety switch
  80. Looking for 2008 CRV floor jack
  81. 97-2001 CRV with Awd. How reliable are they?
  82. P2228 BARO sensor low voltage and open in ground wire
  83. My key won’t turn on ignition. Witch is bad my key or ignition
  84. 2002 crv crank no start(Fuel pump and spark working)
  85. 2001 crv whistling sound at udle
  86. 03 Honda CRV Engine Vibration
  87. Transmission sounds like it is slipping or racing?
  88. Looking for Tester for CR-V Security System Product
  89. Now bubbling 1st gen CRV.
  90. Should I buy
  91. GUIDANCE NEEDED! Timing Chain Slip. Oopsy-dasiy!
  92. Sudden Jump In Temp & Shutoff At Idle
  93. need help
  94. Misfires/Need Help
  95. Power steering sensor problem after changing coolant
  96. 2003 CRV EX Auto 268k driving issues
  97. 2020 HONDA CRV A/C DISCHARGE LINE LEAK
  98. Honda crv 2.2 i-dtec poor start-up
  99. AC Compressor Problems- Leaky Shaft Seal
  100. 2012 CR-V Keyfob reprogram
  101. Reverse Left The Chat
  102. Crv 2023 pdc problem
  103. Engine Sound Loud? 2019 CRV
  104. Few issues with a 2010 crv 4wd
  105. How serious is a timing chain issue due to low oil?
  106. touch screen not working
  107. MDLA trans swop with S4TA in 1999 Honda crv
  108. Honda CRV 2001 - 2006 HVAC controls US vs JMD
  109. 2016 CRV Trans plug wires
  110. EGR and EVAP readiness codes won't reset
  111. Scanner
  112. CVT fluid level check steps
  113. Emissions fail after battery replaced.....
  114. Need Advice On 2002 CR-V Starter Or Starter Relay
  115. 02 CRV p1078 code still popping up
  116. Diagnostic advice
  117. Usdm PCM in JDM Honda crv 2007 k24 engine
  118. 2007 CRV 2.2 diesel (N22A) Camshaft position sensor location?
  119. Do you change 0w-20 to 5w-20 as mileage go's up
  120. JDM 2005 CR-V Brake Parts
  121. 2012 CRV cabin smell when accelerating up hills
  122. 06 CRV Power Window - Ground Fault?
  123. 02 CRV p1078 codes persistent
  124. Brake Fluid change period?
  125. 2000 Honda CR-V is it possible to install a digital instrument cluster?
  126. CR-V cranking issue
  127. P0497 solved - unobtainium part
  128. 98 CR-V Transmission questions
  129. 97 CRV Diff question
  130. 2004 and 2005 use same rear driveshaft?
  131. Vtec & limp mode
  132. SUSPENSION PLEASE HELP
  133. 2007 CR-V Sluggish
  134. Replacing a serpentine belt in a CR-V or Civic
  135. Need help Chirp noise from valve train noisy
  136. Distance Radar Sensor on Honda CRV Hybrid 2024
  137. 2002 CR-V Need Advice On Sunroof Maintenance
  138. 07 CRV Leaking Trans Fluid
  139. P1399… HELP
  140. 2019 Honda CRV 1.5L engine sound?
  141. CR-V mystery howling
  142. 2002 JDM swapped Honda-CR-V I-vtec troubleshooting
  143. Front Wheel Bearing Installation
  144. Propellar shaft vibration after install
  145. 0W-20 temperature range
  146. Help - changing guage cluster with extra complication?ns
  147. 2002 CR-V: Need Advice On Thermostat Replacement
  148. Online Parts
  149. 2007 CRV EXL need parking brake help
  150. Dash Cam Recommendations
  151. 2009 Honda Cr-v AC
  152. High mileage Element purchase ?
  153. 2010 crv bad year for aftermarket parts. Help
  154. Crankshaft position sensor
  155. 2005 crv rear turn signal issue
  156. Gen 1 Steering wheel swap
  157. P1259 VTEC Malfunction - voltage problem CRV 2 2002
  158. 2008 CRV battery dead, faint ticking noise
  159. Idling issue
  160. Gas milage hybrid
  161. Clutch issues 98 CRV
  162. 2005 CRV power steering issue…
  163. Rear beam, rear suspension cross
  164. Maimaintenance Light Reset
  165. 25 CRV EXL AWD exhaust pipe noise
  166. filter confusion
  167. Honda CRV Hybrd 2023 remote start not working when temp below -10°C
  168. 09 CRV LX Car Troubles (Detailed Post)
  169. Manually Engage A/C Clutch?
  170. 06 CR-V Crank no start
  171. 97 crv auto to manual swap no start
  172. 05 CRV P0685
  173. Motor RPM (CVT) rises abt +500 rpm without reason
  174. 06' CR-V Tire Switch with 04' Cr-V
  175. RD3 Engines B20Z2 vs B20Z1
  176. Element Stalling issue
  177. 2007 CR-V belt tensioner
  178. 1999 honda crv M/T differential
  179. 2004 Honda CR-V Serpentine Belt Melted
  180. 1999 crv crank sensor test?
  181. Speedometer Needle
  182. 05 element trans went from shift flare to dead
  183. 2001 Honda crv dizzy issue
  184. [SOLVED] 1998 honda cr-v pulling to the right when coasting
  185. 1999 CRV Transmission
  186. Looking for throttle bodies
  187. D LOCK ON SCREEN CAR TURN ON BUT DONT WANNA START ENGINE
  188. Honda CR-V Shudder/Lurch when 70mph sustained
  189. Replaced crankshaft seal and now an engine misfire
  190. Shifting problems
  191. Do all K24 leak oil from pressure sensor?
  192. Power Window Issues
  193. K24Z6 - what are my options?
  194. Straight piped ‘07 CRV running rich
  195. 2011 Honda crv P0304 misfire code
  196. 2000 Honda CRV won’t stay running
  197. Oil leak near alternator and oil pan on 1st gen CR-V
  198. 04 CRV flashing D and CEL
  199. Shake under load
  200. Low compression and misfire, blinking check engine light
  201. 2000 CR-V Valves
  202. 04 CRV Auto to manual Conversion
  203. Black Soot in engine bay
  204. Oil low after change
  205. 2002 CR-V window control
  206. CRV Coolant Low after 7k Miles? Or Fine?
  207. Collapsed PCV Valve hose
  208. CR-V upgrade
  209. RD1 AC and Wiring Tuck
  210. What the heck is this thing under my dash?
  211. 99 crv new engine, cranks no start HELP!
  212. 2001 Honda CRV SE - Starter Replacement Help (Airbox Removal)
  213. 2008 CRV Ac condenser fan won’t turn off
  214. Earth Ground G202 Location
  215. 99 CRV A/T - M/T swap issues!
  216. 2011 CRV start up rattle
  217. Need Advice On 2002 CR-V Oil Leak
  218. Mysterious oil leak above oil pan - cam shaft seal? Or something else?
  219. Has anyone seen this before? CRV bent idler pulley
  220. 2005-06 Honda CR-V RBC & ZDX Throttle body?
  221. Will an EF Civic Pedal box Fit an RD1 CR-V?
  222. Ignition won’t turn all the way to off
  223. 2008 CR-V EX-L:: What is this at the top, center-ish of my rear window?
  224. 2014 CRV LX auto dimming mirror add on
  225. Pgm-fi fault code
  226. 2004 CRV MT AWD to FWD conversion questions
  227. Entire Transmission Replacement or Just Speed Sensor?
  228. 2016 CR-V gas gauge acting funny
  229. 2004 CRV - RPM Dropout while in park after driving
  230. Knock sensor code issue
  231. Tranny vibration years
  232. Element engine revs varying problem - need help to diagnose
  233. Power for running lights on CRV
  234. 2000 CRV - No Start - Odd Injection Issue
  235. Element rear disk brake conversion?
  236. B20z1 and B20z2 swap
  237. Gathers VRU 195cvi language and map issue
  238. Flashing Drive light 2004 CRV
  239. 2004 Element SRS wiring / pinout
  240. Driving S mode regularly. Honda CR-V 5, 2018, 2,4L, AWD, CVT.
  241. CR-V RD2 (manual) clutch mystery
  242. 2007 CR-V rear diff shudder
  243. 2008 Honda CRV - Rear Differential Leak?
  244. About to give up on this car, any suggestions?
  245. Finding Part No
  246. High RPM on Start - 2009 Honda CR-V
  247. 05 CRV tranny swap: GPPA (UK) with MKZA (JDM) [ Transmission experts, please help ? ]
  248. CRV 2003 - ABS + SRS + Handbrake + Battery light came on
  249. 01 CRV Spark, Fuel, No Start after Timing Belt
  250. Intermittent VSA light comes on
