View Full Version : Honda CR-V & Element
- ipod on a factory stereo
- '01 CRV Service Manual
- lost my honda crv 2005 key in the mail.
- 2001 CRV trans/torque converter issue
- Does anyone have the OBX exhaust for 97-01 CRV? How Loud is it?
- 03 CRV Need advice on replacing starter
- whats's that noise from your car?Please share your views..
- 00 CR-V 1st gen (auto) vinyvolingy
- auto b20 turbo
- Can you fix this?? CHeap? ideas! :D
- MY ELEMENT NEEDS MORE HP!
- CR-V Software update
- Transmission Fluid
- 97 crv warm start drag
- sticking ignition lock cylinder
- crv starts slow
- CRV JDM B20B swap **Potentially retard question**
- TPS Problem: 2003 CRV EX MT
- 1998 crv starter replace
- 2007-2011 CRV canadian tire sizes
- 2005 honda crv
- B20V 97-01 CRV owners...what ECU are you running??
- New Better Fit Ujoints
- CRV Tire Alignment?
- 2001 CRV tailgate lift strut
- 97 CR-V Crank/harmonic balancer pulley Replacements?
- 2012 CRV Concept Wheels
- Drivability Problem... HELP!!
- 1999 CR-V front axle issue--need advise [photos included]
- Struts/Ball Joints
- 2001 CR-V in tank fuel pump and sending unit
- Crv HELP!
- 2002 CRV EX ABS problem
- '02 CR-V will not start, rapid clicking noise instead
- project Bugout build thread! Lifted Boosted 99 CR-V
- Does anyone know which lip kit this V is running?
- Stock B20 VTEC Compression Results
- 98 awd crv transmission questions
- Strange bump when I shift from reverse to drive
- Got this 1997 crv couple of weeks ago is this possible b20z2
- CRV/ELEMENT TRANSMISSION CASE
- vtec oil pressure switch
- DC2 Integra upper exhaust manifold mated to crv downpipe!
- Civic Front knuckle on rd1-2??
- girlfiends element
- 2013 Honda CR-V EX-L 4X4 with Nav
- 97 CRV trans question... or swap
- Simple question about B20Z intake manifold?
- 17" x 10 rims...
- 2006 Honda CRV - Start Up Problems
- 2002 CRV MAJOR A/C problems, please help !
- 2013 CRV EXL-L with Navi
- Crv gsr hard cold start/ code 17
- aahhh first gen crv header question
- 2003 Element engine swap?
- 2003 CRV Check Engine Light blinks at idle
- Plz Help
- Converting from AWD to fwd
- sway bar quetion
- 2010 ATF level question????
- oem roof rack
- Calling all swap gurus ~ Swapped b20z to b20b
- 2002 CRV LX - Intermittent issues
- *B20 Vtec Automatic? tuneable? hmm
- CR-V Air/Fuel Gauge Help
- 2003 CRV Owner's Manual
- 1st Gen CR-V Coilover suggestions?
- catalytic converter
- 1998 CRV harsh tranny shift from 1st to 2nd gear (auto)
- DC5-R front lca
- HELP! 2001 Crv lx 5MT 4WD very low idle and loss of power in low rpm rage.
- First Gen Gauge Mounting Ideas
- just got a second gen crv blank canvas need ideas
- weak spark
- After a cabin filter update, choking???
- Condenser Fan making terrible noise
- 4wd Transmission swap.
- 2000 crv awd ls/vtec ecu help
- Installed my aluminum dual core civic radiator into my V
- License plate screw holes
- Will 2009 Acura TL Rims (17") Fit a 2003 CRV?
- Off Like A Herd Off Turtles Project
- Key Questions
- CR-V GSR Swap questions.
- can i do this?
- My CRV restore build
- Will this tire/wheel combo fit?
- seabee10
- 97 crv.. problem! :( ....... is it tranny fluid or oil leak?
- Part# for 97-01 Input shaft bearings(inner/outer) and seals
- '99 CR-V timing belt: miles vs. years
- 2013 CRV equipped with HID headlights?
- New to me CR-V
- 03 CR-V climate lights
- 04 crv--I think I fried the ecu
- CRV Problems?
- 2007 CRV antenna.
- squeeling belt wobley crank pulley
- AWD EX 5-Speed w/ Auto Cluster
- Need opinions on bushings
- Wife's CRV power issues
- Anyone add a remote starter
- Valve Cover Spark Plug Seals trouble
- Having an strange issue with my 06 2wd element.... help
- Roof cargo basket help
- Swap For A Crv ! Need Help Advice
- Car won't start
- 6th Gear 2nd Gen CRV
- front axles
- 01 CRV Transmission Slipping from stop
- Honda CR-V hatch Measurements
- Air bag light because of seatbelt ?
- SRS Light/faulty buckle - HELP!
- How do you pull codes?
- WTH!! All my doors and trunk locks not working?!?!?
- Whining noise from front end
- Electrical gremlin
- 2002 CR-V Air Conditioing Pending Failure
- Anyone have a dual core CIVIC radiator in their 'V'?
- How to how to order B series oem bearings need some help
- Need some K23a1 answers
- HELP: brakes not working
- strange noise when turning
- grinding/scraping noise when making u-turn
- upper ball joints
- Going to purchase a 2007 CPO CRV, can I get a price check?
- Has anyone ever thought about swapping in the K20/24 in a 97-01 CRV?
- NY 1997 honda crv my lil project !
- installing arp head studs
- 2006 Honda CRV coughing and sputtering
- Honda CRV AC troubleshooting
- CRV Transmission change help
- 07 crv hot rear brakes
- Looking to buy a cr-v
- snow driving
- driveshaft bad.
- New 2009 CR-V AWD owner...what fun can I have with this thing? mods?
- B20B programm
- My lifted crv.
- Largest tires on 97-01 CRVs for 17" & 18" rims?
- 2002 Honda CRV Leaking Break Fluid
- 2003 cr-v wibration/shaking
- crv electrical problem
- b20 build...new rings? or ycp high compression pistons?
- Just bought a 2004 CRV... should I worry about the AC blowing up?
- 01' CRV Dizzy Igniter
- 2004 CRV Build - taming the torque?
- 2001 CRV Air Conditioner Issue
- Cannt Start 2002 CRV (AWD)
- arp head stud part number
- Buying 2001 CR-V B20Z1 any weaknesses?
- Dipstick on a 2002 crv 5 speed
- seat belts locked up
- 2004 Honda CRV Engine missing.. PLZ HELP
- My New Toy but need experts!!
- Problems with 99 UK CRV auto
- JDM/EDM 1st Gen CRV Front Bumper
- 01 crv flashing CEL.
- 1st gen Crv Traction Bars
- AC blower stopped working
- Import Fest 2012
- Boosted first gen questions...
- defroster stopped doing job; AC long gone
- 09 CRV A/C weird problem, please help!
- Can I safely remove these bolts?
- Fixed one issue...another one arises
- 1st Gen CRV Main Relay Question....
- 01' CRV stalling out.........HELP!!!
- Crv dome light issues....
- Recommendations on after market front/rear sway?
- 2002 CRV alarm
- converter heat shield
- crv "pulling" to the left when coasting?
- 2001 CRV Alarm went off while Driving, now Car wont start!!! HELP
- Picking Up a 5-speed CR-V Today...Choice Between Two
- wonky idle...replaced IdleAirControl already...what else to look for?
- 2002 CRV overheating
- 2008 CRV ABS Rear Wheel Sensor Interchangeable
- jdm???
- ac compressor
- Best tools for working on Ball Joints and U Joints?
- off topic - meets, whats up, when, where, why, all about our CRVs!!
- What size tire and wheel for my 2003 Honda CR-V?
- Just bought my first CRV!
- will a vsa modulator from an lx model fit on my 05 ex model?
- My Daily driven Cr-V
- Distributor cap bolt snapped D:
- 1999 crv trans swap
- Shutter/Vibrations from 10-20 mph
- Anybody tint their own windows on CR-V?
- Thinking about getting a 99 CRV 4wd
- OEM 94-01 Integra Springs + 97-01 CRV Struts?
- Any1 have a V with 18" wheels & dropped?
- Element Won't Stop Squeaking
- distributor rotor splined
- Overtorqued Self Locking Nut on Damper Shaft
- Cold start knock 2000 Gen 1 CRV
- Weight of 97-01 CRV alloy wheels
- 2013 Escape, would you buy?
- DC5 Type R Rims on Gen 1 CRV
- CRV Rear wheel frozen
- My channeled 97 crv. need some advice.
- Need a help about the compression test
- Window Visors 97-01
- Coilover Lift
- Prop Shaft Removal
- im having some engine issues with my new crv need help
- 1998 CRV won't turn off!!
- JDM 4WD transmission swap-able?
- Rear Foglight
- Anybody know anything about this red/gold GSR CRV?
- 2012 CR-V door latch recall
- Help on my suspenion setup.
- 2001 CR-V Has Child Seat Anchors, but Retrofit to 97-00?
- front bar??
- What is this thingy do a ma hickey!
- Accord suspension on crv
- 01' CRV having a hard time starting
- moded a hytec tri y for awd crv
- CO671's 1998 CRV
- Towing with my 1999 Lx 5spd questions...
- Propeller Shaft? '98 CRV
- shift solenoid 2005 CRV
- 1st gen auto trans issues
- 03 Honda CR-V door locks stopped working?
- PICS OF MY "V"
- 07' Element SC 5spd Manual Leaking Input Shaft(s)
- Shocks for V
- what can your crv tow?
- 04 CR-V
- 05 CRV a/c questions
- 2004 CRV P0135 code
- blinking cel
- Where to Buy Transmission Syncros?
- how bad of a wreck
- 0W-20 and warranty
- 2006 honda element with 2007 head lights
- New Tranny oil?
- 2002 crv dies right after start
- B20 not firing on all cylinders.
- Recovery Points
- will b18 ls distributor fit b20 harness
- Headlight Lens cleaning
- 97 cr-v engine problems
- whats the easy way?
- new crv owner gots questions. and tintered vs stock crv difference
- How to: 97 01 crv 5 speed conversion
- b20b blox intake manifold install HELP
- 1st gen Crv, bigger tire question.
- A/C problems- pressure too high.
