View Full Version : Honda CR-V & Element
- 2017 CRV alignment issues
- 2012 CRV All interior lights have stopped working
- anybody ever try to replace JUST the sensor on the Accel Pedal positiion switch?
- 2014 CRV timing
- Need Advice On Bleeding 2002 CR-V Clutch Cylinder
- 07 Element intermittent spark, crank/no start
- Priming time on 2010 CRV
- Went to three mechanics/got inspection- still having 2005 CRV SE issues. Please read
- Car shakes when braking at high speeds
- 05 crv automatic transmission issues
- 2024 CRV Hybrid - Jump pack
- 2001 CR-V -- Removing torque mount, cage nut broke inside frame... options?
- 2001 Honda CRV - Dash Lighting LED Re-engineering project
- 2015 Honda CRV hands free / Bluetooth
- Strange AC expander/evaporator sounds?
- 2001 honda crv sputters
- P0335 code after changing dist cap/rotor/sparkplug wires 2001 CR-V
- Intermediate shaft Installation Issue
- engine light on dashboard will not go away
- Immobilizer loses code cycle battery works great
- HELP PLEASE
- Problems with Timing Belt Install
- 1st gen CRV Need help getting JDM bumper on
- 2005 Element P0507 idle high
- CRV start problem
- Crv ac cycles
- Honda Crv 1998 300HP overheating problem.
- 2010 Honda CRV will not start and cluster blacked out
- 99 crv turning over but not starting
- turning problem at times
- 2001 CRV Misfires and high idle (multiple codes)
- Rear tires wear off on the inside
- Power to mirror 23 crv exl
- Honda CR-V Intermittent Starting problem
- CRV engine light on and went into limp mode, codes 1298 1279
- No oil in the middle of oil filter. is it normal?
- Recall 2011 CRV is their bad "fix" gonna cause problems
- CRV Turns Over but Slow to Start
- Crv 1999 automatic transmission problem
- p0303
- 99 crv timing belt snapped
- Transmission speed sensor scratching..
- 2000 rd1 crv manual transmission swap
- 08 CRV Engine Swap Problems
- Need Advice On 2002 CR-V Trailer Hitch
- The P1157 extended cut
- 2003 CRV harmonic balancer bolt
- CRV error messages
- 2014 CRV - P303 - bad valve seals?
- 1998 CR-V failed smog test. Smokes.
- A/C Vent making noise
- 05 crv headlights wont stay on
- I killed it Help!!!
- Removing heater / fan / blower knobs 1997-2001 RD1 CRV?
- Honda CR-V 1997 engine start problem
- 2011 CRV 4wd axle
- Can a 2008 honda crv use a 2002-2006 k24a1 motor?
- 01’ CRV Front Upper Control Arms/Rear Drums
- Needing 1st Gen EBP Fender, Hood
- 1st Gen CRV - Best spot to mount USB chargers?
- 2002 Honda CR-V Luggage Rack Question
- Can I Solder In Pigtail Or Should I Depin This Plug?
- RD1 CR-V Swaybar
- Fuse 29 Parasitic Draw 2015 CRV Battery slowly Dies
- 2004 CR-V Interior Lights Don't Come On
- 04 crv tcm faults after engine swap
- 2006 CRV P2647
- Factory wiring harness
- CRV Mk4 2013 2.2 idtec
- 2001 CR-V rough idle and loss of power
- 2003 CRV Front strut / shocks assembly rebuilding
- 2000 CR-V: Upper control arm ball joint taper overworn
- 2009 Crv idle surge… (took to dealer) need advice.
- 1998 b20b4 5mt awd acceleration hesitation
- Need Advice On Coolant Leak
- 2004 crv..Dreaded Knock sensor code
- CRV ECU HELP
- Gear indicators not lighting properly
- 1997 CRV AWD rim sizes???
- 2000 Crv RT4WD Driver side door not working
- 2000 crv wants to start but wont
- No More Cruise Control.
- Need Advice On 2002 Honda CR-V Splash Guards
- can used remote fobs be reprogrammed?
- 2019 CRV Side Mirror Replacement Assembly
- 2002 CR-V Lower Ball Joints: Do I Have To Buy The Knuckle?
- cv axle popping out
- 2000 Honda CR-V AWD max tire size
- Stops accelerating Help Please
- "Limp Mode" on '09 CR-V 4WD K24Z1 After Hauling Butt
- pull to right when starting to move
- CR-V shifting weirdly...
- B20B motor
- good replacement struts for 99 CRV
- 2008 crv rear brake issue
- 2018 CR-V Completely Dead Electrical Sysytem
- controllable diff in a CRV
- Memory saver / changing battery
- window motor assembly
- Dropped in new motor.
- 2018 CRV EX Gas tank hoses question
- How to reattach the roof antenna on a 2015 CR-V?
- B20B with LS Trans
- Honda 2004 gen 2 Instrument Cluster
- 1.5 turbo Oil Dillution
- 2002 Crv Starts then dies right after
- Driver door door lock
- Door AJAR when pushing
- Aftermarket Piston Rings shaped differently than OEM
- Engine stays on cold with new thermostat
- okay to weld?
- New Member - 2023 Touring Hybrid
- 08 Cr-v shuts off while driving.
- SRS light
- Change 2016 CRV Date
- Is this WELD job ok?
- headlight relay for 2013 CRV?
- New to the team. 1996 JDM Honda CRV
- Happy New Year, wish all a great 2023 !!!
- Intermittent Non Start issue 2001 CRV
- New Crv and Honda link
- 2005 CR-V pull to left and small thud when off gas
- CRV04 Can someone tell me what part this is?
- 2014 CRV heater blowing cold on passenger side
- 2006 Element P2646
- 2000 CR-V exhaust
- 2015 CRV FWD CVT Check Bolt
- How to: Element backup lights as loading lights w/ rear hatch
- How to: Element spot/map lights as dome lights
- Resetting PCM
- Transmission oil change cost
- 2005 CR-V SE - lights in instrument cluster
- Honda CRV parasitic draw test
- Can no fuel cause CR-V to not click or crank or start?
- 2002 CR-V Oil Viscosity: 5W-30 or 5W-20
- Issues with Transmission Range sensor (Neutral Safety Switch) after JDM trans swap
- Replacing Under Cover Assembly
- Building my 2nd Gen crv
- Honda problem
- Cost for 15K service on 2019 CRV?
- B20b4 A/C To Super charger swap
- 02 ceb battery light on
- Wheel spacers and the Hub-centric vs Lug-centric debate
- Dim headlights in CRV 2005
- CRV b20B basemap?
- 08 CRV FWD Whine under acceleration after starter replacement
- Oil Dilution Issue - Still a problem? How about the Hybrid?
- 2005 Honda CRV Tail gate Adjustment HELP
- Clutch won't disengage!
- need more HP on CR-V gen 1 with auto tranny
- 2nd gen CRV O2 Sensor USDM vs JDM
- body Control Module for 2007 honda CRV
- Removed & Replaced Driver's Seat Belt - Now SRS Light Is On
- HD Radio on 2016 Honda CR-V EX-L
- 2003 Honda CRV Clunking when in D
- 2019 CRV Climate Control
- CRV (2003) MT Dragging when decelerating
- 00 CRV no crank, main relay clicks, gear indicator illuminates D
- 97 CRV AC Issues
- Element Rear Suspension Loud Creaking/Popping Sound When Backing Up or Going Forward
- Need Help for 3rd Gen CR-V Suspension and Brake Upgrade
- 2013 CR-V Shudder issue
- adding rev lock out solenoid on rd2 (02-06)
- 01 CRV Big Brake Kit
- 2001 crv transmission stuck in reverse
- 2012 CRV wire schematic to NOx sensor
- 2018 Honda CR-V Touring Edition (104,000 miles)
- 2020 CRV Electrical problem
- 2016 CRV Undercarriage
- 2000 CRV Blowing Cluster Fuze
- 1998 Honda CR-V a/c headache HELP NEEDED
- 2006 CRV Leaking Coolant at the head gasket?
- HONDA CR-V HELP!!!
- 2010 EX-L Requesting Troubleshooting Assistance
- RD1 B20Z swap/wiring question
- 2007 CR-V navigation installation questions
- Car died - how to sell for parts
- Replacement suspension parts for RD1.
- 2016 Honda CRV - code P0087 - won't get past 2500rpms
- 2000 Honda CR-V Stuck at 1400rpm when first starting.
- First Gen CRV ABS Codes
- Death wobble sometimes at higher speeds
- evaporative leak pump running 5 hrs after parking
- 2001 CR-V Vibration High Speeds - I've Replaced Everything
- Reliable 1st gen CR-V coilovers for long-term use
- Seat belt loop on driver's side in '21 CR-V
- Keeps trying to regen
- Honda CR-V 2.0 2002 intake leak
- Honda crv ( won’t start)
- Break Fluids interval
- 2016 ABS Code after wheel bearing
- Small traffic icon
- 2004 Honda CR-V Catalytic Converter Stolen
- How to videos
- 2014 Honda CRV struts and springs
- 2006 Honda CRV headlight wire
- Removed Drivers Seat - Now SRS Light Is On
- 2007 CR-V aftermarket headrests that won't push your head forward?
- 2003 Element / gauges not working
- Clutch Safety Switch
- Can you Supercharge a 2011 CRV EX-L?
- Removing engine only
- Best RELIABLE coilovers for 1st gen CR-V?
- Reverse lights don't work
- Wheel bearing issues after mechanic replaced Steering rack and Pinon
- Found Ford trim on Honda CRV
- 97 Honda CRV no mechanic can solve
- 2005 CRV Engine/transmission swap?
- 2002 crv oherheating
- Lifted Honda CR-V 2005 project, my first lifted car for hunting
- Rear suspension overhaul CrV-rd1
- What are your thought about this 01 crv build??
- 2006 crv abs issues
- Cam Cap Arrow
- Honda Cr-v 2008, 2.4 engine with LPG
- 04 CRV TPS ISSUE!Please help
- UNL88 fuel
- Recommended 1st gen CR-V coilovers? Current ones rub tires
- ECU Rewrite program (where to find)
- CRV AC clutch knocks when disengaged
- 2006 CR-V Auto Trans. Fluid Change Advice...to fix shudder
- '08 CR-V Instrument Cluster-Digital Display Issue
- Seatbelt disconnects airbags !
- CRV advice
- 2004 CR-V Battery Light Will NOT Turn off
- 2015 CRV -- FUSE 29/ Hood Latch wire connects to ??
- CRV - Struggles to start!
- Do I Need New Engine Mounts? 2000 CR-V 2WD
- K-Tuned immobilizer bypass A/C not working
- Ac is leaking
- Help me find wiring diagram for my navigation unit?
- engine torque mount torn
- k24z6 (2012 crv) head swap options
- Crv with swapped b18b1 won’t start only crank
- 2010 Honda CRV Engine light came on after AC compressor replaced. (also longer crank
- Tranny issues. Throwing lots of codes
- 1999 EX AWD 5MT no crank
- 2007 CRV AC questions
- 06 Crv -doesnt always start & t.c. hill problem?
- I/M readiness greenlight still throwing code '06 crv se
- CRV 2.0 won’t start
- 2009 CRV No lower brake lights, but top center good
- Brakes have NO pressure after sitting for 6 months
- Lowering a 1st gen, what strut?
- Deer took out the wiring harness
- First Gen wheel thread.
- Upgraded 12-hole injectors
- Will not start
- 2000 crv Driver (left) front power window common ground
- ECON causes jerking?
