PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24
  1. 2005 CRV shudders on sharp turns
  2. 1998 Honda CR-V LX Won't Start
  3. 2000 CR-V CEL Service Connector
  4. Element Break-in
  5. new rims, suspension and bumper
  6. Horrible idle on 2000 crv IACV screen broken with Video
  7. 2003 element green aux plug wire colors and job they serve
  8. Sam's new rare '98 CR-V
  9. CRV died on the road. Help?
  10. mileage
  11. eg hatch duckbill fits pretty good on 1st gen crv
  12. Total brake replacement
  13. just picked up my first crv.
  14. ABS help please?
  15. Honda CR-V Transmission Fluid Recommendations
  16. Cold Air Intake - Yes or No?
  17. 2002 Honda CRV w/ 2006 Si rims
  18. Ideas for my 98 Crv to look better!
  19. replacing blower resistor 2002 crv
  20. 98 Crv AWD 5sp small project for now
  21. 98 CR-V just got released from impound after a year and a half..
  22. 2008-2010 CRV Info
  23. Any info on this Red CRv with a Swap on TL Type S wheels Slammed
  24. Where is bank 1 sensor 1? Got code P0131 for an 02 low V
  25. 02+ crv seating capacity
  26. Need help pickin wheels for my CR-V
  27. Which is a better deal: Compare 1 used vs 1 Certified Pre-Owned
  28. Cr-v Intercooler piping
  29. low mileage engines from ebay
  30. Strange overdrive issues and A/C
  31. 02-06 crv master switch issue?
  32. 2nd Gen CRV Mileage query
  33. how do you replace the idle control valve on an 05 element
  34. 18's for gen 3
  35. CRV ISSUES NEED FIX NOW!!!!!!!!!!!
  36. 1st gen CRV bug deflector options
  37. '97 CRV won't start after rad/thermo replacement
  38. Automatic AWD to 5 speed AWD HELP
  39. timing belt valves maintenance
  40. Radio install question answers please...
  41. location of vtec oil pressure switch on 2003 crv
  42. Element KPRO
  43. Honda CR-V no auto headlights off
  44. trans shift kit ?
  45. 98 CRV Burnt Valves
  46. JDM B20 bogs/sluggish under 3000rpm
  47. 2000 crv lx intake sensor quieston
  48. My 2000 GSR'd 5 speed AWD CRV build
  49. Will Acura RSX rims fit on my 2001 CR-V
  50. 2000 CR-V Drum Brake Noise
  51. help asap 99 crv 5spd 4wd
  52. can i do a b20v in my 99 crv
  53. 2010 CRV Air Filter
  54. ECU Mystery
  55. 99 CRV.
  56. What is this rubber?
  57. HELP b20 problem
  58. Which Portable Car DVD Player Should i Select?
  59. First Gen Cr-V Slammed on RSX Type S Wheels
  60. ECU Problem!
  61. 2 gen CRV, how do you program auto lock feature???
  62. New to Fourm kinda taking a step down...
  63. 98 CRV immobilizer or bad ECU?
  64. European CR-V 1998 ES
  65. EXTREME Gasoline Fumes when air temps exceed around 70 degrees
  66. Suspension Info.
  67. Clunk in rear when brake is depressed Honda CRV 2003
  68. CR-V Motor Swap and 5-spd conversion
  69. Ac repair and engine issues
  70. 99 CRV tranny USDM to JDM????????
  71. 2005 honda crv, honda won't honor warranty
  72. 98 crv 5spd
  73. P1381 on a 1997 CRV
  74. Interested in bumper protectors seen in the UK
  75. Any success with HID lights ?
  76. Wheels and Tires
  77. JDM parts access
  78. Researching CRV
  79. 2011 CRV Bumper Protector?
  80. Loosing coolant
  81. Engine mounts
  82. 07-11 crv cd player question. Please help.
  83. 245/45/17 tire on a lowered CR-V ??
  84. I THINK I NEED A LAWYER??????
  85. 02 CRV K20 ecu showing p0341, HELP!!
  86. new intake
  87. 2008 Honda CRV A/C compressor change.
  88. 2008 crv radio in a del sol
  89. Ideas for upping towing capacity (08 Element EX)
  90. Honda CRV 2000 bolt pattern?
  91. would someone help me locate the starter on '03 element?
  92. Did some light off-roading with my CRV...(pics to come)
  93. Shut Off Navigation System
  94. 2001 CRV Stereo issues
  95. Honda Diagnostic System (HDS) Software???
  96. After market keyless entry on Honda element 2003
  97. Whats a good price for a 2011 CRV?
  98. vibration at idle
  99. JUST GOT A 08 element SC 5speed
  100. Idle Issues - please help!
  101. 2001 motor mount question
  102. Westin Safari Bar Installation
  103. 2000 cr-v throwing p0131/p0171 codes
  104. Element Throttle Body letter to Honda
  105. how to do timing belt
  106. Crank pulley removal tricks
  107. crv edm bumper ?
  108. anyone want a pair of 1st gen running boards?
  109. b20b headgasket and headbolts ????
  110. 3rd gen V economy mods
  111. CR-V just died on the wife.
  112. 97 honda crv? for parts!!
  113. My new 98 5spd CRV EX AWD
  114. Vibration in P and R but not D4
  115. 2007 CRV - Reset Airbag (SRS) Module after wreck
  116. This VW would be a good Element
  117. mods you did in your CRV gen 3
  118. biggest tire fitment on 15x7 wheels?
  119. CRV front issues
  120. New Honda owner introduction
  121. Element Transmission Swap
  122. my 2000 crv ex build
  123. NEED HELP !! swap k24a2 (tsx) in 02 crv
  124. Element parts
  125. Brake light off help
  126. CV Axle stuck need suggestions
  127. CRV with an H2B
  128. Warning Light
  129. 98 crv clock
  130. anyone here took theyre mud flaps off? 1st gen crv
  131. 2008 honda cr-v gps update
  132. 2008 cr-v HID bulb question
  133. 1997 CRV CEL
  134. Rear Disc Brake Upgrade-Gen1
  135. GSR engine swap, Manual CR-V
  136. color codes
  137. where to get oem floor mats 1st gen
  138. A/C noise
  139. HELP!!! ELD, CKS, ECM/PCM, Coil - No Spark
  140. 2003 honda crv obd2 question code error 1167
  141. 1998 2WD CRV Transmission Problems
  142. Honda CRV towing trailers
  143. 2nd gen rear upper control arm
  144. one piece coilover 1st gen crv?
  145. 98 crv front suspension noise
  146. Project “Daddy Wagon” 99 CRV daily driver build -56k no way
  147. 98 crv
  148. 02-06 Crv Strut Bar?? What fits? From what car??
  149. crv taking time to warm up
  150. Honda crv water leak inside?
  151. Few questions about the 1st gen CRV
  152. IAC valve 98 CRV
  153. 4-bolt to 5-bolt conversion on CR-V
  154. '98 Honda CRV problems - please help!
  155. Will fully synthetic engine oil damage my CRV's engine?
  156. Element ?s
  157. Intermittent front end vibration 2005 CRV
  158. 2004 Element ABS 81-1
  159. Sunroof Exploded!
  160. Sunroof Explosed!
  161. 03 cr v lower in the back
  162. Element Transfer case gearing/ rear gearing
  163. Crv Civic suspension compatibility?
  164. Where is the camshaft positioning sensor ?!?!
  165. crv factory alarm
  166. Error Code p1399pd for 2000 CRV
  167. Help honda CRV engine feels slugish low rpms and about 3k etc. higher smooth?
  168. 2000 Cr-V SE on RSX-Type S wheels
  169. 97 crv oil pan gasket
  170. crv transmission gen.1
  171. TURBO JDM lsvtec B20 swap. Experience?
  172. Serviced my CR-V
  173. What is the best way to go about lowering an '06 Element?
  174. 4x4 Convertion to 2WD?
  175. electrical issues on 97 crv.
  176. Supercharge CRV
  177. 2001 crv se on 18'
  178. 04 crv awd roar in right front wheel
  179. 1st gen dropped on TL TYPE S 18"
  180. 245/40-18s on a 1st gen
  181. 97 CRV problems?
  182. Need help 98 CRv 4x4 Tranny
  183. how long are the orginal spark plugs good for on a 03 crv
  184. Remove Scotchgard White Residue from Interior
  185. 1998 crv rebuild..... need some opinions
  186. maintance required light, how to remove it
  187. 05 tranny problems
  188. Is Dent Protection Worth It?
  189. Headlight Chime
  190. 02 sensor code p0141 seconary sensory light wont go out
  191. Thermostat Question
  192. 1998 CRV annoying CEL Light (P1508)
  193. is it ok to drive with the code p1298 on a o3crv
  194. is it ok to drive with the code p1298
  195. 1998 CRV vs California Smog Test
  196. How much can I sell my 99 CRV for as mechanic special?
  197. HONDA CRV CODE P1298
  198. Keeping the Interior in Good Shape
  199. Keeping the Exterior in Good Shape
  200. Scotchguard on Grey Upholstery. Yah or Nay?
  201. Purchasing Genuine Honda Parts for CR-V
  202. Honda CR-V Add-Ons
  203. Routing power cable in 2011 CRV SE ?
  204. new crv shudders
  205. Pins for lambda?
  206. 2003 Element odometer/tripmeter not illuminated
  207. 01 crv stalls when cold
  208. H22 in CRV?
  209. Problem with blower motor
  210. Overhauled 01' CRV
  211. Coilovers for 09 CRV EX-L 4WD
  212. New guy, first Honda, 1st gen content
  213. crv transmission gen.1
  214. Bumped curb -> wobble, what now?
  215. '01 CR-V Won't Start
  216. 04 Element engine rattle @ 4k RPM
  217. Modifying a 2nd Gen CR-V
  218. NEED A PART NUMBER FOR A 98-01 CRV HELP||
  219. 2000 cr-v will not warm-up!
  220. IMW-Built/Fabbed/Tuned: 390whp/340wtq Honda CR-V of Death
  221. 05 CR-V Headlights go out a lot
  222. 1997 Honda CRV Overheating Issue
  223. can a first gen crv tow?
  224. borrowing my mom's element
  225. 2005 CRV Will not start
  226. 04 cr-v vibration questions need help
  227. Fully Slammed 1st Gen
  228. styrofoam plug on spare tire rim
  229. CRV has no spark!!!!!
  230. adding coolant passed the max line?
  231. 2007 CRV brake performance after pad change
  232. Honda CRV 2007 SRS light is on
  233. Largest tires for 99 crv
  234. compresson check 2001 CR-V
  235. Rear end blues...
  236. Screeching/Grinding Noise - 2009 CR-V
  237. CRV speakers install questions.
  238. '02 CR-V Temp Gauge Issue
  239. Tail light issue need help!
  240. 2001 CRV LCA/Ball Joint/ Wishbone Install Help
  241. sputtering engine - Honda Element
  242. How Do You Propely Remove the Driveshaft on the CRV
  243. 2002 Honda CRV RT-AWD Front Brake Upgrade RSX Type S
  244. Help!! 2003 CRV Evaporator removal
  245. heater not working.... what can it be?
  246. Oxygen sensor diagnosis
  247. 03 CR-V Flasher problem
  248. 99 Honda CRV Maintenance Q's
  249. Help: B20b4 rebuild problems
  250. 2003 Element w/intermittent start problem
