PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24
  1. Good deal on a rare part?
  2. Which cold air intakes are you guys using?
  3. quick b20z/vtec question
  4. Front Bumper License Plate Bracket for 2006 Honda CR-V
  5. b20b to b20z???
  6. Parking lights
  7. 1998 honda crv diagnostic socket uk
  8. Jdm auto climate control/jdm clock/ambient temp sensor
  9. Low RPM/stutter, almost stalling
  10. Differences Between MPG for CR-V's
  11. b18c in crv
  12. 97 crv misfire ????
  13. Struggling to start my crv
  14. 01 CR-V PROJECT
  15. 01 CR-V PROJECT
  16. 2007 (gen 3) CR-V head gasket replacement
  17. "Lights on" Sounder
  18. Can have stagger rims on a 99 crv with the allwheel drive
  19. honda day 2013
  20. Enkei Evo8 wheels
  21. 2001 Honda CRV p0132 code
  22. K24A1 timing chain stretch?
  23. need diagnostic help for 03 element
  24. anyone running H&R sport springs
  25. transmission stays on first gear only
  26. How do you guys dress up the plastics?
  27. My first car ever! (98 CRV)
  28. 01 crv help
  29. first gen crv wing?
  30. Engine diagnostics.
  31. Front Brakes....
  32. Sinking brake pedal
  33. Paranoia Regarding Bosch O2 Sensor
  34. gen2 -V leaking hatch glass - SOLVED
  35. CR-V TYPE R? I HAVE QUESTIONS
  36. 99 upper control arms
  37. price for parts?
  38. 04 crv switch lights do not work
  39. CRV steering wheel
  40. 2004 CR-V thermostat location
  41. Honda Service News
  42. just picked up my first cr-v
  43. 2005 CRV power steering pump
  44. 1998 CRV Squealing sound on start?!
  45. Dummy o2 sensor
  46. ECT on 2002
  47. OFFICIAL: Lets see your CR-V Tables in use Thread!
  48. Light flywheel on the rt4wd
  49. Crv lowering questions
  50. Help! Odometer and tach twiching when key is turned on
  51. Help need 04 CR-V Radio code serial is 23114518
  52. 1998 Honda Crv LX Thermostat Housing Leak
  53. Windows wont roll down
  54. couple J-series swap questions
  55. CV Shaft Seals
  56. Thunk thunk thunk...
  57. 2005 Honda CRV Idle Issue
  58. 2003 honda element issue
  59. Valve problem 1rst gen crv fix??
  60. need opinion on foglights
  61. 96 Honda CRV Won't start unless I press the Gas Pedal
  62. 98 CRV - Won't start
  63. V-tech valve inspection
  64. CRV vtec with AUTO tranny
  65. Gen 1 rechip?
  66. New to me 98 V DD for my daughter
  67. New to the CR-V world!
  68. '97 CRV Cold Start Fine; Hot/Warm Start is Spotty
  69. Fuse Box layout on 2000 CRV
  70. CRV 2001 - Start problems + error code P0118
  71. honda crv o2 sensor problem please help
  72. making 00 crv rims look better
  73. Leaking Injector on a 2000 CR-V
  74. 2nd gen mud mats in a 1st gen
  75. 2004 Honda CRV Interior Lights Issue
  76. Honest Honda Tech question on CRV code
  77. Removing steering wheel cover
  78. 2001 Vtec crv ecu help
  79. 97 crv distributor pinout?
  80. 99 crv brake bleeding with abs
  81. Slipping Clutch 98 CRV
  82. Will these wheels fit?
  83. Looking for some help 98 crv
  84. 98 crv tranny replace need torq spec
  85. first CRV and new to forums
  86. Wheels and lowering info please help?
  87. Dreaded Electronic Problems in Africa
  88. Any issues with slamming a awd 1st gen
  89. B20 Gsr head swap check engine light
  90. B20/vtec with e85?
  91. What are roof racks made of?
  92. My lowered 2000 cr-v
  93. Coilovers
  94. b20 spark plugs
  95. Weird Issue with MY 1999 CR-V Hoping you guys can help
  96. B20b compression
  97. CRV throttle woes
  98. CRV rear differential question
  99. Cluster light bulb sizes
  100. 1999 CRV Starting Problem
  101. My new Cr-V build
  102. Will 96 Integra lowering springs fit my 01 honda crv
  103. 97 crv, b20b to b20z
  104. CRV SWAP
  105. gen1 rim/color input
  106. Low brake at Low RPMs - 2007 CRV
  107. Replacing fuel pump 2006 Element.. questions
  108. gen 1 crv fortune auto coilovers
  109. DRIVER DOOR NO INTERIOR LIGHT
  110. Koni/GC
  111. Got a free 98 5speed awd with blown motor
  112. hello
  113. 2000 crv front plate help
  114. Gen 1 Trunk Pop Fuse?
  115. Weak hatch struts, What replacement to use?
  116. 1st Gen tail light gaurds?
  117. 1998 Honda CR-V strange sound - video included
  118. Where is crankshaft position sensor located 01 CRV
  119. Which cylinder head replacement 01 CRV
  120. 2011 honda element question??
  121. CRV P1457
  122. CRV Catalytic Converter Replace With Test Pipe?
  123. 1997 CRV Thumping noise in front end
  124. need help engine swap
  125. 99 crv cluster and climate led replacement
  126. Hydro dipped some interior pieces carbon fiber
  127. looking for g1 crv clock delete
  128. B20Vtec Legal on a CR-V?
  129. 00 Crv Auto Transmission cooler route question
  130. Does anyone know where i can find or buy 1G crv front mudflaps in socal
  131. 99 CRV 4wd 5spd, 2nd gear issue
  132. 5x114 and 5x112
  133. 2007 CR-V Driver's Side Spotlight
  134. b20vtec
  135. '98 CRV wont start!
  136. "Junkyard" Performance
  137. Gen 1 Automatic Transmission Drain Plug Washer Size?
  138. What Engine Should I Replace in This CRV?
  139. 2wd stick trans ? Please need help
  140. Stuttering issue
  141. '98 CR-V Project
  142. 00 CR-V Start issue (Auto Trans)
  143. 05 Element fog lights
  144. Bolt ons....
  145. FML! Bent Crankshaft Pully
  146. First Gen CRV Lift
  147. Max Gen 1 Alternator Output? (Many auxiliary lights!)
  148. civic fog light on CR-V
  149. Springs on a 2004 crv
  150. starting problems
  151. 2002 CRV
  152. New guy with a clutch question
  153. 3rd Gen alternator on its way out?
  154. 1st Gen Cruise Control Noise
  155. 97 CR-V timing covers
  156. 04 manual crv with odd tapping noise at 2500 rpm
  157. 2005 Honda CRV Brake Calipers Overhaul and Brake Bleed
  158. car dying IACV or something else?
  159. auto tranny gear ratio/ shift points
  160. Bad knock sensor
  161. 1997 CR-V Misfire -Need Help. Compression and Leakdown passed.
  162. My element dies
  163. Need new + battery terminal
  164. [WTA] Will EK9 Type R Steering fit CRV First Generation???
  165. Genuine Honda ATF
  166. finally installed catch can and new fogs!
  167. 2005 CRV
  168. *****HELP CRV RATTLING NOISE WHILE DRIVING !!!!
  169. coolant smell
  170. 98 CR-V abs ground
  171. 2000 CR-V Fans and Smoke Problems
  172. b20/b16 ideas?
  173. b20z i/h/e re-flash???
  174. *Official H/T OFFROAD/LIFTED CR-V thread!*
  175. b20b 7800 rpm
  176. 98-01 CR-v Horse Power Ideas
  177. Block heater for 1997 CR-V.
  178. CRV in Africa: Horn Troubles
  179. 01 crv 5 speed project for 2013(((boosted))))
  180. 2005 Honda CRV
  181. 2003 Element multiple fuses blown
  182. Front End Clunking and Slipping??
  183. b20 leak
  184. 2007 CR-V side steps
  185. hiiiii
  186. crv drive shaft
  187. Where to get stronger u-joints??
  188. 99 cr-v ex running funny
  189. first gen crv 5spd f20b swap nightmare! help please, running but not good.
  190. Auxillary Fans keep going on and off
  191. 00-01 engine difference?
  192. Great source for replica oem gen 1 spoilers.
  193. 2001 Honda CR-V Gauge Cluster
  194. Got me a NEW V =)
  195. My 09 PPM Element SC
  196. 07 cr-v turn signal relay mod
  197. MY LIFTED 99 HONDA CRV AWD 5SPEED
  198. Blue Tooth issues
  199. Stumbling acceleration after warm up
  200. DIY: 97-01 CRV 5 speed manual radio removal
  201. 2007 CRV ABS, VSA light reset
  202. Vinyl Wrapping my 06 E
  203. CRV H23A vtec powered teaser video
  204. 98' crv 2wd low idle problems
  205. Rear disk brakes on a awd crv?
  206. backup lights wont stay on in reverse of my 98 CR-V 5sp. man.
  207. anyone have pics of inside 1st gen manual trans?
  208. '99 CR-V clutch problems
  209. 2007 CRV Engine fan problem
  210. Element clutch or gearbox problem?
  211. Immobizer Problems
  212. Rear spoilers on CR-V's
  213. brake caliper torque specs
  214. Battery cable replacement
  215. Just bought a used CRV, a couple of questions...
  216. 01 CRV wont start! NEED HELP ASAP!
  217. AWD CRV fluid '04 model
  218. '04 CRV maintenance light
  219. black undercarriage for 3rd gen crv: how to keep it looking black?
  220. wire location
  221. CRV only rear wheels moving!?!?! HELP!!
  222. 1999 CRV Ecu Location?
  223. Rattle when going over bumps
  224. Wont shift out of park..
  225. 1999 CRV Ecu Pinout
  226. need advice on CR-V shocks
  227. '02 CRV p0341
  228. Honda CR-V 2003 front suspension
  229. 99 CRV 4WD, various problems wanting input.
  230. 01 4wd Trans work in a 98?
  231. Catalytic converter problem
  232. MY 1999 GSR 5SPD AWD CRV MILANO RED
  233. 2000 SE CRV Keeps Dying
  234. ELEMENT front seats.
  235. Rear Window Defogger Relay
  236. 05 Crv Whining sound
  237. Replacing the Inner Tie Rod - 08 CR-V
  238. New TPMS Headaches - What did YOU do?
  239. 1st gen crv tranny gear questions.
  240. CRV 2000 starts sometimes
  241. first 97 crx auto awd
  242. 2012 CRV Antenna vs. Car Wash?!
  243. Does the 1997 CR-V come in AWD?
  244. Starter Replacement Write-up
  245. 07-08 acura tl wheels on 07 crv lx
  246. Wow....seriously!?! Fawking thieves!!
  247. Door lock lubricant
  248. Oil leak on 2002 CRV
  249. Technical difficulties..
  250. ipod on a factory stereo
