PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. My 98 CR-V needs a 97 CR-V evap Purge valve
  2. 2008 element Po137
  3. P0304 Cyl 4 misfire after VTC replaced.
  4. Please ID
  5. My Mugen 2018 CRV | Looking for Suspension
  6. Power locks driving me crazy.
  7. 1998 CRV, torque converter unlocking in 4th?
  8. Tire Size Recommendation For S9A 665A Rims?
  9. Rattle on ignition? 2014 CRV Touring AT
  10. 2002 CR-V Fuel Injector Wiring?
  11. 2000 honda crv no Crank sensor removed completely
  12. Re: Not enough acceleration to go up the hill? wtf
  13. Element Clutch Packs
  14. 2002 CR-V Dead A/C
  15. No start after replacing SRS computer.
  16. 2002 CR-V Upstream A/F Sensor Pinouts
  17. Code Po134 one solution
  18. Lane assist and workaround for always holding the steering wheel - 2019 CR-V EX-L
  19. 2006 CR-V VTC Oil Control Valve Leak
  20. AWD conatantly on query on a MK2 2003 CRV
  21. 2020 Honda CR-V Vibrations
  22. Gen1 CRV Suspension Upgrades...
  23. Element Cranks but no start
  24. CR-V dsm injectors with resistor box not working.
  25. 2013 CRV EX-L aftermarket
  26. Increase Tire Size on 2017 CRV Touring
  27. Relays Behind Glove Box//
  28. 2003 Honda Element part
  29. Strange Air Conditioning problem
  30. Gearbox compatibility
  31. Clearing Codes
  32. 2003 CR-V rough ride even with new suspension
  33. P0134 code
  34. 2006 Honda CRV Automatic “Hard Start”
  35. 2003 CRV EX, cooling system leak, what is this part?
  36. ‘00 CRV temp gauge fluctuates with rpms
  37. How to Remove ABS Sensor from Knuckle
  38. Looking for name of part on 2003 Honda CR-V
  39. 2004 CRV Motor Mount: OEM vs Aftermarket
  40. Replaced IMR Solenoid, Disconnected Battery, Pos Terminal Loose, Now AC is Wonky
  41. 2007 CRV Hi Idle
  42. 1998 Honda CR-V
  43. 2006 Honda CRV immobilizer Issue
  44. Wiper slapping A-pillar at highway speeds
  45. 2007 Honda CR-V stuttering issues on the highway
  46. Question on bolt pattern
  47. 2007 CRV Fuel rail pressure sensor
  48. 2005 crv passenger side oil leak
  49. 1997 Honda CR-V (first gen) iacv issues
  50. '03 CR-V p0134 + p0139 intermittent
  51. help on crv 2013 touring horn problem
  52. 2001 Honda crv misfire cylinder 4
  53. Honda CRV 2002 Hard Start/ Fuel always Empty
  54. What Cluster is this?
  55. 2003 CR-V Start issues.
  56. Jdm B20B into 97 CRV
  57. 2016 crv oem amp bypass
  58. 5 Premature Water-Pump Failures in a Year, HELP!
  59. Rear differential on a FWD
  60. 00’ CRV Excessive Clutch Free Play
  61. AC Poor Cooling
  62. 2000 CR-V Rough Start - I'm at a loss
  63. Transmission model code number for Gen1 manual trans RT4WD
  64. 2003 Honda CRV
  65. Can I put OEM CD/Cassette Player into 2001 CRV
  66. Camshaft timing
  67. 1999 Honda CR-V Awd 5MT
  68. Weird buzzing sound from engine
  69. 2000 CRV AC problems
  70. 1998 97-01 CR-V No heat
  71. Wiring diagram/pinout for 2014 CRV Nav radio?
  72. 2015 CRV: HandsFreeLink Suddenly cannot connect my phone with a Loading screen
  73. 2001 Broken hard brake line at rear passenger brake
  74. 99 Honda CRV Driver Lower Motor Mount - Missing Nut
  75. Rd1 engine needs ups....please help
  76. Headlamps Battery Drain Question
  77. 97-01 Honda Cr-V Cooling Fan Motor Failing?
  78. Replacing factory nav radio on 2014 CRV Touring?
  79. Multiplex control-unit part # 2010 CRV EX
  80. Does 99-01 Crv have an immobilizer in their ecus?
  81. Off Road Tires - General vs Toyo vs BF Goodrich
  82. 97-01 crv rear camber kit - 88-00 civic fit?
  83. 2016 Honda HRV intermittent flashing odometer
  84. Failing hard at hardwiring dashcam
  85. Cooling Hose Kit
  86. 2003 head gasket
  87. JdmRD1
  88. 2013 cr-v front end rattle
  89. Why won't it stay running?
  90. 2002 Honda CR-V m/t cruise control unit
  91. Lights Not Flashing When Locking
  92. 1999 Honda CR-V Door doesn’t always unlock
  93. 1997 CR-V ENG CHECK LIGHT ON STEADY.
  94. Need Advice on 2000 CR-V Running Rich. Bad Injectors?
  95. 1999 CRV transmission upgrades to newer
  96. 98 crv fuel injector
  97. Backup camera mounting location
  98. 1997 Honda CRV idle issue
  99. 2005 CRV directfit catalytic converter not fitting..
  100. 1999 Honda CRV Front upper control arm issue
  101. 2005 CRV P0685 - where is the ecm/pcm relay?
  102. 99' CR-V valve clattering. Help.
  103. 2001 Honda Cr-V multiple/random misfires
  104. Assembly line in Yorii factory
  105. No spark
  106. 1999 Rear Trailing Arm Bushings
  107. SRS Wiring Fix 2004 Honda CRV EX
  108. 2005 crv vtec
  109. Which Bee R limiter
  110. Which Bee R limiter for Rd1 CR-V
  111. 1997 CRV
  112. 2019 CRV fails to start
  113. 2003 Honda CRV Cold air driver side, hot passenger side
  114. JDM RD1 complete teardown. oem accessories(YouTube)
  115. 2004 CRV: Doing Maintenance. What else while I'm in there?
  116. Abs failure?
  117. 98 crv water leK
  118. No AC clutch engagement or condensor fan
  119. P0131 oxygen sensor low voltage error code, how to check if bad
  120. Fuel trim levels
  121. 1997 CR-V
  122. 1997 CR-V
  123. 01 CR-V AWD starts good, warms up and then instantly dies, but will restart
  124. 2nd gen Steering Wheel compatibility
  125. 2012 CRV possible alternator issue...or something else?
  126. 2008 Honda CRV Question
  127. 2012 CRV Wierd Noise from Engine side
  128. 2007 Honda CR-V p2646
  129. 2004 honda crv starts up fine but gear leaver wont go into gear
  130. HONDA CR-V 2015 EX-L
  131. 2008 honda issues
  132. Wheel Bearing & Hub replacement
  133. Engine rubbing noise 2015 CRV
  134. 2001 Honda CR-V hesitation / loss of power PUZZLE (I've tried many things)
  135. crv-1st generation
  136. Traded my CRV for something..... good/bad?
  137. Used 2003 Honda CRv
  138. CR-V Oil Consumption Due To Excessive Fuel Dilution Of Oil??
  139. Is this wear detector?
  140. 2005 CRV - Multiple Codes & Issues. What order to tackle them?
  141. 1997 CR-V oil pan is leaking after gasket replacement
  142. 2009 CR-V P2646 VTECH issue and limp mode
  143. I no longer have an oil dilution problem.
  144. Not sure what this plug with the exposed wire is for, I'm sure someone here knows
  145. Honda FRV how to remove ECU ?
  146. Issues Faced in a brand new Honda CRV 2019
  147. Crv 2008 will not start
  148. Rough idle sometimes stalls
  149. Tire Shakes around 10 - 20 mph
  150. 2001 CRV rear Ujoint help
  151. 2010 honda crv blinker/ headlamp issue
  152. Still no spark with new distributor?
  153. Problem with ECM
  154. 1999 CRV Driver side engine mount issue
  155. 2000 CR-V...Need Advice On Possible Low Compression
  156. 1997 CR-V - Gear oil in rear diff
  157. Passenger low beam for 05 honda crv wont work
  158. Multiple Codes on 98 CRV
  159. 2004 crv crank no start
  160. 1997 CR-V - Can't open glass hatch
  161. Somebody give me some advice on how to diagnose my CRv
  162. 2017 Crv electrical issues
  163. Reversing electrical problems -help ..
  164. 2001 CR-V O2 sensor issue
  165. The a/c heat is not working
  166. 2003 CR-V Headlight Projector Retrofit
  167. How can I permanently disable 2019 CR-V Collision Mitigation Braking System CMBS ?
  168. What to look for during inspection of 2005 CR-V 4wd stick
  169. How to remove antenna base from fender?
  170. 99 crv won't disengage park after brake job....
  171. 2007 Honda CR-V engine noise
  172. K24a2 from 04-08 TSX in 02 auto AWD CRV
  173. 2002 Honda CRV engine swap
  174. 01 CR-V with 197K mi - buy it?
  175. 2006 CRV - after airbag recall, no high beams
  176. 06 CRV Misfire and Now P1009
  177. RD1 Automatic Radiator work in MT?
  178. 1998 CRV Brake Interlock
  179. Sputtering sound + oil leak -> shaking and loud engine??
  180. First Generation CR-V Brake Master Cylinder, ABS vs Non-ABS.
  181. Need Advice On 2002 CR-V Sunroof
  182. 2003 crv vsa light reset??
  183. 2008 CR-V Squeak
  184. Help 03 crv pulling to the left but can’t find out why
  185. CR-V styling/offroad part websites
  186. Engines B20Z2 vs B20Z1
  187. 2015 CRV LX navigation?
  188. 2006 Honda Element on the fritz (help diagnose & worth repairing?)
  189. 99 cr-v, b20b swap CYP code help!
  190. Need Advice On 2002 CR-V Shop Manual
  191. 2009 CR-V leaking oil on belt
  192. P0661 issues
  193. 2000 Honda CR-V Automatic AWD
  194. 98 cv rebuild help
  195. OBDII bluetooth device in a 2014 CRV
  196. Steering, automatic transmission, brake and hot smell
  197. RD1 CRV Auto-Up Window Switch
  198. 2005 + 2006 CRV
  199. Water pump bolt
  200. Is it normal for the CRV consuming all oils evry 5k miles?
  201. robert232
  202. 2003 catalytic converter replacement
  203. Key falling out while driving
  204. Stereo Wiring nightmare!
  205. Smarty Trend Head Unit
  206. VIDEO - 2014 HONDA CR-V - REPLACING REAR BRAKE PADS - DIY
  207. Interior Dome Light Not Working
  208. P1298 trouble on CRV mod 03
  209. Help! Engine swap Is it possible?
  210. 99 Honda CR-V break line leak..
  211. 2004 CRV-Bypass Hatch glass indicator bypass
  212. Getting between passenger seat and center console
  213. PSJB_CRV build thread
  214. P2646 and P0011 error codes
  215. Oh boy, another Honda idle problem..
  216. 2013 CRV backup camera issues
  217. 2003 Element-High idle Then idle hunting when warm
  218. 2002 CRV EX AWD Trouble Codes
  219. Odd starting problem- 2004CRV
  220. Buying a Crv today
  221. Auto/Manual swap computer
  222. '02 CR-V Won't shift out of park, no crank
  223. HR-V wheels on a 2009 3rd gen CR-V
  224. terrible fuel mileage
  225. by pass damper question
  226. CR-V 2014 LX , CVT transmission?
  227. 97 crv no crank no start stumped my local mechanic
  228. Does a 2014 require an ATF filter to be changed every time ATF is changed?
  229. Adding Fog Lights to 2006 CRV
  230. 01 CR-V won't start once warm??
  231. 2011 seat belt replacement (yes, the one in the ceiling under the headliner
  232. CRV 2013 Shoulder Seat Belt Lock
  233. Gen 1 wheels on Gen 2?
  234. ENGINE HESITATION
  235. CRV/ELEMENT TRANS
  236. Ignition barrel/lock what are these wires?
  237. Key Wont Open Driver Door Through Door Lock Cylinder
  238. 2013 CRV 2.4L jumped timing chain
  239. 2014 CRV annoyance with AT
  240. 98 Honda CRV cold soak crank wont start
  241. Cross comparability for Honda Element trans?
  242. 2000 Honda CRV Unknown Issue need help!
  243. Bluetooh
  244. 1st gen CR-V heat/temperature blend fix
  245. 07 E. rapping noise from below engine
  246. P0420 Question
  247. 2016 Honda flasher relay
  248. 2003 CRV headlight reminder chime
  249. 01 door adjustment for wind noise
  250. OBD1 2000 CRV with A/C Fan Issues
