Oil leak, oil pan gasket? 2002 Honda CR-V
Hey guys, I have an oil leak coming from the passenger side of the car, with little knowledge on where to look specifically for an oil leak I can not seem to find just by glancing around and checking obvious spots(filter, sending unit,). It looks as if there is a hole under the seal where it meets the block, but I cant get a light on it to diagnose. The car is almost out of oil and it seems to be still leaking. Any help would be great.
The crease where the pan is seems to indicate where the oil leak is but looking into the crease from the top you cant really pin point the damaged area
This is a (s××××y)image of looking at the crease from above.
immalooser
09-25-2009 08:05 AM
