PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. Problem: VSA kicks in and taps the brakes, any advice?
  2. 2001 Honda CR-V Rear Driveshaft odd ball.
  3. 1996 CRV JDM import Brake Pads
  4. DIY power increase for an '05 CRV?
  5. 2002 honda cdv intake phylum and throttle body torque
  6. will this header fit 1st Gen AWD CRV
  7. '99CRV with Check Engine light on.
  8. Massive Oil Leak Near Oil Filter - HELP
  9. LED indicator hyperflash on CR-v Gen2 - Solution?
  10. 1998 honda crv fuel pump wires torn d4 flashing l
  11. 1999 CRV CKP sensor bypass with JDM B20Z swap
  12. Help
  13. Reverse Gear won't click in when cold
  14. Do CRV Gen 1 support OBD-II/ELM327?
  15. Transmission issues
  16. '15 CRV Bluetooth and iPod
  17. ShouldI/Can I use these suspect looking CRV aftermarket engine mounts?
  18. my passenger door lock will not fully lock or unluck when I use the key in the driver
  19. brake lines
  20. Please help me solve this cylinder head/valve cover oil leak B20Z
  21. 2012 CRV looking for a new battery
  22. 2018 - OBDII + ABS + SRS + etc bluetooth scanner?
  23. 1st Gen CRV how to test the AWD?
  24. password
  25. 06 crv auto tranny fit in 03 element
  26. 2002 Honda CRV fuse #9
  27. JDM b20b with P8R head, valve issues
  28. Trans fluid, when to change it?
  29. 2008 Honda CRV Wiper Switch Replacement
  30. CRV 2003
  31. 2014 CRV
  32. 2nd gen lowering options
  33. Honda CRV flickering headlights and dashlights
  34. 2018 CRV..no heat
  35. Whistling noise when RPM goes above 2000
  36. really need some help. my minds exhausted.
  37. 1999 CRV replacement key
  38. Re: PLEASE HELP does anyone know what year the series 1473 came out
  39. 2006 Honda Element Stalling Issues I've Tried Everything
  40. CR-V IV Gens electrical schema
  41. on a 2004 crv japan made car is the fuel pressure regulator in the tank
  42. 2003 CRV Negative Fuel Trims driving me nuts.
  43. 2003 CR-V has all lights pulsing with engine on
  44. Flashing head lights
  45. Shifter bulb replacement
  46. headlight electrical troubles
  47. 1998 CR-V heater not hot and temp gauge stays on cold
  48. CVT in 2015+ CR-V Reliability?
  49. Loss of power when heater is on
  50. how long can I drive an 2007 Honda Element with 0% oil life?
  51. Injectors not getting ground
  52. Rear Lower Control Arm Bushings
  53. 97 Honda CRV stalling while driving
  54. Wheels for my crv
  55. Will 17x9 Enkei Kojin fit a CRV
  56. awd crv limited slip front differential
  57. Honda CR-V 2013 center hood rubber seal missing?
  58. 2017 CRV: Radar & Blind Spot issues?
  59. 2015 crv tpms
  60. Honda CR-V 2013 center hood cover rubber seal
  61. Thicker oil grade 2001 CRV
  62. Honda CRV - Dead after start
  63. 03 Element wont move forward after stop sign
  64. Unusual tire wear.
  65. 2006 CR-V P0420 code
  66. Suspension and wheel questions for an AWD 2002 CRV
  67. Crv lift questions
  68. CR-V EX-L vs CR-V Touring
  69. Creaking noise
  70. 2005 Honda CRV fuel gauge stuck on full
  71. 2004 CRV p0497 code
  72. How do I start my 2001 Honda CR-V
  73. 1997 CR-V Driver Door Harness
  74. CRV 2007 instrument panel removal
  75. OBD Scan Help
  76. 2003 element starting issue
  77. CR-V Gen2 hood dampers?
  78. fuse # 2 under hood burn
  79. 03 CRV, "rich" at idle. Rotted B pipe flange p0430
  80. ELEMENT TIMING CHAIN KIT RECOMMENDATION
  81. 2017 CRV MULTİPMEDİA SYSTEM HACK
  82. 2017 Honda CR-V brakes suddenly
  83. Engine ? Honda crv2004
  84. 07 Element AWD manual Axle seal leak
  85. 2014 CR-V with code issues
  86. 97 crv lift help?
  87. 2006 CRV AWD not working! Help!
  88. driver side window 2006 CRV
  89. Locking yourself out of the Honda?
  90. 2006 Honda CRV drive shaft question
  91. 05 CR-V Water pump replacement - what else?
  92. Clabbe´s RD9 build
  93. i have diesel in my 2010 honda cry's gas tank
  94. Knock Sensor PLUG
  95. 2006 CRV: Weird object attached to air cleaner housing screw: need answer fast, pls!
  96. 2006 Honda CR-V: Weird sounds as the key is insterted and car won't start
  97. ecu
  98. High idle
  99. Remote starter installation issue (aftermarket)
  100. 2000 crv timing issue
  101. honda crv annoying humming or vacum sound
  102. When to replace spark plugs of 2008 CRV?
  103. lift kit?
  104. Doors Automaticall Unlock
  105. 2014 CRV: Battery Light Stays On!
  106. abs
  107. [2003 CRV] Underdrives via K20Z1 Pulley
  108. 95-01 CRV Axle too short?!?! Deeper frame or suspension issues?!?
  109. CR-V Warm up mode ?
  110. 2007 CRV EX L transmission fluid flow direction
  111. RD1 fender mirror install guide?
  112. 1st gen CRV cluster stepper motors
  113. Element Steering rack difference between years (03-11)
  114. 03 CRV, where to go from here
  115. 2001 CR-V temperature sensor... do they make 2 different sizes?
  116. check fuel cap
  117. 2002 CRV door compatability
  118. Radio code concern
  119. CR-V Full Bull Bar
  120. RD1 CRV Spoiler/Wing Installation
  121. Steering problem
  122. Auto Light not working / CR-V 2011
  123. 99 CRV 5SPD AWD Need Help!
  124. Honda CRV Tirew wear issues...?
  125. Fuse schematic
  126. 2005 Honda Element Stalling?
  127. Suspension bushings 2gen crv
  128. Gen 2: A/C Pressure Readings
  129. 2002 Honda crv lx
  130. 02 Honda CRV overheating
  131. Warn light Xmas tree. 2007 CRV
  132. 2002 Honda CR-V doesn’t want to crank
  133. 1998 honda crv
  134. 1999 Honda CR-V Driveshafts
  135. CV Axles
  136. ATF fluid USA and EU the same?
  137. 1996 CRV Timing Belt Questions
  138. 2007 CRV Pulling - HELP
  139. engine dies soon as I release the gas pedal
  140. Weird HVAC issue
  141. Speedometer/odometer stopped working
  142. 1st gen with cracked C-pillar
  143. Can I program new OEM TPMS sensors before installing them in the tires??
  144. tire balding
  145. Relay question
  146. roof rack thread size
  147. CRV stuck in park
  148. Shocks for Element:
  149. Ignition
  150. 1999 Honda CRV Transmission Issue
  151. central locking problems
  152. 2010 Start up nosie
  153. 2017 CR-V maintenance
  154. 00 CRV Converting Stock Dizzy To Coil Packs
  155. 2002 Honda crv cooling fan
  156. Anyone wanna play Name That Noise?
  157. 2017 HR-V red CD light
  158. CRV Misfire - Distributor related?
  159. Power Steering Leak
  160. 1998 CR-V | Turns Over - Won't Start | No spark
  161. No Dashboard Lights Upon Keying In
  162. does a 2004 CRV have a doorlock passenger multiplex control unit?
  163. CR-V AWD LX, when lifted on jack, only 3 wheels spin.
  164. growling/whinning sound
  165. Axle Nut Torque
  166. CRV lock 'shrieking' noise
  167. 2004 CRV Front Wheel Bearing
  168. 2017 CRV EX - Remote start, walkaway lock, and fob lights/beep when locking
  169. 2006 CRV Honda Right Headlight
  170. Need Help, need frame parts
  171. how many 02 sensors does a 2002 CR-V have?
  172. @008 Honda Element manual heater cable where is it?
  173. 2000 CRV automatic transmission issue
  174. CAR WONT START AFTER DRIVEN FOR A SHORT TIME
  175. Honda CRV AC problem
  176. YCP B20 piston noise
  177. Park AND D4 Lights illuminated. Strange 3- downshifts.
  178. actual mpg for Honda Element and Honda CRV
  179. My CRV 2010 shuts off while driving
  180. no constant 12volts to many things
  181. 1st gen CRV alloy wheels
  182. 2003 CR-V CV shafts
  183. '07 Honda Element APP Sensor or TPS
  184. 2000 CRV White Smoke Engine
  185. Idle issues
  186. 2017 CRV Apple Maps Voice Guidance
  187. Alignment on 2016 CR-V
  188. 2001 crv srs code11-1
  189. Break and driving light issue.
  190. 2001 CRV lift kit or other?
  191. Exterior Molding
  192. 2005 CR-V will not start anymore
  193. PGM tester code 66-1
  194. TPMS sensors relearn or not 2007 CR-V
  195. 2012 CRV Charging Voltage Problem
  196. 2011 CRV Cooling System
  197. rough idle and dies
  198. 2001 CR-V Stalled. Will crank but not start.
  199. 2005 CRV EX - difficult starting - replaced your starter?
  200. Whine as soon as foot off accelerator
  201. does a acura rdx strut fit a honda crv?
  202. false misfire codes on 2001 crv
  203. how to check fuel pressure
  204. 2003 Element Engine
  205. 2011 Honda CR-V torque specs brakes
  206. Timing rebuild K24
  207. Isolated Suspension Noise
  208. 2008 CR-V low fuel pressure
  209. 2006 CR-V rough idle - when AC kicks on.
  210. CRV sport 2002 charging problem
  211. Steering Wheel Swap. Cruise wiring.
  212. MK1 CRV
  213. 2004 Element breaking Sway Front Bar Links Quickly
  214. ID and LED
  215. wire color chart
  216. 97 crv auto
  217. How Much Power Can A Stock Auto Trans Take?
  218. Installing Distributor after replacing head gasket
  219. 2006 crv transmission whine
  220. 99 crv just rebuilt, rom surges on start and then bounces up and down.
  221. **Trans-GO shift kit for autos**?
  222. 1999 CR-V has erratic idle when ac is on
  223. Andrew's RD7 progress
  224. 2013 CR-V Bluetooth pairing issues
  225. 2004 Element Electrical Problems
  226. high idle crv 2010
  227. Honda CR-V 2007
  228. Heavy Duty Inner rear CV joints???
  229. Oxygen sensor problem
  230. '99 CRV auto shift cable adjustment HELP
  231. Intermittent HVAC
  232. Problem shifting into PARK
  233. 3rd Brake Light FAIL on 06 Element
  234. Blinking red light on my CD player. HRV 2017
  235. Significant Oil Burning in 2004 CR-V
  236. random misfire
  237. 2005 CR-V Power Windows Master Switch
  238. Need help with brake lights
  239. Name this fron suspension part - 2005 CRV EX
  240. vibration on acceleration and under load - axle change related
  241. 01 crv noob in trouble please help
  242. Honda CR-V 2012 issues
  243. 2000 CRV check engine light and rough running
  244. CRV Phone Bluetooth
  245. 2015 power outlet not working
  246. 2008 honda element lx brake hardware kits
  247. 1998 crv transmission issues. Need help
  248. Retiring CRX, Swapping Built obd0 b20b into CRV
  249. 04 crv shaking
  250. Low Oil Pressure light - on and off
