PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24
  1. News concerning the redesigned VTC actuator
  2. crankshaft pulley wobble 01 crv
  3. I want a smoooooth ride for my 2008 CRV
  4. 2007 CRV Check Engine Light after Throttle Body, MAF Sensor cleaning
  5. popping noise from front left
  6. 01 AWD CRV Lift Kit
  7. 1997 CR-V: Cannot shift out of Park
  8. 1997 CR-V SRS Cable Reel/Clock Spring
  9. Sway Bar Links
  10. 1997 CR-V A/C Belt woes
  11. 2003 Element Reverse Lights Circuitry / Wiring Diagram
  12. '97 CR-V: Suspension help
  13. My 206 CRV Customizations: HIDs, grille, and soon lift
  14. How many times can a P75 head be serviced?
  15. 1998 Cr-v Issues that could mean the end.
  16. CLUNK in the FRONT
  17. auto AWD trans confusion.. 97/98 vs 99-01 vs JDM
  18. 07 CRV TPMS issues
  19. Jdm auto climate control/jdm clock/ambient temp sensor
  20. 1997 RD1 CR-V
  21. 2000 CRV reverse/backup light relay location?
  22. p0325
  23. Gaskets, axles and racks (oh my!)
  24. Shop Manual? 2006 Element
  25. 1st Gen CRV Alternator Removal
  26. Low Jack hammering noise
  27. No air through central vents
  28. CRV towing questions, bout to get wild.
  29. Yonaka Coilover question
  30. Current leak
  31. 99 CRV ecu options
  32. I am New here... Son just bought a used CR-V & he dropped part of funnel in Tranny!??
  33. AC compressor noise in '04 Element
  34. 97 CRV Jumping Tachometer
  35. Rd1 crv Japanese wiring diagrams needed
  36. Shopping for my next Honda: 2005-06 CR-V
  37. Spark plugs ? really?
  38. 1997 CRV - Rough start when hot - sometimes
  39. B20B, B20Z piston rings are the same?
  40. Proper gen 1 HID retrofit?
  41. 2005 CR-V wheel size confirmations
  42. 2010 CRV w/ sticking piston rings
  43. 2015 CRV Bluetooth audio weirdness...help!
  44. 2012 CR-V - "Reconnect System Writer" error message on Clock
  45. Please help, loosing my mind!
  46. '97 - '01 CRV Rear U-Joint Replacement WARNING
  47. Rear Diff Issue
  48. power window issue
  49. help i love my 2000 crv but its got something wrong
  50. Seized lug nut
  51. 2002 Honda CR-V turn signal flasher relay location
  52. 2005 CR-V Sunvisor
  53. 2004 CR-V Intake Manifold Codes 0661 1078
  54. Metal clicking sound when crv is idling...
  55. will a 1997 CRV motor & automatic trans bolt right into a 1999 CRV?
  56. 05 CR-V EX Front Clunk, Help me identify (pic heavy)
  57. 04 Honda Crv HELP... HELP....
  58. Thread / instructions for replacing motor in 1999 AWD CRV?
  59. Idle problem?
  60. 2005 CRV Scan Gauge shows TPS 16
  61. 2004 crv help me need to access starter
  62. 1998 CRV cam plug or seal? Mine is leaking.
  63. Engine is shot, swap?
  64. no power to the radio unit
  65. Anyone have a eBay fog kit in a 02-04 crv?
  66. Honda CR-V axle
  67. 1999 Honda Crv isnt getting spark
  68. 2003 CRV Flashing D Drive P0700 Transmission Fault
  69. Honda element rear window latch stuck in closed position
  70. Best Cat Converter for my 2003?
  71. Advice for torque increase on 2000 crv
  72. 2008 crv d4 blinking
  73. 2004 Element Turn Signal light not working
  74. P 1457 1998 CRV
  75. Front suspension overhaul
  76. Need advice with 2006 CRV AC overhaul
  77. Low Fuel Light 01 CR-V
  78. This isn't the Marketplace.
  79. 2011 CRV SE
  80. Honfa CR-V maintenance cost
  81. First gen cr-v
  82. Closed.
  83. Dribbles of coolant...cause for immediate concern?
  84. Where is the expansion valve 2008 crv?
  85. Loose Gas Cap or EVAP Leak?
  86. looking to buy
  87. saving my first CR-V: 2000 -5speed with blown motor
  88. 1997 CRV Driver door stuck shut
  89. Catalytic Converter - California Legal - NEEDED!!!
  90. 1999 CR-V no spark, help!
  91. coilover strut replacement
  92. Anyone know if Civic/Integra/Accord sideview mirrors fit RD1s??
  93. Back cover contacting camshaft
  94. Steering rack joint bad
  95. CR-V 2001 LX Automatic to Manual Conversion
  96. 08' CRV AC issues after replacing compressor
  97. CRV 1st gen rear diff
  98. Unplug VTC car runs
  99. 03 crv oil problem!!!!
  100. **Fuel pump issue** 08 Element
  101. CRV AWD v FWD
  102. Headlights & Tailights Will Not Turn On
  103. Can I tow my 94 civic hatch race car with my crv?
  104. 2003 CRV Knock sensor Bypass
  105. Serial stamp on head
  106. 2003 CRV Pulling when Accelerating
  107. 2001 CRV - Squeak when turning wheel - sometimes slips
  108. CR-V Purchase Advice...
  109. Turbo w/ stock crankshaft
  110. Replacing A/c Expansion
  111. 2003 CRV no Heat OR A/c
  112. 2005-2006 CRV ECU PIN OUT
  113. Will this work
  114. CRV 2WD 5 speed conversion HELP!!
  115. 2005 2.4L white smoke from exhaust
  116. Gen 1 CRV clunking in front suspension
  117. 03 Element valve problem and questions
  118. Wheels for CR-V
  119. Brake master cylinder
  120. Honda Element swap
  121. Changing gearing in 97-01 awd crv
  122. 99 AWD Bias
  123. A/C Compressor not Kicking On and Off
  124. Can't pass emission due to high co
  125. Rd1 crv driver window only work when door open
  126. 2005 cr-v code P0661
  127. 97 CRV: Need to Buy Discontinued Steering Col Covers
  128. 2005 CRV Timing chain install VTEC 2.4L
  129. 2003 CRV compliance bushing
  130. Maintenance required light blinks a couple times first starting t
  131. Need help on Suspension (1st gen crv )
  132. 98 crv needs a new motor
  133. Head cover nut
  134. Timing chain install VTEC 2.4L 2001 CRV
  135. tire size question
  136. Element 6 speed conversion
  137. Windsheild gutter leak fix
  138. 2006 element reclining lever
  139. 98 crv
  140. 2003 CR-V Downstream O2 Sensor Vehicle-Side Wiring
  141. Tensioner bolt
  142. Cylinder head gasket replacement
  143. Rocker Arm Assembly (intake)
  144. 2000 crv timing belt replaced need help
  145. HELP NEED EDM CRV PARTS
  146. Replacing oem steering wheel to an after market steering wheel
  147. Looking to buy an element - buyer tips?
  148. newbee stock jdm b18c
  149. 2000 CRV engine remove/replace
  150. New used 01 CR-V
  151. 2013 CRV rapid turn signal
  152. 2002 CRV CEL code help
  153. wiring for oem fog switch
  154. How to remove 02-06 CRV auto shifter lever
  155. What ps bracket/pump can I use B20z/vtec
  156. Engine mount / AC belt adjustment
  157. 2002 CRV drained battery, had it charged now no response
  158. Timing is off and hitting valves
  159. 2003 CRV, ABS brakes, Auto transmission stuck in PARK
  160. b20v vtec camshaft
  161. I have a 99 crv and the reverse lights dont work and it is a auto
  162. 98 crv miss after tune up
  163. Honda CRV Turbo build help
  164. 99-01 CR-V FWD to 4WD/AWD possible?
  165. Timing belt change
  166. 2015 CRV EX-L 2WD with Navigation $28762.0 or EX-L AWD $27941.0
  167. 99 cr-v has gear oil smell
  168. B20 motor help
  169. CRV Window problem, Anyone have any idea what is wrong?
  170. Newbie looking for advice
  171. CRV - 07 rear washer not working
  172. 2002 honda crv lx sunroof
  173. looking for edm/jdm front and back bumper and parts thanks
  174. Honda CR-V making weird noise after timing belt install
  175. Hitch install on 97 CRV
  176. 2004 Honda CRV Sputtering under load
  177. Engine install troubleshoot. '02 CRV EX
  178. RD1 Water Leaking Issue Resolved
  179. HELP PLEASE!!!
  180. Park Pin Switch
  181. CRV '12 open door, warning chime won't stop
  182. 2002 CR-V Drivers side brake rotor very hot
  183. Would this cause a No start situation?
  184. Crv 2003 fluids & filters
  185. '01 Honda CR-V: Misfires after EVERYTHING!
  186. 2006 Honda CRV fault code U0122
  187. Terrible rear shudder
  188. 2005 CRV and the battery keeps dying
  189. Roof Rack channel - Broken - Clips Needed?
  190. P1259 and limp mode, but only on cold engine?
  191. Muffler bolt size
  192. 03 CRV front end scoots while turning slow
  193. 2005 CRV with coolant in the OIL!
  194. 2001 Honda CR-V engine with 7000 miles.
  195. Can I re-use the pressure sensor from a damaged rim on a new rim?
  196. Diagnosing and replacing ECM/PCM in '00 CRV
  197. 99 Crv se in junkyard
  198. Low fuel light
  199. unknown dangling connectors in engine harness( with pics)
  200. >>> PLEASE HELP. 98 CRV STUCK IN 1ST AND 4TH GEAR <<<
  201. 2002 Honda CRV Speedometer problems
  202. 99 4WD MT - High pitch whine
  203. 04 CRV - cylinder 1 misfire code
  204. After Drive Shaft replacement
  205. 2005 CRV won't start
  206. Aftermarket Floor Mats
  207. 00 Crv hard cover removal?
  208. Stock Exhaust Size and Patch
  209. Coil over sleeve set
  210. Brake squeak
  211. 2002 Honda crv alternator question.
  212. 2000 Honda CRV LX 4WD (5 speed)
  213. Looking for 5spd for l.s.d. mockup
  214. Genuine Honda Factory Coolant - Fact or Fiction?
  215. element clunking noise in rear
  216. just bought it and it's misfiring
  217. 1998 CRV 4wd problems
  218. Refilling coolant
  219. oil
  220. Honda crv transmission problems please help!!!
  221. Possible to put fog on 1st Gen crv like the jdm/edm bumper?
  222. what wheels are these
  223. 03 crv newbie
  224. Puddle on passenger side floor when it rains...
  225. 98 no elec power to start.
  226. 2000 Honda CR-V Temp Gauge Issue
  227. 2010 CRV Weapon-R or K&N Style Cold Air Intake
  228. 99 crv rough idle
  229. Callmetree19 dd project 99rd1
  230. Will CRV front seats fit in my element?
  231. What could be Wrong with my CRV? P1259 ,problem with Vtec?
  232. B20b swap ,, need help with coolant hoses . Pics inside
  233. Problem with automatic transmission CRV 98
  234. Coolant hose help for B20b swap .. Pictures inside !
  235. Where is the Fuel Rail Pulsation Damper on Gen4 CR-V?
  236. More stalling problems
  237. 1st gen CRV Camber question
  238. 2006 Honda CRV headlight relay
  239. 2000 Honda CRV - A/T gear hunting/flaring issue 3rd-4th gear
  240. Lowering a 2nd gen CR-V
  241. Idle re-learn procedure for Gen4 CR-V?
  242. Transmission issues??? 97 CRV AWD
  243. 2002 CRV DRL indicator !!!
  244. Transmission position indicator lights
  245. ENGINE BAY pictures! lets see them!!!
  246. 2005 Element with seriously dim lowbeams
  247. Bad Vibrations
  248. 99' crv what model do I have??
  249. 1999 crv balljoints
  250. 2001 Crv Issues
