PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. CRV cutting out
  2. Lifespan of CRV?
  3. CV Joint? Tire Disconnected While Driving / Turning.
  4. CRV oil pan torque specs
  5. K24 etc low, idle high, thermostat replaced
  6. 99 crv no power, blown fuse
  7. CRV 2002 - New fuel pump installed, gas gauge stopped working
  8. Fuel pump wires , ripped out by dog
  9. 2002 Honda CR-V trans leak.
  10. AC works Sometimes and Sometimes it doesn't work. why?
  11. 2018 CRV EX vs LX vs RAM4 performance
  12. Driver seat rolling noise
  13. Camshaft Position Sensor
  14. Oem Honda Air filters
  15. 98 CR-V 4wd Rear Bearing Bad
  16. 99 crv cranks but no start
  17. Honda crv usdm to jdm transmission swap
  18. 1999 Honda CRV Fuse 56 keeps blowing
  19. Need advice with 2004 crv AC issues
  20. About to pick up a 2005 CR-V AWD. Few Q’s
  21. fuse box ground location
  22. speedometer intermitent
  23. transmission swap
  24. recommended maintenance schedule
  25. Help! 1999 Crv Jerking issue
  26. Flickering dash board lights
  27. 2011 crv no power to accessory no power to constant power Power to crv only when on
  28. My wife drives a 2002 auto AWD CRV with mild upgrades
  29. 2005 cr-v rear bearing
  30. 06 occasional no start
  31. Honda Crv CV Joint Keeps Coming Loose
  32. Intake Air Bypass Control Thermal Valve & codes P0507 P2279
  33. CRV Horn Relay
  34. A/C clutch engaging and disengaging problem
  35. [HELP]P0401
  36. Tire Light Keeps Coming On 14 CRV
  37. Element ECM swap-reprogramming
  38. ECM swap 2007 Element
  39. 2017 Honda CRV only getting 22mpg
  40. How easy is it to steal a Gen 1 CRV with factory immobiliser?
  41. More premature water pump failures: 2016 CR-V
  42. 2003 EX under hood fuse box
  43. ELD disconnect
  44. Analog speedometer in 2018 CR-V?
  45. Oil pressure light flashing
  46. 2003 CRV hood stuck
  47. Braking System Combination Valve
  48. Intermittent buzzing/humming noise-2006 CR-V SE
  49. Rattle
  50. oil light
  51. Fuse Box/Multiplex for 2004 CR-V
  52. crv sounds like thomas the train and code p0131
  53. Changing compressor bearing 2005 mk2 2.2 cdti
  54. 2003 CR-V Suspension and/or Brake upgrade?
  55. Can I disbale auto locks?
  56. Oil pressure light flickering
  57. 99 CRV - Water Leak - Need Help ASAP
  58. 03 CRV stereo problem
  59. 2002 CR-V Test Drive Noise Help
  60. 2000 Honda CRV Alternator Bottom Bolt and Nut
  61. 2016 CRV Oil Drain Plugs
  62. 2001 Honda CRV Shutting off
  63. Intermittent steering wheel shake
  64. 99 CR-V Fuel gauge stuck.
  65. what is the purpose of dimpling the axel nut
  66. random fuel injection / starter moter
  67. RD1 CKF bypass
  68. Honda Element Passengers Window
  69. 99 Honda CR-V timing bay issues/ rubber shavings
  70. Scanner for Throttle Position reset
  71. oil problem
  72. oil light
  73. 1999 Honda CR-V 0132 code
  74. 2002 cdv 2wd break booster
  75. 2000 CR-V Engine Dead at 205k
  76. where is the egr valve on 2003 crv????
  77. 1999 Honda CRV - Rear End Groaning Noise
  78. 2004 CRV Limpmode P2646
  79. New CR-V control arms, loose bushings?
  80. 05 CRV “N/A” Codes?
  81. How to correctly remove the "99 CRV Gen 1 Airbox?
  82. 97 Honda CRV Stock Spring Rates?
  83. 2005 Honda Element injectors do not pulse
  84. Alignment Issues with 1" Lifted 1st Gen CRV
  85. 2005 Element Evap Sensor Replacement
  86. 2002 crv lower dash console removal
  87. Brake Flush.
  88. 2000CR-V engine management light
  89. 2002 CRV - Coolant & Condenser Fan NOT Working
  90. 2004 CR-V Manual Transmission Multiplex?
  91. 08 CR-V rear susp torque specs/ manual needed
  92. 1999 Honda CRV Timing Belt Replacement Help
  93. 2005 element
  94. 2011 CR-V ECT sensor location
  95. Radiator Cooling fan issue
  96. Brake lights don't work on Honda 2007 CRV
  97. Tire fitment
  98. Better horn for 2018 CR-V
  99. 2008 CRV, Trouble Starting?
  100. Honda 2012 CRV MES Connector
  101. 2015 Honda CR-V Serpentine Belt Replacement
  102. 2016 CRV Turn Signal Fuse
  103. B20z block p75 head, what head gasket?
  104. 2012 CRV NEW TIRES NEEDED
  105. crv 2017
  106. Honda Engine Swap
  107. Redcblinking red light next to CD slot when car turned off
  108. P0171 After JDM Swap
  109. Help: Front Wheel Hub - How to Pop Out
  110. 98 CRV Power window won't go
  111. Thinking about buying a 2013 CRV Ex-L w/ 50 k miles. What should I be looking for?
  112. 2001 cr-v no engine power no CEL
  113. 2008 CRV PAG oil capacity
  114. Parasitic draw on battery
  115. Gen 1 CRV Timing Belt
  116. 2006 - Pop when engine starts
  117. CRV 2014 Leather
  118. CRV 2014 skull cap
  119. CR-V IAC valve problem
  120. Why shouldn't I use a crv for an exo build?
  121. Best quality struts ?
  122. Timing Chain replacement
  123. 2001 CRV in Boston area?
  124. 2003 CRV Seat Belt Chime Activation
  125. Trans.
  126. 2009 Honda Crv 4wd EXL-how to perform an Idle relearn and ECM reset please?
  127. Jdm b20b head doesnt have year stamped. Please help!!
  128. CRV sunroof came off!
  129. What are the possibilities?: USB (or similar) connections in CRV for Dashcam use
  130. 1999-00 CRV subframe
  131. 06 crv cold air Intake duct
  132. Squeal
  133. Off Road
  134. 2011 CRV trunk door not closing
  135. '12 CRV wipers stuck on......again
  136. Can ac clutch be replaced or do I need a whole ac compressor
  137. Damp/ wet air wont start
  138. 2006 Honda CR-V headlight problem
  139. CRV jerks when coming to a stop
  140. 2013 CRV stuttering
  141. 2011 CRV ac clutch dead - bypass?
  142. Coolant System Questions 2000 CR-V
  143. '08 CR-V ran out of oil... now what?
  144. 2005 Honda CRV - code P2647
  145. Honda CRV 1998 - White smoke from Exhaust Manifold
  146. What is a Zap Latch/Cable?
  147. 1996 Honda cr-v e-rd1 cuts off
  148. 1996 Honda CR-V E-RD1 wont shift
  149. 1999 CRV AWD Auto Transmission Died and Came Back to Life
  150. 2017 cr-v dome light
  151. 98 wont start. Could it be octane 88/E15 gasoline?
  152. headlight bulbs.
  153. 2002 CRV Smoking and More!
  154. What's the difference?
  155. Rebuilding 2nd gen CRV. How do I figure out where my engine was built? England or Jap
  156. 2010 CR-V rear seat won't tumble
  157. Always hot fuse
  158. Does crv have Smart Parking Assist
  159. is my compression bad?
  160. 2002 CR-V engine removal guide?
  161. 1999 Crv bogs down on retart only
  162. 1999 CR-V lock actuator removal
  163. 97 jdm b20b awd front differential delete
  164. upgrade lighting
  165. My 03 RD7 CRV!
  166. 2002 CRV Persistent P1259 Remains
  167. Better - GRAF or GMB Waterpump?
  168. Exhaust Noise Only When Accelerating After Catalytic Converter Replacement
  169. 2016 CR-V engine cover
  170. 97 CRV overheating and radiator fan does not turn on by itself
  171. Honda CR-V bell or Chime noise
  172. 01 CRV front blinker and running light plugs needed
  173. 2017 CRV won't start
  174. CR-V 98 P3F ECU Pinout
  175. 05 crv Driver rear window won't go back up.
  176. crv 4wd alarm goes off when tried to start engine with key
  177. 2002 Honda CRV stalling
  178. Cargo cover for 2012 CR-V
  179. 02 CR-V Japan built vs England built
  180. B20 cambelt rear plastic cover touching cam pulleys?
  181. Wiring Question for JDM CRV RD1 (1997) Outside Air Temp sensor (Ambient)
  182. Green key light on CRV flashing
  183. Battery keeps dying
  184. Keep getting vtech and oil pressure valve codes
  185. 2010 CRV Brake rear lights issue
  186. 01 crv 4wd crv axle compatibility problem
  187. 2nd gen from the UK build
  188. Help identify my 2002 CR-V ‘s issues
  189. How do I remove factory dash tweeters?
  190. 03 Honda CR-V not starting after ECU change
  191. AWD gen 2 CRV - RWD engage only
  192. How improve radio reception?
  193. Gen 1 CRv - can i use RTV silicone as a sump gasket replacement?
  194. P0420 help
  195. 2000 Honda CRV no start.
  196. 2000 crv overheats but cools extremely fast...help please
  197. Rack & Pinion Leak Honda CRV HELP!
  198. How do i remove hatch glass
  199. JDM K24 Swap into 02 CRV. Some help needed.
  200. G2B awd Crv with boost. Looking for answers
  201. Any A2 swapped Elements?
  202. rear air shocks or shocks for 2007 CRV?
  203. 2002 CRV Knock Sensior Issue
  204. Car Turns Off Stopping and Starting
  205. 2006 honda element standard Question: new battery does not stay charged
  206. OEM CRV Foglights Not Working, No Power to Lights
  207. Key fob not working
  208. 2002 CR-V Wont Start/ No Crank. Please Help
  209. HonaLink on CRv LX
  210. 2010 CRV EXL CAN problem
  211. What Can Be Harvested From a First Gen CR-V?
  212. Is the JDM fender mirror adjustable? (1st gen)
  213. 98 crv awd 2nd gear grind
  214. P2646 P0420
  215. Honda Fr-v rear toe alignment
  216. Water pump?
  217. 2006 CR-V 2.2 i-CDTi - difficult to move on full lock at low speeds
  218. Question about 2018 CRV AWD system
  219. low beam problem
  220. CRV boot won't open
  221. Alternator removal 2014 CRV EX-L
  222. Electrical Issue, How To Debug?
  223. Rd1 lifted turbo build
  224. sluggish!
  225. Jack/Lift Points if you have Running Boards (Gen 2 CRV)
  226. 99 Honda CRV not connecting to scan tool
  227. 1st gen CRV are parts interchangable?
  228. '04 CR-V K24A1/MRVA Jap import service manual questions
  229. Honda Element 2007 O2 sensor bank 1 sensor 1
  230. 1st gen A/C tensioner pivot bolt
  231. 1st Gen - 4WD only 1 front and 1 rear wheel spins, please advise.
  232. Under-seat wiring question - 2006 Honda CR-V
  233. Honda CRV - Vibration noise in dash
  234. 2000 Honda CR-V / Shift Into Park Issues
  235. 15x8 procomp wheels
  236. lift kit for crv rd-1
  237. 2005 Honda element, replaced starter, won't start.. help!!!
  238. 2008 Honda Element Air Condtioning Issue
  239. crv wiper blade problem
  240. Drago’s 2005 CRV mods..
  241. 2017 CRV TOURING
  242. crankshaft sensor bypass
  243. Charging Light
  244. Axle Vibration damper come loose, now vibration
  245. Squealing on tight turn
  246. 2000 CRV - Cluster Lights Issue
  247. SRS light stays always on in Honda CRV 2001
  248. Key Fob wont work just lights up on clicking Lock
  249. 215/75 or 225/70 1st Gen
  250. P0507 & P2279 Need help with these two codes.
