2013 CR-V 2.4 excess oil consumption
I have a 2013 CRV EX-L 2.4 with about 85k that's using oil but Honda call's it "acceptable". My daughter owns it and is not the type that wants to check the oil level and add oil every few weeks or month as has been the case. I'm actually afraid she'll run it dry. What a shock. I understand the need to check oil level regularly on an old Chevy, or Harley, but once every few weeks in a modern engine? This otherwise immaculate CR-V just dumped most of it's private party resale value it had cause I'm not going to lie to anyone about it. Anyone else have this problem with a 2.4?
Thank you,
goco
Thank you,
goco
Re: 2013 CR-V 2.4 excess oil consumption
Thank you,
goco
Thank you,
goco
Same vehicle, year and mileage. I noticed the loud rattle now known as the timing chain rattle on start up. Why do I talk about this in an oil consumption area? Because they are related. I couldn't figure out why the rattle at 75,000. I searched the internet and You Tube. Found out that these Hondas from 2023 start to burn oil t around 75000. I was curious so I checked my oil level 1 month after I changed it. My oil dipstick came out dry. I had no idea how low it was. So after adding 2 quarts it was at the full mark. A mechanic on YouTube stated that if these Hondas run low on oil, it will cause the timing chain to stretch. This causes the VCT noise. After I topped off the oil and drove it the rattle nearly disappeared, but not completely. The VCT actuator is not the issue. The excessive oil consumption is the culprit. But why at around 75,000? Honda knows it is all related. They know the problems originate with the oil consumption. Honda really screwed up engineering this CRV. The problem now is what are intending to do about it?
X2BOARD
01-13-2004 03:30 PM
osuPrelude
10-22-2002 05:24 PM
