View Full Version : Honda CR-V & Element
- CRV speedo issues
- A/C Turning on and off constantly
- What is the warning light for on my 2003 CR-V ?
- Recommended Size of tyres for this beauty
- Need help finding seat belt buckles for '99
- 2012 CRV Defective Seatbelts?
- How to replace 1998 CR V PCM
- SRS/Air Bag System Replacement
- vacuum lines for a modifies crv engine
- Should I buy this 2006 CR-V?
- 2002 Honda CRV
- 2016 CRV Suspension Noise
- Window Won't go up.
- 1998 CRV 5 speed AWD squealing issue, trans?
- Would Like to Convert RT-AWD to Switch with 4wd
- 03 honda crv ac and idle problems
- 2001 CRV - A/C work sometimes.
- 2012 CR-V EX key won't operate door locks
- 2012 CR-V Tensioner Removal
- Performance Parts for 2012+ CRV ?
- 98 manual CRV transmission questions
- this guy makes me proud
- 2006 CRV A/C compressor conversion
- help diagnosing rear end noise
- Castor problems in an 06 CRV
- 2003 CR V hood latch...assembly bolts?
- Element Oil Pan Removal Special Tools???
- 2003 Honda occasionally won't start when engine hot
- 2000 CRV Shift lock problems
- Automatic Transmission Compatibility AWD & FWD
- Wondering how to do my tire/rim setup
- i-VTEC Timing Chain Help Needed - 2005 Element
- First Gen CRV suspension adjustments
- B20Z1
- Knock Sensor Wire Harness
- Diesel 2.2 CDi Hesitation
- sunroof don't move or click
- Seized bottom caliper bolt
- p1166 an p1167
- 98 cr-v w/ b20b high compression engine
- CR-V upgrade
- OBD2 connector size
- Power Accessory Socket
- Honda CRV 2000 Ran Dry (No Oil)
- No-Start
- slow acceleration in 1st gear - CRV 1995
- Rear Sag & Aftermarket Replacement Coil Springs opinions
- Misfire when cold with six CEL codes
- Need to Bleed Clutch
- 99 CR-V No Start/No Spark
- CRV 99-01 Keyless transmitter question
- Master cylinder problem?
- Solenoid "c" stuck open/has a hard time with reverse and O/D
- Please look at this picture and tell me if this is put together correctly.
- Quick question on Main Relay
- 1996 CR-V Whirring Sound when Braking
- 2000 Crv Overheating
- 2003 Element- what to look out for
- 2001 CRV water pump bolt location
- 1999 CR-V lowering concerns
- 2002 CR-V LX driver's seat rocks
- 2008 wiper issue crv
- 03 crv suspension help
- How to fix a common problem (hood Handle)
- Transmission cooler for 2015 CR-V
- CRV Takata Airbag Issue
- Swap seats in 3rd gen CR-V?
- 2004 Honda CRV AWD Air Bag
- Bypass Transponder
- Windshield washer fluid stopped working on front windshield only
- Roof Rack Baskets? How did you install yours?
- Radiator Fan needs "help" 2004 CR-V
- Wiring Kit for trailer? 2016 CRV
- Transmission Codes?
- 2002 CRV Where is front Air Flow Sensor reading P1166 &P1167 Codes
- New to me crv...strut questions
- 2004 element inner tie rod
- 2001 crv key removed engine still runs
- Dash clock help
- 2003 crv offroad wheel question
- looking for '02-'04 ac help
- K24A8 swap in 2005 Element
- Sheared off a/c pulley bolt
- Recently Purchased Gen1 CRV - Sound Diagnostics Help
- Airbag - CR-V
- yay or nay new ride
- 2005 Honda CRV AC blows cold only when not idling. Condenser or Vacuum leak?
- 2001 CRV diff swap?
- Engine Light P0325
- 2014 CR-V transmisson smell
- 00 crv auto input speed sensor
- Rear hub / bearing removal
- 2005 Honda CRV Headlights went out cant fix?! Need help
- 1995 honda civic wont pass smog
- B20B crankshaft problem
- 4dr accord fogs
- 98 crv 5 speed b20vtec build
- 99 CRV B series manual transmission
- JDM Engine install
- HELP!!Rev Limiter problem!
- first gen crv and accord shocks
- 2012 CRV Small Animal Damage
- Jdm b20 from CRV into del sol, question with b20
- 2011 crv SE gas door
- 02 CRV complete Brake Parts - brand to avoid, items to buy (eg OEM or not)
- Timing at idle?
- Replacing front RH strut
- CRV 2005
- Seeking older CR-V (1st -2nd Gen's) what to watch out for -mileage wise, etc??
- Lift Kit Comparisons CMR vs OME - Spring Rates & Facts Included
- Best coilovers and wheel fitment for 01 Honda crv
- Honda CRV 2006 K20 engine stalling and stopping when cold.
- 99 CR-V head rebuild/replacement
- 03 CR-V Heat
- crv alarm siren
- '02 cr-v rattling and surging
- Valve lash and carbon
- b20z2 engine teardown and rebuild
- Front passenger turn signal not working
- HELP!!!Blower not working!!!!
- E 4WD Won't track straight (kind of) at highway speeds
- My CRV alignment seems way off, any thoughts?
- 98' bad lock up solenoid and P1298? Wire shortedout?
- Will this work in a 1998?
- 2014 Honda CRV Stereo Issue
- Premature Water Pump Failure in 2014 CR-V with 20K miles
- Reverse light does not work
- 2003 CRV EXL Cruse control problems
- Repair manual question
- AWD engagement noise
- 2000 Honda B20z2 with p8r head
- 1999 CRV P0300 - P0304
- Usdm B20b to B20z swap HELP !
- 1999 CRV lx misfire, stalling engine P0300, P1399
- Weird intermittent almost white noise at idle
- Just bought a 1998 Honda CR-V 4wd 4AT
- Re-entry into the Honda Scene via 1999 CR-V EX 5-SPD w/120k
- Honda access mudflap measurments
- 2001 Honda CRV - Hard Start & Running Lean
- How much are 1st gen CRVs going for?
- 1999 CRV, 5speed
- 99 Manual Trans Swap. Electrical issues,
- 2000 stick shift b20z turbo build
- vtec solenoid wiring
- shaking when i turn 97 crv
- First gen awd header options
- Low voltage (P0122) on Throttle Body Sensor
- 1997 - 2001 Honda CRV RD1 Rear Disc Conversion DIY Write-Up How-To Guide
- O2 sensor question
- Perhaps an immobilizer problem ?
- disable auto lock on 2001 CR-V
- 2003 Honda CRV LX
- Tread depth on CR-V AWD
- Help with lifting/bigger tires/lower offset on 06' CRV
- Lift Question - Struts and Spring specific
- Dangers of crap aftermarket parts
- CR-V 4WD maintenance rear diff?
- how do i find TDC for pistons with head removed?
- 1st gen or 2nd gen CRV in Canada?
- B20 Camshaft Position Sensor?
- Acceleration Issue
- Oil pan leaking...
- honda crv 2000
- In the market for crv - what to look for?
- Extreme smoking from 07 2.4
- Struts and shocks
- fan on the left/drivers has refused to come on
- 2001 CR-V - New Owner With Idle/Stall Issues When Engine Cold
- Squeal from Bluetooth calls
- 1998 power loss/idle problem
- 2014 CRV EXL Random Beep Noise
- Question about the cable shift linkage.
- couple of problems im new be nice :P
- Too much oil in 1998 CRV...
- 2001 CR-V AT B20 AIC Valve Wire Colors
- 1998 CRV door handle
- Where to buy Electronic load detector 98 Crv
- My new CR-V Project!
- 2001 Honda CRV New JDM Motor Running Loud + Vibrating
- 2016 Honda CRV -- USA/CANADA vs UK models
- 2016 CR-V Rear Headrest Adjustment
- Are these windows usable
- window problems
- 5 Speed 2003
- Misfires - testing fuel pressure
- Worth purchasing?
- Should I buy it? $1000 2000 CR-V EX, 178,771 miles, Random Misfire/Wont Start ..
- Honda Element Limp mode help please
- 2006 Honda CR V LX - P0301 (MISFIRE CYL 1)
- 1st ever AWD kswapped 1st gen crv w/parts list
- Used car experience 2006 CRV
- 1998 CRV Power Steering pump help.
- Distributor swap on 1997 crv
- Brakes squeaking on 2014 Honda CR-V
- RD4 CRV instrument panel problems
- Should I buy a CR-V that leaks oil? (pics)
- Interior lights are not working and the fuses and bulbs are ok
- First ever 2011 Element Rear diff into 1st gen CRV RD2 rt4wd info inside
- Dead CRV
- My ratty RD1
- Slow cranking 03 Element
- 2006 CRV vibration under driver seat
- 1st gen wheels on 2nd gen?
- Heater control panel keeps dying. 1gen CRV
- B20b problem.
- I need the name/part number for a replacement
- For those with Gen 2 CRV, am I missing an under dash panel?
- CRV RD1 aftermarket parts????
- 2003 Honda CR-V / P1457 EVAP Leak
- chu clunck
- Distributor interchangeable?
- Buy EX-L '14 certified used or '16 Brand New?
- 07+ 3rd generation CRv suck? Or bad resale value?
- 2007 CRV Rear Wiper Motor Woes
- Gen 2 Ecu Location?
- Family whip 99 crv
- who has a DIY Aux input 2006 CR-V link
- horn prob of all horn probs
- 2002 Crv bottom dash removal
- K24A1 Flywheel weight
- new cr-v owner lol
- K24A1 2006 CR-V stage 1 exedy clutch bolt pattern?
- Bigger sway bars - improve handling
- Engine knock when in gear [video] [2009 CR-V 4WD]
- I'm back with a new(er) CRV, going in a different direction.
- Whited's 99 CRV
- CRV - Gen 1 engine for a Gen 1.5 engine swap?
- RD1 CR-V Coilover Setup Combinations
- VSA warning light on and stuck in park..
- CR-V automatic transmission replacement
- 99 CRV EGR port cleaning
- Burnout's 99 CR-V EX AWD
- 98 CRV catalytic converter replacement ?
- 2012 CR-V Heat isn't hot
- 1st gen frt rt ABS sens replace?
- Power Steering Chatter and Chirping Sound
- How much torque goes to rear wheels when RT4WD is engaged? (Gen 2)
- Need tech info
- Help me give my new ride a birthday :) [1998 5spd]
- 08 CR-V ABS Trouble
- Stalled no start
- GSR head swap.
- Anybody interested in CR-V heated mirror mod?
- 2005 CRV Slave Cylinder
- Power Steering return line
- 2003 CR-V Hesitation 2,200rpm
- 2000 CRV Diff leak after replacing
- Garble noise on hard acceleration
- 2003 CRV steering wheel Oem options?
