PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24
  1. left high beam and indicator not working
  2. 01 CR-V motor mount replacement
  3. 04 CRV dark interior
  4. JDM RETRACT SIDE MIRRROR BLIND SPOT SOLUTION WITH VID
  5. Anybody ever SeaFoam a CRV?
  6. cruise control not working
  7. Just sharing some pics of my head gasket job 1999 CR-V
  8. Are the 1st gen. radiator fans the same left & right ?
  9. Sway bars
  10. 2007 Honda CRV alternator walk-through?
  11. 1st gen transmissions
  12. 2000 CRV Misfire Problems (Compression is ok)
  13. BLK on BLK 2014 CR-Z
  14. 2004 Crv no start after ecu reset.
  15. Trip Odometer Stuck
  16. Backup camera wiring 2002 CR-V LX
  17. 02-06 Crv Lowerd Pictures
  18. 2000 crv transmissions
  19. exhaust valve stuck
  20. 04 Honda Crv motor problem
  21. overheating engine or not ? need some opinions!
  22. 1st Gen CR-V with Integra Type R coilovers
  23. Quote for Repairs to CRV - opinions?
  24. K&N filters
  25. 07 crv sway bar options/ performance options
  26. 1st gen CR-V - Using a header designed for an Integra CARB legal?
  27. A/c bypass options
  28. 2000 CR-V crank/ no-start help pls
  29. 4wd engaugment light?
  30. 02 crv rough idle, stalling and engine noise/knock
  31. Speaker wiring
  32. 98 CRV won't start when warm
  33. Vapor Canister probs
  34. KYB AGX Shock/ Struts for 1st gen?!
  35. 05 CR-V Lowering Options?
  36. 2004 Honda CRV washer fluid tank
  37. Bad heater core or.....?
  38. Gen 1 CRV issue, no power to front wheels
  39. Car acting odd after head gasket replacement
  40. CRV misses when warm
  41. 1998 CRV wont start, doesn't turn over...
  42. Damn PO's
  43. 2005 CR-V bad gas mileage
  44. CR-V RE3 Tire Size Down and Chassis Lift?
  45. Expo set-up CR-V or Element pic thread
  46. 2007 CRV oil pan replacement
  47. Looking to turbo my CRV with GSR swap and tune with NepTune.
  48. Is there a CRV Sunvisor (Like large trucks have)?
  49. Gen 1 CRV Cruise Control Rapid Acceleration
  50. Start and die between certain outside temps?
  51. Heater core Gen1 crv ..help please
  52. Rewiring the CRV Door
  53. 2002 CR-V Hard to Start
  54. 2008 CRV 2.4L rattle noise at cold start
  55. Honda/Acura SUV overall quality
  56. 2000 Honda CRV Keeps Blowing F/I Fuse
  57. OEM Header size?
  58. omb code kwp2000
  59. driver door wiring sucks 1st gen crv
  60. Check out my all red taillights!
  61. Oil - cause?
  62. 2005 Element fuel filler tube removal
  63. What is high-mileage in a 1/2 gen CRV?
  64. 03 Element - Electrical Issues Wipers/locks/signals
  65. 98 CR-V AWD rear end squeak / squeal on slippery roads
  66. Need help going from OBD2b to ODB1
  67. 00 crv turbo tuning.
  68. 98 crv running lights
  69. Vibration
  70. CR-V will not start, not battery, clicking noise
  71. 99 CRV misfire
  72. Any one know where to get some oem fogs for a 04 crv?
  73. 99 CRV starting problem
  74. Blinking Red Light in middle of CD slot of CD Player
  75. k2x a/c compressor compatibility
  76. 2004 CR-V high idle w/ idle surging 1400-2000 rpm
  77. Buying a crv: crv related issues?
  78. 99 crv daily
  79. Which motor mounts are most important?
  80. possible elecrtical or fuse issue?
  81. Really odd grinding noise on cold starts
  82. 97 crv auto shift problem
  83. Windshield Wiper Problem
  84. 3-Angle valve job on the B20 / CR-V ??
  85. Computer connection failed 2003 CRV
  86. 03 CRV rear wheels seized up?
  87. These parts any good?
  88. 1998 CR-V Crack in radiator across from upper hose fitting
  89. Made a DUMB decision a few months ago. Not sure what to do...
  90. Crv is over heating
  91. Anyone see this? Supercharged b20 on ebay
  92. Keyless Entry Issue
  93. 2005 CRV Light Problem
  94. 2000 CRV, Replace bulb behind fan control
  95. Need help decoding a crv vin please!
  96. CR-V suspension * anything and everything suspension*
  97. crv mk1 brake warning light issues.
  98. Strage grinding/scraping sound from front of engine
  99. SRS Code 04-06
  100. 99 CR-V Clutch R&R Question
  101. 1997 honda crv trans question
  102. Honda element loses total power
  103. 03 honda element water leak in engine bay?
  104. Transmission mount the same? B20 RT4WD Manual:
  105. '12 CR-V Cargo Area Noise
  106. RD1 updraged sway bar bushings.
  107. 98 CR-V severe hesitation/stall at low-mid throttle
  108. 99 CRV cross part interchane
  109. HONDA CRV COLD START HELP!!! VIDEOS
  110. OEM Timing Belt Identification
  111. Automatic Transmission Modifications
  112. is idle a common problem with b20 engines?
  113. 99 crv sounded like no compression when cranking
  114. 2002 CRV lossing power when cold
  115. Fullmark 01 crv??
  116. 1st Gen Hood Bra
  117. 00 Silver Cr-V Build
  118. 04 CRV Idle Issue
  119. Heads up on a cargo cover
  120. CRV Front Strut Fork vs EK Civic
  121. CRV Rear LCA Length vs EK Civic
  122. Cylinder Back firing on Crv 2001
  123. wiper delete kit?
  124. CR-V transfer case strength issue solved.
  125. Evo 5 style front bumper restyle
  126. Installed a passenger side armrest
  127. Seat belt replacement on CRV - how do I remove the interior body molding?
  128. Spongy brakes after simple front pad replacement
  129. Steel Braided Brake Lines
  130. Jerking on acceleration
  131. B20V Dowel Pins Misaligned Oil Leak?
  132. leaking radiator 99 crv alluminum radiator good?
  133. Anyone in Chicago? Halloween meet on the 26th
  134. Unatural CRV
  135. 97-01 CRV fog light grille
  136. 06 CRV too hot exhaust
  137. Honda stream display softwaRE disc
  138. Taillight has me boggled.
  139. 98 auto Crv. New to me project.
  140. Samsung Galaxy Note 3 and CR-V 2013
  141. Auto b20 LS Turbo Tune
  142. 2001 CRV misfire
  143. Rear wheel bearing help
  144. 1999 crv
  145. Adjusting idle screw and......
  146. Auto trans max power/torque capacity
  147. 97 CRV 217000 miles, sell or fix?
  148. Honda Crv 2001 EX cooling problems
  149. Just picked up a 98 CRV
  150. camshaft specs for CRV2.0SE SPORT
  151. 2005 CRV Help
  152. My 97 CRV and need help with wheels!
  153. Ran out of gas now car will not start, Any suggestions would be greatly appreciated.
  154. weird front end bouncing??
  155. scored free wheels for the crv
  156. All speakers cut out
  157. Honda Element 2008 repair manual
  158. Random b20z2 intake manifold question
  159. Clutch adjustment - 2002 RD7
  160. 2005 CRV Rear differential help
  161. Some help from you CRV Gods!
  162. Official CRV Deal/Steal/Hook-Up thread
  163. Crv keeps blowing the ACG fuse: Help me!
  164. Help with power accessory socket rewire
  165. RD1 FB enthusiasts page
  166. Keyless Entry?
  167. 2000 CRV All Wheel Drive
  168. Lifted EBP CRV work log
  169. Be aware if you order from prothanesuspensionparts.com for your CR-V
  170. H4 to double H1 conversion dilema
  171. After market clock
  172. auto b20 vtec
  173. New Build On Another V For Me
  174. crvs with built engines
  175. rims for first gen
  176. 2001 Engages Overdrive Gear Way Too Early - CR-V EX, AT, 75k miles
  177. jdm swap, torque mount spacers?
  178. leaky passenger floorboard?
  179. A/C wiring
  180. CRV management light
  181. Tranny Problems
  182. Removing the doors and rear hatch
  183. 2000 CRV build thread
  184. Sad News for Me
  185. Oil Pan Gasket
  186. Valves noisey after valve adjustment?
  187. honda cancer...
  188. Accord struts and springs
  189. deep whistling noise at high speeds
  190. What is this connector?
  191. Weird squeaking and clunking in rear
  192. Upper control arms
  193. 2008 honda Element Tire wear
  194. Anyone from Clifton with a CRV?
  195. AWD Issue
  196. CRV OBD1 A/C Fan problems
  197. Engine won't Idel
  198. UK Camel Trophy
  199. 2005 Honda CR-V headlight harness plug problem
  200. '05 CR-V Problem: depress brakes and instrument panel lights up
  201. Bouncy Bump Suspension
  202. stock Integra struts and springs on 1gen
  203. Tire size on wheel upgrade
  204. 2003 CRV Door Lock Cylinder Binds
  205. What are my options???
  206. Hit bump and radio turned off!?!?
  207. CRV Kick Pod Enclosures
  208. sugestions for rd1 rear wings please
  209. crv just died
  210. New Member Here!
  211. 2 RSX/CRV Questions
  212. 03 Honda Element hesitation
  213. master power window switch
  214. RD1 Squad Member
  215. Honda CR-V 1st generation (RD1-RD2) versions & types
  216. Getting a couple weird noises!
  217. High pitched whine type noise
  218. squeaking noise
  219. Passenger Airbag Light
  220. Cool things to do to my '01 CRV
  221. 1998 CRV obd code P0108
  222. Door latch inverted on 2000 CRV
  223. R12, R22, or R134a
  224. Need help with crower cams
  225. 2000 crv no a/c
  226. WTH?!! Car dies and I get CEL 78...
  227. 98 crv trailer arm bushing
  228. My new CRV
  229. 2002 CR-V 226k miles P0341 Tensioner/Stretch Question
  230. 97-98 differences from 99-01??
  231. Front Mud Flaps On Ebay
  232. 1997 CRV FI E/M fuse keeps blowing, car won't run
  233. painting taillights
  234. Seized rear toe bolt
  235. Help please! P1336 code, CKF sensor or ECM?
  236. Hours to replace CRV engine
  237. serialz_1 First Gen CR-V
  238. probs with 1995 CRV auto help!!!
  239. Aftermarket/Extended Warranty
  240. Element Wing Options?
  241. My first Gen.1 CR-V [never ending]
  242. 04 CRV-Replaced fuel pump, relay good-won't run
  243. Tail light problem first gen crv
  244. Need tips and ideas for my CR-V 3rd Gen
  245. Keyless entry question - 03 CR-V
  246. Crv stalling
  247. CRV problem please help
  248. CV Axle keeps popping out! Need help!
  249. Stock Pivot Cup Bushing
  250. Tein Springs Clunking
