View Full Version : Honda CR-V & Element
- What kind of Manual Tran. For a 2000 CRV?
- Master brake Cylinder issue?
- B20b4 vs b20z2 transmission gear ratios
- 2015 crv Need to set up apple play…?
- 2004 Honda CRV Trim
- P0339 - Crankshaft Position (CKP) Sensor Circuit Intermittent Interruption
- Gathers VRU - 205 CVi
- 2014 Honda CRV - what gear does it start in?
- Replacing transmission from salvage yard
- Check Engine Light Clears when Car Restarts
- 2016 CRV LX AWD i-Mid wire diagram needed
- Please help me file out fuel issues!
- Gen2 CRV performance from scrapyard
- 2017 CR-V 1.5 AWD not pulling itself
- Honda cr-v 2000 belts (ac belt, alternator belt and power steering belt)
- Fuel too lean (need help)
- 2014 CRV - 3 lights on (Tire, AWD, Steering)
- 1999 crv with 1997 tranny
- Vacuum leaks and shifting shudders
- 2012 Honda CRV Ex - Parasitic Electrical Drain
- How to deal with burnt valves
- 2017 CRV - Code P0456 with Smoke Test
- Need Advice On 2002 CR-V Valve Adjustment
- 97 crv import no start
- Mitsuba RK-0280 door lock unit to OMRON keyless unit?
- Honda CR V 2002 bad differential - really not worth fixing it?
- K24W9 Engine
- cr-v rear brake caliper 1. fit built japan & 2.except japan, What's the difference
- Help! 2007 CR-V AC valve core sizes/styles
- 2004 CRV starter, issues
- Crv 2001 horn stuck on
- 2005 Honda Element weird issue
- Wire diagram for a Honda Cr-v distributor wiring diagram
- 04 CRV - Flickering battery light at around 3500rpm
- Project: High mpg / reliable rd1 2000 Crv
- '04 Element Frame Rust - SOLUTIONS!
- 08 honda element
- 1998 Honda CRV FITV rings/gaskets?
- "EDC C0044" displayed, right wheel locked up
- 1998 Honda crv transmission interchange
- 98 CRV JDM 126,000 kmh or mph?
- Where does this wire go??
- Mystery of the nonexistant idle. 1998 CR-V
- Rotten egg smell, cranks but no start
- Starts only using starter fluid
- Replacing/Reconnecting Trim on Lower Rear Hatch--Thoughts Appreciated!
- 2018 CRV 1.5 valve adjustment specs
- 99 CR-V overheating at 60mph
- Location of the TPMS control module on 2009 CRV?
- What I've tried to fix the CRV trans shudder
- 2004 CR-V 4WD needs trans?
- Can I use 06 civic coil overs and shocks on 06 CRV
- Excessive Cranking when warm 2014 CR-V 2.0 FWD
- Some process running after engine has been shut down down.
- Low low idle Crv 2,4 2004
- CR-v 2002 ABS pump compatability
- 2001 CRV Temp Gauge Issues
- Cruise Control and P0340 code
- REMOVING PASSENGER (RHD) AIRBAG 2006 CRV
- 2012 CRV Cleaned TB, reset TPS and PCM with Foxwell NT710 now shifts are off…
- 2007 Honda CRV VTech
- Loud popping noise making turns
- 2014 CRV EX-L Wheel Question
- What do the fuse abbreviations mean?
- 99 crv burning oil
- '16 Honda CR-V Gas & Horsepower issues
- B20 Engine - Did I damage valves?
- 2023-24 CR-V Hybrid Alignment problems
- 97-01 CRV & 96-00 Civic - Water injestion through blower motor - fixing design issue!
- 2001 Honda CRV - Fender collision repair, paint and swap panel
- 2000 CRV - no space for rocker adjustment on exhaust side
- 1999 Honda CRV 2.0 No Spark! No Start Issue!
- 2010 CRV misfire
- 2012 Honda Crv Sound
- Help! Connected B1S1 and B2S2, think I killed my 07 Element
- 2005 CRV shakes gets worse as you drive faster
- Distributor not working
- P0336 Crank position sensor woes, help
- Honda CRV 2005 CTDI 2.2 wiring diagrams
- 2005 Honda CRV srs code help
- 2003 CRV idle problems after replacing IAC valve and cleaning throttle body
- Building my 2005 CR-V
- Crv upper bolt hole stripped for starter
- 2015 Honda CRV vacuum hose and coolant hose diagram
- Honda CR-V making strange noise when starting engine, and sometimes when driving
- adjustable cam gears stock?
- Clock Can’t Keep Correct Time
- 2013 CRV mystery noise after timing chain and tensioner replacement
- Identify these seals from a gasket set
- Are the valves open when at tdc?
- Is this the sound of a bad Water Pump for my 2009 CR-V??
- I'm completely lost on what to do
- 2nd Gen pre face-lift steering wheel compatability
- 2000 CRV Fault code question - c1700, p0071
- 2012 strut torque specs
- Moonroof won’t close
- Element airbag code 15-2 help badly needed
- 2008 CRV passenger door won't lock
- Honda Element 2005 engine mixed with coolant
- Crank Pulley Spec
- 2010 Honda CRV LX 4WD - Catalytic converter
- Am I being swindled?
- CR-V RD9 2006 UK 2.2 Diesel - Intermittent Crank No Start
- 2013 australian CRV - center sliding armrest dissasembly
- Reason for random P0740 code? 2013 crv.
- 2010 Honda CR-V Key Fob programming
- cat delete or hood exit need a tune?
- 2006 CRV 4Cyl- P01610 New Sensor but Code will not Clear
- Rusty thread on the battery retaining screw
- Engine swap compatibility
- Black soot and other issues….
- 2000 crv hose leaking?
- coolant flush ? or drain and fill ?
- How to test an Idle Air Control Valve
- High pitch whining from the rear at highway speeds
- Fuel gauge issue - low voltage on pin to fuel sender
- 2012 cr v front lifting point
- Engine pan Part name
- 2003 CRV - Idle Air Control Valve
- Ecu question
- Installing a factory roof rack
- Help looking for reliable rack and pinion for 01 Honda CRV
- CR-V II K24A1 head gasket
- 98' CR-V power
- 2011 CRV-EX
- Scraping sound
- New member New problem, no interior lights 06 CR-V
- 2003 CR-V chasing codes
- 2001 CRV no acceleration
- 06 CRV vibration at idle.
- CRV 2013 relay circuit board replacement
- 1999 CR-V 2W Beeping
- weird sound
- Why left exhaust pipe snoring?
- 2nd Gen CRV pwr Steering
- Adding power to DD RD1
- Car Won't Go Into Gear
- CR-V throwing multiple codes
- 03 Manual Crv no crank after replacing master and slave cylinders
- 2000 Honda CR-V 2wd grounds USA
- 99 Honda CRV LX P0730.
- 23 crv hybrid resonance
- Why wiper arm doesn't go all the way down?
- Honda Cheaping Out!!
- RD7 Front end clunking noise
- 2020 CR-V loses acceleration but mechanics can't figure it out
- How to replace plastic trim underneath the door handle?
- Easiest way to tell the timing belt is bad
- 2003 Honda CRV AWD - Touring Edition: INDICATOR WARNING ALARMS
- 2000 CR-V fwd no start
- 2007 Honda cr-v
- 2010 crv has trouble starting when cold, mechanic can’t find issue
- Transmission problems!! Help a brotha out
- CR-V 1.5 Turbo Is It Any Good?
- 2001 Honda CRV - Clean alarm install with telematics and remote start
- 2001 Honda CRV - Interior ambient lighting, custom door panel lights, map lights, etc
- 2001 Honda CRV - touchscreen double din android radio installed
- Is it normal for brake pedal to make friction and clicking noises?
- Need Advice on Issues with 2024 CR-V Sport-L
- Need help and advice. Car will not stay running. Died on the highway. P0341
- 2016 Civic Touring Rims on a 2012 CRV Touring
- Why 2024 Honda CRV has no engine cover?
- 2010 CRV steering wheel “pulsing”
- 2012 CRV no clock set after head unit swap
- service manual
- Fact or Fiction?
- 2006 CRV ECM change
- No more Honda for me
- The order of folders with audio files on a USB stick during the playback
- Daytime running lights CR-V 2019
- Honda CR-V 2019 hybrid 100k plus engine flash.
- 2017 Honda crv dome light wire
- Cam position sensor swap?
- 2000 CRV transmission/overdrive problem
- V-TEC miseries
- 2006 CRV Acceleration Shudder
- 2001 Honda CRV - reupholster sunvisors and adding homelink garage door opener inside
- Reluctor tooth bent need advice please
- Firmware for vxm-155vfei
- Where is my PCV valve located and where to get one in Europe?
- Key fob has to be touching the push start button to start
- 2nd Gen lift spacers diy
- 06 crv tail and dash light short
- 2004 Honda CR-V headlights
- Rear driver CV axle won't go back in
- 99 Honda CRV Cranks no Start
- 04 crv EX rear wheel bearings and hub
- Need Advice On General Brake Question
- Gen 1 CRV 2001 Transmission problem
- 5th Gen CRV ELD bypass (2017-2022)
- 1st gen CRV build advice
- Where to look........
- Chirping noise from engine at idle
- Loses power than picks up.....
- Is this loose piece of rubber on front suspension normal?
- Slow throttle response.
- RD1 & RD7 drivetrain compatibility
- 2006 CR-V PCM Swap
- hesitating
- 2024 Honda CR-V LX suspension.
- 2024 CRV Sport Touring - Dealer Replaced Windshield
- AC compressor part #
- Honda crv speedo not working properly
- '08 CRV starter change and now no start
- 05 Element LX AWD Auto to Manual Swap
- Our New member. JERSEY!
- 2013 Timing Chain Replacement
- Need Advice On 2002 CR-V Idle Hunting
- 2001 CRV Headlight Wiring Issue
- Opinions on best tires for Honda CR-V
- 2002 Honda CRV crank - No start
- 2011CRV AC Intermittent Blowing Hot Air
- 05 Honda crv - rear turn signal issues
- 2023 CRV spinning display
- hole below VTEC solenoid
- 2002 CR-V Door locks & Immobilizer problem
- Interior Panel Removal 2015 CRV
- 2012 crv airbag screw size
- 2002 Power Steering Pump Outlet Differences
- CRV 2007 overheats
- 2013 CR-V Sunroof not working
- 2001 Honda CRV - HID projector retrofit w/ detail attention
- 2001 Honda CRV - LED dome lights & map light project
- 2001 Honda CRV - LED stop light project
- D3 shift button
- sputtering at low speeds
- Sway bar bushing mount ripped out with part of "frame" 99 CRV
- '01 CRV, cold start rough idle. can stall.
- OBD2B to OBD1 conversion issues (chipped p75 ECU)
- Need Advice On 2002 CR-V Wiper Arms
- Range Estimate on dash
- P0505
- Recently purchase 2011 crv
- Troubleshooting my 2002 CR-V transmission
- 16x8 wheel on 01 CRV EX AWD
- Proper site to purchase HDS license
- Knock sensor - resistance and voltage output?
- Gen 3 crv Nav systems
- Wont start, no green ligth, no communication
- 04-06 TSX cams in a 09 CRV K24Z1 head?
- 2020 Crv 4cyl turbo Sparkplug gap?
- 1997 CR-V P0335 CEL won’t clear
- 2.2 DTEC EGR VALVE
- Noisy Alternator Belt on Startup
- 2009 CR-V Power Steering Frustration
- 2001 Honda crv cylinder 4 misfire p0304 p0300
- 2004 Honda CRVLX 4X2A/T-Which PCM is it?
- Honda crv 1999
- Can I use Idemitsu H2 cvt fluid
