PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24
  1. 2007 CRV - oil pump shaken itself apart?
  2. JDM clock with temp sensor help
  3. Thud noise from my wheel well
  4. Mounting a flashlight in cabin
  5. 99 CR-V Excessive revving when accelerating
  6. Deep Sleeper - Turbo CR-V
  7. eBay coil sleeves on CRV - your experience?
  8. 99 CRV Slow Motion Build
  9. Brand new clutch slipping, please help
  10. 99 crv, running rough, misfiring, backfires...coil? rotor? cap?
  11. Cant dial in timing. Timing mark jumps b20bz
  12. 98 crv awd error codes p0730 p0740
  13. ghetto armrest to keep gf happy lol
  14. What DOES CRV stand for?
  15. 07,08,09 power lock recall settlement
  16. CRV with coil sleeves..
  17. element advise
  18. 98 crv Randomly stalls then cranks but won't start.
  19. 03 LX - cylinder misfire 1
  20. need info on cel plz
  21. Uh oh.....Leaking Transmission Fluid....
  22. bypass distributor computer
  23. need help...please
  24. 06 honda cr-v starter relay and other relay locations
  25. 2001 Honda CRV..Idling issues help!!!!!!?
  26. 1999 Honda CRV Stalling
  27. crv lift
  28. 1st Gen cry dash light fuse keeps popping
  29. Throttle Position Sensor Questions...
  30. Third Gen CRV LIFT NEEDED
  31. 2014 CR-V steering wheel clicking
  32. ABS CODE 66-01
  33. Best/affordable CRV 2000 code reader
  34. 03 CRV No spark puzzle
  35. DBW stuck ratio
  36. 2015 Honda CR-V EX Dashboard/Center Console Lighting
  37. 2002 CR-V Braking Issues
  38. CR-V Revving in Neutral
  39. 1999 crv transmission issue... someone's gotta know!!
  40. 1999 crv intermittent spark
  41. general question help
  42. Attn: 2015 CRV owners/buyers...I'm in the market.
  43. Transmission Range Sensor - Am I Doomed?
  44. B20b head on b20b4?
  45. 09 honda cr-v,hid install
  46. 2005 CR-V hard starting when warm
  47. 2002 CRV VTEC solenoid replacement
  48. 2014 cr-v grill replacement
  49. Valve Lash Adjustment
  50. CV Joints
  51. crv tranny slipping
  52. 2007 CRV suspension knock when slow moving or stopped
  53. Repaire manual CRV gen 4
  54. ELD and Auto Trans Codes
  55. Oil pan gasket replacement 2001 CR-V
  56. 1st Gen Block Heater?
  57. 1st gen won't start
  58. Silly newbie question, How do I properly check the trans fluid?
  59. 2007 RVI CRV - 56k killer
  60. My 1998 CR-V minor build thread
  61. 2003 Honda Element auto locking HELP
  62. Safe 2015 Honda CR-V jacking points
  63. CRV Whine. Transmission? Belts? Normal?
  64. 2000 CRV decipher my code please
  65. 98 crv p0135
  66. 2006 Honda CRV stopped accelerating
  67. 1st gen crv largest mud tire that will fit
  68. What is the most simple & inexpensive safe lift for '03 CR-V
  69. Biggest tires that fit a stock '03 CR-V?
  70. 2015 Honda CR-V Smart Entry System
  71. 2000 CRV Coolant Leak
  72. 2004 Honda Element: Rear Lights and Cruise Control out
  73. no heat when engine is warm 2007 CRV
  74. 05 Honda CRV Bad Wheel Bearing? (Video)
  75. 2011 Crv tranmission
  76. Servicing Transmission in 2001 CR-V
  77. Lockout 5th gear on 2010 CR-V
  78. 🔴 BRAKE BOOSTER PUSHROD CLEARANCE ? 🔴
  79. Gen 1 CR-V Cruise Control Bulb Part Number?
  80. Snow tires.
  81. High pitched whine on cold morning startups.
  82. 2nd Gen CRV seat swap questions.
  83. clean the screen of vtec solenoid valve
  84. High Mileage CRV - Anything to look for?
  85. 2001 CrV B20Z - Fuel injectors Spray pattern
  86. 2008 Honda Element codes for VSA warning light
  87. 2000 CR-V timing belt tension
  88. partial throttle surging 01 CRV
  89. 2003 CRV battery/alternator issue
  90. 1997 CR-V Dies While Driving
  91. Honda CRV CTDI 2009 - rear foglight
  92. New engine for 03 Element
  93. Looking for 2013 & 2014 CRV Owners Opinions on AWD in Snow
  94. 2007 CR-V Black Death or just the compressor?
  95. 96-01 crv recalls
  96. Totaled CR-V 06
  97. Another Tire question -215/75/R15 BFG A/T
  98. 2003 CR-V OEM Hood Prop Rod Grommet Install
  99. 2014 CR-V Grinding Noise at Start Up
  100. 2000 Honda Crv pinging and metallic noise
  101. 00 CRV - Drum Brakes Squeak, especially in Reverse
  102. Is my axle in correctly?
  103. 2009 CRV - Engine stutters at red light/slow turns - next day dead battery!
  104. 1999 CR-V 4WD/AT Problems
  105. 1st gen CRV. Which motor mounts work?
  106. Sluggish, Awful Fuel Mileage..
  107. Alternator help
  108. Purchasing CRV: 98 or 99? Thoughts?
  109. Drivetrain problems after JDM swap into 97 CRV
  110. 01 CR-V tires
  111. Honda CRV 2005 noob question
  112. 2011 CR-V 11,000 miles already needs power steering rack replaced
  113. 2000 EX, A/T..First gear light doesn't "light up"..
  114. mistaking on opened Receiver Drier
  115. Cabin fan comes on and radiator fan starts getting weird..
  116. H2B CRV ECU question
  117. 3rd gen CRV k20 head swap
  118. DIY - CRV painted headlights.
  119. Lowering Rd1
  120. 2009 CRV Engine Vibration
  121. how reliable is CRV cooling system?
  122. Really bad fuel mileage
  123. NEED HELP!!!! SWAPPED JDM B20 AND IT'S MISFIRING
  124. code for 2008 CR-V radio-navigation?
  125. Mesh grills
  126. Will a 99 trams work in my 97
  127. Drivers side "low" beam headlight out.
  128. Throttle body cleaning
  129. JDM B20B side mount bracket problem
  130. Swapping GSR into 1st gen CRV and want to keep A/C.
  131. P0341 code on 2001 crv
  132. P0420 comes on and then shuts off???
  133. 97 CRV no crank, no start
  134. Will a b20 vtec fit in my crv??
  135. 2001 Honda CRV AWD - Misfire
  136. Rd1 rear wheel bearing help
  137. Replacing lower ball joint and upper control arm
  138. Funkster's 2000 CR-V
  139. B20B rocker arm placement..
  140. 2005 UK Honda CR-V headlight help!
  141. My 01 CR-V. From crashed and forgotten to...
  142. Pedal Adj Help...
  143. Bad tranny trouble finding a new one
  144. 2008 CR-V A/C Return air filter
  145. 2001 Auto CRV shifting/transmission issues and weird sound
  146. 05 CRV P1009 and 83-1
  147. 2002 crv how to change front drive axle shaft
  148. 98 Crv stalls
  149. Replace ignition cylinder in a Gen 1 CRV - DIY
  150. Honda AP2 front lip on CRV
  151. 2004 CR-V moonroof switch question
  152. 98 Honda CRV problem cranking
  153. CR-V electrical problem
  154. Hood bra
  155. Too Cool - 2002 CRV
  156. New crv owner here! Learn me on lowering
  157. Whine sound when key is turned to position 2..
  158. Remanufactured head wanted
  159. Car pulls in the direction it was last turned?
  160. Rough idle, what might be the cause of it?
  161. Low profile intake manifold vs high
  162. Help Needed: 2004 Honda CRV engine starting issue
  163. How can I read a transmission error code?
  164. DIY Window Tinting on CR-V
  165. 06 CRV OEM remote starter
  166. FYI: Door not opening from the inside
  167. Remove ignition cylinder 97 CR-V
  168. 1998 honda crv, help
  169. Catalytic Converter 98 Honda CRV
  170. 2001 Honda CR-V Interior Water Leak
  171. Engine light on and rev counter
  172. Install pics of catch can 2nd Gen
  173. "Idle Learn" procedure fails
  174. B Series Timing belt job, DOHC double trouble
  175. 98 CRV front brake pads
  176. A/C Compressor going bad after 1 year
  177. Looks like another TPS question
  178. K24A1 engine auto vs manual differences
  179. How close is the 97 civic and crv?
  180. New cr-v owner here! Any good websites to order aftermarket parts?
  181. Can my CR-V be saved? Or is it game over? :O
  182. replacing valve stem seals in k24?
  183. Accord coilovers
  184. labelone inc. crv DD rebuild
  185. Gauging Interest - North Georgia Soft-roading Meetup
  186. random misfires cyl 3 + 4
  187. B20 swap- Urgent ECU Help (37820-P3F-A61)
  188. Rear Fog Light 2005 CR-V Executive
  189. 2003 honda element software update
  190. Honda crv 2000
  191. P0123 & P1122
  192. honda crv 2003
  193. 2003 Honda CR-V grinding noise when AC is on
  194. 2012 CRV EX-L
  195. 2003 honda CR-V EX
  196. Adjusting valves 2001 CR-V
  197. One of the two front fans doesn't start
  198. 98 Cr-v with a lot of problems
  199. D2 spring rate SOFT!!!
  200. FLASHER RELAY UNIT honda crv 1998
  201. why is it so dang hard to find gen1 red/clear tails?
  202. 2004 CRV
  203. Quick Question: How does the horn work?
  204. troubles with b20vtec, non start in geo metro
  205. P1259 code 2002 CRV
  206. Thud when drivers side window reaches bottom on my 2009 CRV
  207. 03 Element Squeaking and Creaking
  208. 06 CRV A/C EVAPORATOR REMOVAL
  209. Auto Door Locks not working, two wires not getting power
  210. 01 Crv keeps throwing missfire code
  211. Need advice, 98 CRV motor sounds like marbles from 3k-4k rpm
  212. Front end noise
  213. 2007 CRV EX-L Creaking
  214. 99 CRV Has No Reverse Lights
  215. Element - Ash deposit, only one plug
  216. 2001 CRV Alignment Specs
  217. 03 CRV Fuel filter
  218. 04 Element electrical question
  219. engine stalls at idle or cold
  220. Brakes 2010 CR-V
  221. 2003 CRV LX - Power Locks Failed
  222. Live traffic for 2007 crv navigation
  223. 2000 Honda CRV
  224. 00 CRV oil leak 2.0 motor
  225. 2011 CRV Door Lock Malfuncation… actuator?
  226. 2003 CRV Engine Removal without Trans?
  227. 2000 CRV Shift Interlock Problem - Need Ideas
  228. Honda CR-V 2001 Spare Tire
  229. 04 CR-V Hunting Idle
  230. 1997 JDM CRV Rotors and Pads
  231. Looking for parts RD1
  232. Synthetic Oil vs Regular Oil
  233. 2004 honda crv oil pan replacement
  234. Iphone and bluetooth
  235. Need help figuring out tire size with a new lift! please help
  236. Looking radio diagram for 2008 crv
  237. Left wheel crunching noise
  238. My Gas Milage Is Horrible
  239. Rear Differential Mounts
  240. 00 Honda CRV engine sensors
  241. 2006 CR-V SE *A/C QUIT* DETAILS, FIRST POST! :)
  242. 2005 Honda CR-V dashlight issue
  243. NOOB CR-V Timing Belt Repair
  244. sub boxes?
  245. 03 crv no start after cleaning iac
  246. Need help with rough idle 98 CRV
  247. New RD1 Owner Checking In (Sort of a Build Thread)
  248. Honda CRV 2001 I can put it in parking.
  249. 97-01 crv
  250. My Naples Gold Rd1
