1st time engine removal looking for some help
Hello everyone. I have a 5speed 00 crv awd that I will be replacing a broken engine in. I purchased a jdm out of California. I am finding it difficult to find how tos video or info threads on how to accomplish it. I was told my engine has the rks sensor and that it will be a plug and play situation. From I have been able to gather I will be raising the vehicle and removing the engine from the bottom. I have questions as to what would be easier, removing engine and trans together or separating the engine from trans prior to removal. As well as what other components will I have to remove such as axel or any other suspension and drive train elements. Thank you in advance for any info.
Re: 1st time engine removal looking for some help
I just did mine last spring. Pretty straight forward .I dropped engine and tranny out the bottom together. Your should have the crank sensor behind the pulley ,check to see if your JDM has it,if not you'll end up swapping out the oil pump. Depending on what happened to your old motor you could use it. Also look closely at intake fittings ,I needed a vacume port that wasn't on the JDM .Also Several of the things on the intake would not match my plug ins. And my dizzy was different too.It sounds worse than it is ,just take your time and compare things.
MazworxRacing
Welding / Fabrication
40
02-04-2011 11:45 AM
NatedoggAZ
08-13-2007 08:23 PM
