2005 crv vibration at idle and takeoff
I own a 2005 CRV SE, bought it with just under 70,000 miles on it
At around 75,000 miles it started vibrating at idle, its 100% not an ignition issue, but I am having a hard time to pinpoint it.
Usually I would say motor mount, but most of the time I can get the vibration to go away using a floor jack, but have not been able to do that in this case.
I did replace all the motor mounts with AFTERMARKET mounts, which made the problem worse if anything, so I put all the oem mounts back in.
While they were out I did inspect them and the appeared to be good.
At about 90,000 miles I started noticing a hard vibration on initial takeoff from a dead stop.
The car does not vibrate after the initial takeoff, only then and at idle.
The oem mounts are about $500 for all 4, now I dont mind spending the money, but the last thing I want to do is spend that, and it not fix the problem.
In theory it should be the answer, but I'm not certain, and its a lot of money to gamble with if it doenst fix it.
Any thoughts?
Any thoughts?
sleepyhamsterlx
12-04-2003 07:35 PM
