PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24
  1. Honda element 2006 check engine light code p2646 faulty acceleration
  2. How do I know if I need to have my valve lash adjusted?
  3. Radio, Clock, & Dome Light stopped working
  4. CRV rear diff question
  5. most bang for the buck performance mods?
  6. Alignment questions
  7. Megan Coilovers.
  8. Confusing Timing Issues
  9. Engine Noise AFTER Timing belt install ??
  10. Access oil pan bolts - 2000 CR-V Automatic
  11. pinging noise mainly in reverse
  12. 2011 vs 2012 CRV
  13. steering wheel
  14. New crv highmiliage?
  15. 2004 CRV engine oil question.
  16. 2004 CR-V AWD. tranny question.
  17. Please help: Timing belt tension/slack adjustment
  18. Towing - Changing D3 to D4 in CRV
  19. 2012 CRV with Ivory/Charcoal combination
  20. 04 Element "flapping" noise under power
  21. crank spins but cam does not
  22. 98 CRV D light
  23. RADIATOR TROUBLE?
  24. Will TPMS from a 09 CRV work on 08 Acura TSX wheels?
  25. HELP! RD1 Rear parking mirror Install
  26. Project Skelement
  27. 1st Gen CR-V - Tranny-Questsions
  28. ID/OD 1st Gen CRV springs
  29. Honda CRV Timing Belt change Crankseal
  30. Just 1 picture for now...
  31. 03 CRV How to adjust shift cable
  32. 2007 CRV A/C Question
  33. '97 awd....complete steering rack needs replaced? leaking; and bad tie rod
  34. 2ndGen's CRV Daily Project
  35. Gas mileage loss with 215/75/15's?
  36. My ongoing Cr-v project/obession
  37. TSX Header on an 07 crv?
  38. which tire size would you choose and why???
  39. 1st gen CRV cd player, play burned CDs?
  40. how to rebuild your viscous coupler video.
  41. My 2001 v (Build Progress)
  42. how to make speedometer correct when using crv trans in a civic?
  43. Blown strut need replacement help fast!!
  44. 97 CRV, keyless entry?
  45. CRV ENGINE PROBLEMS
  46. Honda CR-V (2007-...) AC / Heater fan making noise.
  47. corner light problem
  48. First gen CRV
  49. Difference between 97-98 to 99-01 transfercase?
  50. Need to fix up an old CRV as a beater, have some questions...
  51. Clicking Relay & Central Locking when driving
  52. 2009 CR-V clock fast
  53. Oil Life Indicator reset
  54. Price error? LOok at this
  55. 98-clunk in fr. end.uca flange bolts?
  56. 2005 CR-V transmission remove
  57. 97 CR-V Won't Start
  58. 1999 CRV AC issues.
  59. 2006 CRV won't start?
  60. 05 element i'm looking to buy i need feedback
  61. 2003 CR-V immobiliser issues key light flashing
  62. 99 CRV - Sputtering / Hesitation under acceleration
  63. CRV Automatic - reverse grinds, forward gears work fine
  64. Timing Belt Failure: Damage?
  65. 2001 CRV problem filling up with gas, pump keeps stopping
  66. B20z and a better exhaust manifold???
  67. Element 2009 No primer under paint
  68. Question - Check Engine Light - VTEC System and Radio Reset?
  69. Would you like to import a JDM spec car legally?
  70. what transmission for my 95 eg civic hatch???
  71. DC Outlets Failed - 01 CRV
  72. blinking d after valvoline trans flush
  73. How to hook up 2004 CR-V Rear Defroster to an aftermarket Remote Starter?
  74. Finally, Pics of 2012 USA CR-V
  75. Fuse for clock on 2000 CRV
  76. aggressive tires on crv
  77. 98 crv loss of power...
  78. K-20 engine sluggish at 2nd gear(MT)
  79. Drop-in filter vs. SRI
  80. 2006 CRV Driver Door Will Not Open
  81. oil burning/oil loosing longevity and reliability
  82. Intermittant A/C
  83. Fastest Honda CRV??
  84. 2004 CRV 2.4 throttle surging and poping thru intake
  85. 2011 crv awd in snow
  86. CRV Seems Sluggish...
  87. 98 CR-V coilovers???
  88. Front lower control arm bushings
  89. 2006 CR-V with WEIRD Electrical Problems
  90. 2001 crv wing/spoiler
  91. HELP PLEASE! HONDA ELEMENT SHUTS OFF
  92. 1st gen asian/middle eastern front grille
  93. 99 CR-v K-Series?
  94. 1998 CRV high-load low-RPM misfires. Please help.
  95. Transmission Question...Help
  96. 97 CRV door harness wires breaking as usual
  97. Shift lock has to be realeased manually & no brake lights
  98. which coil-over's have a smooth ride for the 2 gen crv
  99. 98 Honda CRV AWD Transmission Issues. Help
  100. element wtb
  101. intercooler behind edm front bumper?
  102. 2005 CRV Horn and unlocking problem
  103. My 98 CRV Build, RT4WD Inside...
  104. What is that single click noise in dash from?
  105. suspension problem
  106. 2004 Honda Element LX CV Axle
  107. Lowering Spring Choice
  108. 2001 Honda Crv-check engine reads misfire #3 cylinder
  109. 2000 SRS code CR V
  110. engine locks up
  111. 97 Cr-v electrical problem with horn
  112. parts and accessories
  113. vtech install
  114. SRS light after stereo install. Wont reset.
  115. Multiplex control unit?
  116. 1999 CRV shifting problem
  117. Sam's 98 CR-V - HELP! Engine codes P0172 & P0170
  118. Wanted: RE4 Front Grille Moulding - Black.
  119. 2000 crv.......
  120. Boosted 99' 5 speed CRV!!
  121. 99 CRV Expansion Valve - Removing Blower and Evaporator Boxes
  122. 2003 Element EX loose driver seat
  123. Better brakes for a 2nd Gen CRV that tows
  124. 98 crv not smooth
  125. CLIMATE CONTROL NOT LIGHTING UP
  126. 97 crv will not start
  127. High pitch buzzing when car turned off
  128. first gen K swapped crvs?
  129. crv steering rack bad
  130. element stereo
  131. 99 CRV Rhino Lining
  132. Clicking sound from relay box wont stop, and car is unresponsive
  133. some crank pulley info
  134. 1st gen crv rear differential ratio question
  135. tie rod ends
  136. Cr-v On evo's
  137. Is it possible to......
  138. First Gen CRV sputtering and dieing while driving
  139. 2012 CR-V has a 2.5 liter with 201 hp.
  140. 98 crv engine swap walkthrough?
  141. 98 crv electrical issues
  142. Steering pump?
  143. transfer case question
  144. edm bumper
  145. crv 02-04 front lip???
  146. Noob with a 2001 CEV and 2 questions!
  147. CR-V specific F/S Wtb and wtt thread?
  148. sourcing a 1st Gen fullmark tailgate?
  149. gen 1 crv: not enough air coming from vents
  150. 2002 CR-V speedometer acting weird
  151. Door lock help.. searched
  152. vtec on a stock firstgen?
  153. CR-V with Weird Ignition Problem PLEASE HELP!!
  154. 06 exp element into a sc
  155. new vibration
  156. '06 Honda Element - Bad AC Compressor
  157. 3 New Starters Grind on my Elemenet. HELP
  158. Need help from you 95-95 civic owners
  159. boosting 04 crv
  160. 98 CR-V A/C hissing noise
  161. drive train problem
  162. 99 CRV misfires under hard acceleration
  163. CRV clunking in the front end
  164. 99 crv trans removal need some guidance
  165. 2000 CR-V Surging Idle
  166. 2002 cr-v driver's window problem
  167. Oscar and me :)
  168. lock issues
  169. Rear Differential - estimated costs for labor and parts
  170. 1999 CR-V condenser cooling fan question
  171. 1st gen Cr-v Poll: EDM Bumper vs USDM bumper which one do you think looks meaner
  172. 03 crv a/c problems.
  173. intermittent stuttering
  174. element water proof
  175. Mounting Yakima Tracks on an Element
  176. crv multiple misfires
  177. 95 CRV radiator Fan
  178. Addco rear sway bar (gen 1 V)
  179. Element CD player problems???
  180. 2012 CR-V Interior Pics - Looks NICE
  181. 1st Gen CR-V Buying Tips
  182. b20z vtec help? what head to use????
  183. CR-V bad vibration 45-65 then stops
  184. Common rust areas CRV
  185. 2010 crv vibration issue...any fixes?
  186. 1st gen CR-V eating distributors
  187. Ball Joint Squeak Problem!
  188. new wheels
  189. new crv owner few qustions
  190. 98 CR-V Timing Belt
  191. Service Bulletin 11-050 A/T Software Update to Prevent Transmission Damage
  192. how i put integra teins on my crv
  193. will any bseries auto trans fit my 99 crv?
  194. car loosing oil
  195. overflow boiling over
  196. Auto CRVTEC ???
  197. 2010 crv a/c and whining
  198. Rumbling Breaks + ABS Light
  199. help koni yellow
  200. TL wheels on Gen 1 fitment
  201. 2012 CR-V - Already destroying the Highlander and Lexus RX
  202. Honda CRV Starter Whining
  203. Ground Control Coilover for 1 Gen CR-V
  204. Cylinder head for 97 CRV?
  205. k-sport coilovers review...anyone? 99 CRV
  206. exhuast
  207. iPhone/iPod Integration CRV Help
  208. 3 person rear seat for Element?
  209. sterio in element
  210. New CRV guy here!
  211. p1457 on a 2003 CR-v
  212. 97 CRV Weak Air Conditioner on Highway Speeds
  213. What did you use to lower your crv?
  214. crv or element?
  215. Ac
  216. *** CR-V HELP*****
  217. Honda CRV Engine light 2000
  218. need advice on buy a crv
  219. 2003 Honda CRV valve adjustment
  220. Please help, Navi code
  221. Element Park Lock
  222. Element AC
  223. HELP - No Spark!?!
  224. 1st Gen with DC2 steeringwheel
  225. stripes on a 1st gen crv???
  226. 03 CRV overheating
  227. New CR-V spy pics
  228. Can gsr gearset fit in awd crv trans?
  229. CRV 1996 Overheating
  230. headlight chime 2002 crv
  231. Crv mantainence
  232. crv door power lock problem
  233. My 98 CR-V
  234. Tein coilovers
  235. Civic exhaust fit CRV?
  236. FOG LIGHTS
  237. crv 2007 change interio from cloth to leather?
  238. Help with overheating Element
  239. timing off
  240. Backup lights/clock
  241. Vibration turning sharply at low speed, But not when in reverse
  242. Black 1st Gen Crv 5spd
  243. suspension reference (99 crv question)
  244. how much power can the rear diff handle?
  245. Replacing rear hatch glass
  246. Lug removal 2000 CRV
  247. my project
  248. Steering lock solenoid or Brake switch? Can't get out of park
  249. 1999 CR-V Starts won't Drive
  250. Which cylinder heads are a direct swap for a 97 CRV?
