PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. What is best way to remove crankshaft timing belt sprocket, 2000 honda crv
  2. Oil consumption
  3. Crankshaft Timing Belt Pulley stuck
  4. 2002 CRV oil burn and leak
  5. 2002 CRV Fender
  6. 2010 CRV water pump? timing chain?
  7. 2005 CR-V overheating and a/c blowing warm air
  8. 2 liter turbo 4 in '18 CR-V?
  9. Element starter
  10. 2002 CR-V parking brake rebuild
  11. Crv oil pan replacement
  12. Shutter / shimmy on take off from dead stop -2002 Honda CRV AWD
  13. RD1 Rear differential replacement
  14. 2004 element seat pretensioner
  15. Engine light goes on and off
  16. Trailer wire connector 2002 CRV
  17. Coolant Leak?
  18. 98 Crv swapped standard no Reverse lights help please!- Beginning of crvtec swap.
  19. Engine knocking with AC on
  20. Front wiper stop working
  21. EVAP Control System Leakage
  22. Seek your opinion
  23. Compression testing a 2000 crv
  24. Power steering pump bubbles whines
  25. After market strut doesnt fit
  26. Honda CR-V 2.2 2013 HELP!!
  27. 2002 CRV-Reset Emission Light-now gas guage doesn't work
  28. 1997 crv 5speed bellhousing swap
  29. Key will not turn when in ignition
  30. 2017 Honda CR-V LX Headlight Auto-OFF
  31. CRV P Code
  32. SRS light not resetting
  33. Good Replacement Clutch?
  34. rev, stumble, rev a little more and stumble
  35. Stranger paired their phone to my 2013 crv bluetooth
  36. steering vibration
  37. 2017 CR-V Navi Lost Function
  38. 2000 CRV Engine sputters and dies.
  39. CRV 2017 trim
  40. 2011 Honda CR-V tires
  41. SAFE TO DRIVE 05 CRV P1077
  42. check engine light flashing on
  43. how to make turn signal click lower for hard of hearing on 2015 honda crv
  44. D1 SL Coilovers?
  45. Dead battery in 2017 Honda CRV touring
  46. Honda CRV Spark plugs
  47. Kpro availability for CRV Gen2 5 speed manual
  48. Rounded off bolt head to the serpentine belt auto tensioner pulley (2004 Honda CR-V)
  49. Squeaky noise while brake is applied
  50. 06 CRV rear spindle knuckle bushing install
  51. Dealership recommends hose kit service @ 90K
  52. 1999 crv another sway bar problem
  53. Honda CRV Engine Light and Manifold
  54. Engine 98 Honda CRV overheating
  55. MAX AC Stop Blowing Fast
  56. 2000 Honda CRV
  57. Best Fog Lights for 2006 CR-V
  58. 2005 honda crv vibration
  59. 98 CRV not restarting when engine is hot
  60. Blue tooth Connectivity Problems
  61. Honda CR-V 2010 sunroof shatters:why +who is responsable??
  62. 2014 Honda CRV - Grinding sound when starting even in warm temperatures
  63. 2004 leak
  64. 2006 CRV AC Compressor making me hot
  65. AC Compressor Switch
  66. Part Number or Name
  67. Looking for Chrome Beauty rings for stock wheels
  68. JDM or US Transmission
  69. 06 CRV, seized rear lower control arm bolt
  70. Max tire size
  71. Passenger door will not unlock
  72. 2002 honda crv brake bleeding
  73. Vibration on accelleration (2009 Element)
  74. stuck in reverse
  75. Element Front Seats
  76. 3rd gen CRV making weird noise.. help
  77. Can you resurface the rear brake rotors on a 2006 Honda Element?
  78. improving 2008 Element low beam headlight
  79. 01 crv steering rack fastening bracket
  80. 2010 CR-V Engine R20A iVTEC
  81. my first honda in a while
  82. 2003 CRV A/C woes
  83. 2010 CR-V, rear seat won't tumble forward
  84. SRS Code 62-01
  85. 2002 CRV high idle
  86. Cat Converter Broke Off, Yanked O2 Sensor Wiring, Problems Snowballing Since.
  87. 2011 2.0i-vtec engine knock
  88. Airbag fault 44-B2 and 46-22
  89. Need Help with K24A4 Swap?
  90. 2006 CRV life expectancy currently at 219K
  91. 2000 honda crv engine noise
  92. 2006 SRS light fix
  93. 1999 Honda CRV drivers side door latch
  94. Block Lift Kit Resources
  95. Diagram for driver door connector
  96. 2005 CR-V Check Engine + VSA Warning Lights
  97. CRV Steering Rack Boots
  98. CR-V rear differential question!
  99. honda crv 2004 reciruclation button is stuck
  100. CR-V K20A4 motor 2.0 liter sport variant
  101. Power loss
  102. Brand new Honda CRV 2017 EX – weird noise when car is locked and everything is off
  103. Air conditioner unreliable
  104. Loss of Brake Pressure Honda CRV (2005)
  105. 1998 CR-V Brake Problems...
  106. 2005 CRV Rear Brakes
  107. Life Expectancy of Aftermarket CR-V A/C Clutch
  108. 2008 crv bottom torque strut
  109. 2004 Honda Element -Idle Surging
  110. Honda 2005 CR-V: need key with buttons to open car and trunk
  111. 1997 Honda CRV Door Plug Pin diagram
  112. Honda Cr-V 2002 AT annoying sound under the dash board
  113. Honda crv starter
  114. Honda CRV Wheel Exchange CRZ
  115. 2010 Honda Element EX - Overheating?
  116. 2006 CR-V A/C not engaging when is hot outside
  117. Speed limiter 2003 AWD automatic?
  118. replace 2004 honda element ac compressor
  119. Used CRV to mod
  120. ABS Sensor Ring and New Axles
  121. won`t start after driving in the heat
  122. 2003 CRV ex ac issue
  123. 2007 Honda Element starter relay location
  124. 06 Honda CR-V water leak
  125. CRV 2010 speedometer
  126. 2004 CR-V cruise cluster light comes on, but won't engage
  127. Problems Starting on short stops
  128. towing 2010 Honda Element
  129. Radio Displaying A-Link
  130. 2000 CRV Timing Mark Jumping Around
  131. In-line transmission filter
  132. Help with maintenance intervals
  133. 2006 CRV Speedometer quit
  134. clutch judder
  135. 99 CR-V Front Subframe Swap
  136. Can't seem to get my Honda CRV 2013 bluetooth to turn on
  137. 2017 CR-V audio. Are 8 Speakers (EX-L) noticeably better than 6 speakers (EX)?
  138. Metal chips in transmission
  139. Started 2014 CR-V with no oil
  140. Vibration on highway 2001 Honda crv
  141. crv wont crank/start
  142. Extra harness on left rear speaker
  143. 1998 CRV Jumper Harness
  144. Cannot compress the caliper pistons (front)
  145. JDM 4th gen 'disk drive'
  146. HELP - Trouble attaching ball joint after new CV boots
  147. Immo diagram for CRV 2013
  148. Unexpected RPM Spike on Down Hill Coast
  149. 08 Element Engine Change
  150. 98 Crv Build log
  151. Honda CR-V 1998
  152. HOW TO CHECK COP FOR SPARK
  153. Mr G Neilon CRV D-TEC 2011
  154. crV 98
  155. CR-V 1998, heater works poorly in cold weather
  156. 05 CRV
  157. 2001 CR-V Clutch Issues
  158. Throttle Body Bolts (2003 Element)
  159. CR-V 2001 Hazard Lights not working - Turn Signals work fine.
  160. Swap engine only without removing trans 2000 CRV
  161. 99 CRV - Oil Pan Gasket leaks
  162. 2000 CRV severe wobble, rattle, clunking. etc. (all of the above)
  163. 2001 CRV Driver window stopped in up position
  164. SEM Bumper Coaters
  165. What is the name of my engine?
  166. TSX-K24 in 3rd Gen CR-V
  167. Need good info about 04 element
  168. 2000 CRV - Flashing D light and CEL (SOLVED)
  169. Sticking Brake Caliper
  170. Weather stripping doesn't clean windows
  171. CRV tables
  172. Do *clean* 1st Gen's even exist?
  173. 2017 CR-V dead battery
  174. 97 honda crv
  175. 2000 CR-V overheating
  176. 05 CR-V Leaking CV Joint Outer Boots
  177. Best/Worst Brands for New Half Axle-2005 CR-V?
  178. 2014 CRV interior rain water leak
  179. VTC_Actuator
  180. water leak
  181. 2008 element "black box" electronic chip ?
  182. 2003 CR-V Transmission Swap
  183. Transmission fluid change 2008 CRV...How Much?
  184. 2002 CRV Driver's side window regulator terminal pinout
  185. 02 CRV
  186. 2005-2006 CR-V Transmission type??
  187. Where to find wire for interior/dome lights - 2006 CR-V
  188. AEM V2 in 2002 CRV
  189. Everett Garson
  190. CRV (2004), windshield sprayer clogged
  191. Replacing Rear Knuckle to Lower Control Arm bushings on '02 CR-V 4WD
  192. 1999 CR-V just dies, no warning
  193. 2005/2006 CR-V 5 spd. manual transmission type?
  194. 97 crv 4wd custom lift
  195. honda crv 2005
  196. DRL and high beams not working
  197. 2017 CR-V dead battery
  198. Need help, CRV wont move!
  199. 2001 Honda CRV Starter turning flywheel but no crank
  200. Wheel Alignment and a Frozen bolt
  201. Fairly New Issue
  202. What is the factory wheel back space on '03 CRV 4WD
  203. 2003 CR-V ideal back spacing for slightly larger tires without lift?
  204. will a a/c bracket mount from an integra work?
  205. honda crv 1998
  206. 1999 Crv, how do I reinstall torque converter
  207. 2003 Honda CRV 2.0L Rvsi
  208. valves
  209. '99 CR-V: complete transaxle fluid change out?
  210. Rear passenger side wheel locked on 1997 Honda CRV
  211. Gen1 CRV Vtec Pinouts?
  212. Weight of stock wheels on 06 crv
  213. 2010 CR-V : Oil Completely Gone After 2,300 Miles
  214. 1999 CRV needs transmission, JDM yes or no? I cant find a straight answer..
  215. 2016 Honda CRV wont' start
  216. CR-V 2015 Odometer mph to kmph and F to C
  217. 110k maintance
  218. 1997 CRV 4wd Transmission Issues
  219. Which code to address first
  220. 2003 Element not shifting out of park,no break lights or horn
  221. A/C stops blowing cold when it's hot outside (above 80 f) - 2007 CR-V EX
  222. Two long beeps while driving Honda crv mk2
  223. turn signal Relay on CRV 2016 LX
  224. 2004 CRV Codes PO135 PO341 Engine light
  225. 2007 CR-V Alarm won't turn off
  226. 2010 honda crv excessive oil usage
  227. Ghetto Alarm Install = No Horn or Cruise
  228. Accessing Airbag Module in 2005 CRV
  229. 98 CR-V Engine dies
  230. '03 CR-V variable vibration?
  231. 2011 CRV Dome Light wiring diagram
  232. 2009 CRV EX-L AWD - slight whirring sound while idling after starting
  233. Mounting LED Bar on 2003 CRV
  234. Honda Crv whining noise under hard acceleration
  235. Keyless Access System
  236. Grinding noise on 2015 CRV
  237. Wheel Rim Color - 2011 CR-V LX
  238. 2004 crv P1077 after motor swap
  239. P2646 & P0011 Codes, 2003 Element
  240. ac honda crv 2006
  241. 2010 Honda CRV will not shift out of Park. Will not start. Brake switch is good.
  242. CR-V 2017 & Pilot 2017 wheel base
  243. Dome light issues 05 Crv
  244. Fuel issues. 2003 crv
  245. LED Instrument Panel Light Swap
  246. CRV 99 revs stay in 2000 during uphill no matter what kind of uphill
  247. 2007 Honda CR-V hard to start
  248. 2007 and up CR-V a/c compressor question
  249. smart key system indicator light
  250. 2005 CRV - Power Door Lock switch
