PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24]
  1. b20b in '00 CRV - Compatibility Question
  2. Help remove rear Knuckle
  3. help, '02 CR-V vtec solenoid issue!!
  4. 03 CRV Bad O2 Sensor
  5. Bou's 98 CRV build thread.
  6. Integra GSR seats in a CRV
  7. 07 honda element gas mileages
  8. 1st Gen CRV's radiator question....
  9. Power steering problems
  10. 2001 VR-V driver door wont open from outside
  11. Tire choice
  12. CRV floor mat interchangeability?
  13. nameplate tire PSI too low?
  14. Replace k24a1 with k24a4? Can it be done?
  15. Converting headlamps from LHD to RHD
  16. Buying 2002-2006 CRV-things to look for?
  17. B20b piston
  18. Rubbing/Vibration on Element
  19. 2000 crv rear window washer problem
  20. New Member looking to do a light/moderate build on a 2000 CR-V
  21. I NEED A 97-01 CR-V CARGO COVER
  22. High mileage CRV, anything to look for?
  23. 2002 honda cr-v no ac
  24. How much power..?
  25. 2005 CR-V 100k Maintenance
  26. CRV JDM LOOK
  27. Cold air intake?
  28. ENGINE TURNS OVER BUT NOT FIRING?
  29. How do I tighten up my driver side sun visor?
  30. 2003 Honda CR-V EX RPM's keep going up
  31. Speedometer lighting messed up
  32. 02 2.4 crv serpentine belt help!
  33. Need help in identifying manufacturer of keyless entry remote
  34. Honda CR-V 2010 LX 2WD
  35. 2011 CR-V Wheel Specs?
  36. 2000 crv 4wd Horn problem
  37. Solenoid shifter question
  38. 01 CR-V timing belt replacement write up?
  39. 99 CRV
  40. future build thread of GT28R CRV
  41. 2000 CRV will not crank
  42. Rubbing sound when turning
  43. 98 crv not starting
  44. 2000 Honda CRV help. Swapped Motor
  45. 2000 Honda CRV ignition problems
  46. ecm/pcm relay fuse
  47. New member with some questions
  48. 2002 CRV (K24) IACV location?
  49. stolen catalytic convertor ELEMENT SC 2010
  50. 99 crv radio pinout?
  51. Engine no on CR-V RD7
  52. 99 CRV Trouble Starting + Overheating
  53. 98 CRV Base Timing
  54. B18b1 into a CRV?? is it possible
  55. Honda Élément 2009 VSS
  56. Carburetor Conversion for a 98 CRV
  57. first gen CR-V, exhaust valves, and you.
  58. Rear Caliper Piston (passenger side) won't fully compress
  59. 2010 CRV
  60. crv having problem
  61. 1st Gen CR-V HEADER..
  62. 2002 Honda CRV - Rear end leak?
  63. 98 honda crv engine error codes
  64. 1997 Honda CRV With 343,000 Miles...
  65. crv fender mirror?
  66. Honda Access Visors for CR-V, do they exist?
  67. B20b HELP!!!!
  68. Suspencion Sounds
  69. 2001 CRV A/C Question
  70. Need some help.
  71. 2000 RPM Engine shudder
  72. Buyin a crv advice
  73. they made an ex/se crv???
  74. What is reasonable price for a 97-00 CRV?
  75. Have you noticed your CRV igition timing?
  76. Supercharging my wifes honda element?
  77. did they make a first gen CR-V SE with a manual trans?
  78. my 1st gen cr-v on si wheels couple ? too
  79. Front Brakes Honda 2004 CRV
  80. Honda CRV Key fob case
  81. 2001 CR-V makes grinding noise when accelerating
  82. 110K no transmission fluid change
  83. finished the gsr 5 spd swap... check it off the list
  84. bogging while using my a/c
  85. Has a 230whp + setup been done in a 2002+ crv? Or can it.
  86. CR-V engine change 2000
  87. *Official H-T CR-V Thread*
  88. 97 crv help is needed
  89. My 01 CR-V
  90. 2002 Honda CRV reliable?
  91. 98 crv ingnition lock
  92. zc alternator replacement bolts and bushings?
  93. 2001 CR-V Seat swap?
  94. Help: 97 crv backfire?!
  95. Brake light on CRV 05
  96. 2000 EBP CR-V Wheels and Tires
  97. Shaking probelm on 97' CRV
  98. 09 CR-V 2WD Trailer Hitch recommendations
  99. radio code
  100. 07 CR-V Radio Code & Navigation Code
  101. 1998 CR-V assistance.
  102. Theres a ticking noise coming from the crank pulley!
  103. - I hear a ticking noise near my crank pulley. What could it be?
  104. Element Owners (Older Models?) - Are Your Doors Flimsy When Closing?
  105. Element Owners - List Your Frustrations (if any) and Complaints
  106. Tail light assembly - how do I replace it?
  107. Replacing exspanion valve in my 2005 Honda CR-V
  108. Exhaust
  109. ^^coolant spilling on crv!^^
  110. my red 2000 crv
  111. Hi, New to Forum.
  112. 97 CR-V electric fans not running
  113. 04 CRV brake light bulb burnt out... or not?
  114. just a few questions on parts for my 97 crv
  115. Misfire code won't go away? WTF?
  116. CRV - Replaced head with LS Integra head Question
  117. 1st Gen CRV DIY Complete Color Change
  118. CRV headache continues
  119. 2000 CR-V keyless remote headlight flash
  120. 01 crv ac compressor same as all b series?
  121. A/C clutch will not engage on 2002 honda crv
  122. only in bermuda ...
  123. CRV noob
  124. Post pictures of your first gen CR-V project.
  125. 00 crv rear sway bar end link
  126. 2000 crv - rear differential fluid?
  127. What's better for modding? 1st or 2nd Gen CRV
  128. Flashing 'D' on my '02 CRV
  129. O HAI... check out my V :D
  130. HELP! 911... b20b head rocker arm
  131. Honda CRV Brake question
  132. Replacing O2 sensor on 04 CRV
  133. Civil's CRV
  134. 97 CRV head problems
  135. 00 CRV Cruise Not Working...
  136. 02 CRV questions
  137. 2004 CRV Needs A/C Compressor
  138. helping my dad buy a new CRV in MD/VA/DC area
  139. Do 97-01 Crv's have problems with valve adjustment?
  140. 2000 Honda CRV oil pan gasket
  141. Where to find clean CRVs?
  142. Honda re-manfactured CRV transmission
  143. RX729 Supercharged CR-V RT-AWD 5-Speed
  144. CRV blower motor resistor
  145. my 2000 crv EX.. dropped on green rota boost
  146. Looking to buy a 1st Gen CRV, anything to look out for?
  147. 97 honda cr-v p0170 and p0171
  148. TwoSevenFive's 98 CR-V
  149. 98 crv bogging miss firing & bad idling
  150. 02 CRV A/C Condenser Replacement
  151. 02 CRV no ac help please!!!
  152. JDM/EDM parts for 1st gen crv?
  153. our 97 CR-V
  154. 1st gen cr-v front & rear camber kit???
  155. how to remove bumper on 98 cr-v?
  156. 1st Gen CRV Motor Mounts
  157. My new crv project $500 daily driver
  158. is there a trick to activate a constant AWD in a crv?
  159. 99 crv door lock actuator
  160. 02 CRV Serpentine belt
  161. 5 speed crv?
  162. My 2000 & 1997 CRV
  163. CRV Rear drum brakes!!!
  164. My lowered black crv
  165. ***OFFICIAL Element Thread***
  166. 2002 Cr-V Idle problem
  167. www.MegaMeet.org's Build Thread
  168. my 99 white CRV
  169. 2000 CRV blower wont shut off ????
  170. Honda Element & CR-V Pictures
  171. crv with civic coilovers
  172. angas_V ('99 crv)
  173. Official H-T CRV thread!
  174. CRV headlight warning buzzer
  175. 03 CRV---Why SRS light is ALWAYS on!!
  176. question: will rsx-s rims fit on a 2001 cr-v?
  177. lowering springs for 97 crv
  178. 2005 CRV blower motor won't turn on - sometimes
  179. 98 CR-V - Flashing CEL, P0301
  180. b20 VTEC torque specs???
  181. 1999 crv door lock problem - actuator or control unit?
  182. Honda Element and Hondata K-Pro
  183. ysk 3 ?? jdm b20b trans or??
  184. How to lower a CRV?
  185. CRV lift kit or bigger tires? off roadin
  186. CRV Shuts off while driving...restart immediately
  187. CRV 1/4 time?
