View Full Version : Honda CR-V & Element
- Camber Kit?
- First Gen Cr-V Mods!
- First Gen CR-V Fog Lights?
- 2nd opinion 2007 CRV AC Issue....
- 99 CRV Stalling while driving
- Electrical Expert Needed - 05 CRV
- 99 crv build
- factory fitted alarm
- 1st gen fuel economy?
- Breather tubing
- Tailgate latch stuck-door wont close
- Radio Codes
- Transmission - cold start
- HVAC smell when cooling, not when heating
- 2000 honda crv... spark fuel compression
- Idle too low with AC on...
- boosted crv
- how often add coolant
- 2007 CRV convert to 4wd...what's needed?
- Prolonged Cranking 2004 Element
- Turd's 98' CR-V Build. STD free!
- Just picked this Element up...
- Here's a new one for you guys...I think
- 2003 Element cooling and condensor fan motor replacement
- Crashed Cr-V
- CR-V JDM Tranny Swap
- 2000 CRV AWD w/5 speed- compat. with civic suspension parts
- my boosted CRV build thread
- AC intermittent: works fine @idle, cycles while driving. help?
- Whats a good aftermarket crv muffler?
- Center console possibilities?
- how is this setup?
- 2001 Honda CR-V Transmission - Auto
- 02 CRV AWD Rear Axle / Hub Removal?
- 0420/yup.... what to do, what to do
- Muffler hotter than Cat?
- AC compressor Viscosity and Charge
- crank sensor on my CR-V
- 98 CRV power window control module
- element with cold start issues...
- GEN 1 AC COMPRESSOR REPLACEMENT
- 05 CRV AC problems
- 2007 CRV A/C problem
- This should be stickied. mobile online service manual for 1st gen cr-v
- 1997-2001 CR-V Traction Bar Group Order.
- Ignition Switch Bad?
- CRV build Power Steering
- Jdm CRv parts
- 06 CRV getting low gas mileage
- My 5 speed 1st Gen CRV Rebuild
- Flywheel cover plate
- 98-99 engine and AT compatability
- Main Relay vs. Fuel Pump
- 98 CRV crank pulley wobble
- 2001 CR-V Shakes When Breaking
- Failed smog, high HC at idle
- Cyl 4 Misfire.. Possible Causes?
- 2004 CR-V condenser fan motor
- In the Market for a CR-V..Need Advice
- Condenser Fan Trouble
- 2005 Towing Capacity
- first gen jdm crv
- 2008 Honda CR-V compliance bushings
- Get Low
- blown head gasket
- help: heater blower motor not working.
- Refrigerant recommendation for CR-V 2003 EX
- A/C Woes.... (Low side high, High side low?) Any A/C Experts?
- having trouble putting car into gear
- Intermittent A/C
- Help with decision on replacing timing belt in 2001 CRV
- 01 CRV 0verheating
- 2002 CRV Air Conditioning
- Night shoot of my Nyce-Box (Element)
- 97-01 CRV Short Shifter: How-To
- 2002 Honda CR-V not starting. Alternator? Starter?
- Civic grille on a first gen V?
- Suspension question (1st gen CR-V)
- Gen 1 cr-v horn dead
- Introduction and CRV Rear Strut Issue
- My '01 5-speed CR-V
- buying a crv and wheels(Xxr527) I believe,next paycheck can someone please help..
- honda element 2007
- jdm power folding mirrors help!
- Help need code to start radio in ontario?
- 2002 cv-r
- Loud Air Release Hiss when I accelerate Honda 2000 CRV
- my slow bugout project
- Please help 2002 CRV automatic
- Aftermarket ITR brake components for CR-V RD1?
- 1997 CRV with ABS: brake pulsing at low speeds just before stopping
- 97-98 Trans fit 99-01 Honda crv??
- Lift kit gone, new wheels on!
- A/C Problem.
- 07 cr-v creaking in park
- Sticking/bumping sound after sitting overnight
- Radiator Problem
- 1st gen running boards, anyone got these?
- Hubcentric wheels
- Cooling fans
- motor mounts for 1st gen CRV
- '97 CR-V - Could use some help, stuck in "1" & "2"
- 99 CRV compressor cycles once, then stays off.
- warm A/C at idle 2006 CRV
- I need help with this noise. Video included.
- unknowncrv's 1st gen
- 1997 CRV won't start (turns over) & oil lights are on - please help!
- Neglected CR-V
- H&R Springs not quite low enough
- 1st gen CRV oil pan question
- U joints
- 1st gen auto to manual wiring help
- 2000 CRV hard start when warm
- Coilover Options for 1st gen CRV
- 1st gen wiper blades
- 01 CRV Doorlocks and Dome Light Issues
- '09 element lurch fwd while coasting - caused accident
- 05 CRV Headlights Keep going out
- Boosted CRV
- back hatch gate handle sticking
- 1999 crv ex power door lock problem
- whats wrong with my alarm
- ABS light on occasionally? Brakes grinding?
- Crv door components keep cutting out
- ac compressor clutch coil failed again
- Anyone every tried Skunk2 Coilover Sleeves?
- SWAP b18c1 in CR-v 1 gen AWD 5 spd
- 04 crv springs
- battery charged, but still won't start, no lights....
- bad coil tested ok with ohmmeter
- CR-V REAR lower control arm bushing part number
- ABS Issue
- 1999 CRV whining/grinding noise
- 00 crv Auto to manual swap,Transmission bracket help
- Grimlock
- IAC ADJUSTMENT SCREW doh!!
- A/C compressor and low freon
- Colorado Mountain Rally Intake
- Keep it simple? Or have fun with it?
- Acura RDX SH-AWD K23A1 Turbo 240Hp Swap possible?
- wiring diagram, 2004 honda CRV, Headlight Circuit
- Evo8 wheels with 225/60-17
- Help! Honda CRV dies while driving!
- b20 sleeve
- Just changed spark plugs and....
- lips for first gen crv
- stronger front axles
- Quiet Exhaust system/muffler?
- whats an oem g1 roof rack worth?
- Shop Manual 2012-2013 CRV
- Pricing quote on lowering a Crv?
- b20z obd2 tuning
- Help with gsr in my crv!
- In 4WD or Not
- My CRV Build
- 2000 Honda CRV Front struts and coils>>>>
- sunroof
- How to fix/change e-brake?
- Why does Honda CRV only start with boost?
- My Stanced Element... NYCE-BOX
- CRV Blower all screwy
- 1998 CRV Crank Compatibility
- 1st gen tail gate shave?
- new radiator source
- Not as smart as I thought: SRS light on all the time.
- 2004 CRV- 3rd Cylinder Misfire Code
- 99 crv problem
- 97 CRV A/T p0700, p0730, p0715. HELP!
- Opinions on full body coilovers
- damn door hinge wires broke...
- civic springs
- A slow and simple build
- 97-01 CRV Black Housing Headlights
- How To: Replace radiator in 5 speed 97-01 CRV
- Cooler tranny fluid help
- 2001 CR-V 5 Speed VSS Location
- 98 CRV head gasket
- civic coils on crv
- 2001 CRV west one, UK
- 00 CR-V rear lower control arm
- What size tires?
- crv slow crank in morning only
- Swaping Stock Wheel Studs for Extended Studs
- Crv 2008, P0341, what to do?
- Speaker wiring through door
- 98 CRV Stalls/Burning Smell
- 2006 Element throwing codes-p0010 and p1009
- squeezing more power from a b20z
- 1st Gen CRV specific issues?
- A/C fan and freon presssure questions....
- My '00 CRV. :)
- '01 CRV with codes P0700, P0730
- First gen CR-V front lower control arm bushings
- off topic eibach meet
- removing cd player from dash
- DASH LIGHT BRIGHTNESS CONTROL WIRING?
- what camber kit do i use for my 2000 honda crv?
- b20 vtec ecu help
- 2000 CRV WANT TO UPGRADE MOTOR
- jdm b20b erratic idle
- Few questions for the lifted CRV's...
- broken abs sensor wire
- 01 crv cold air intake help??
- 00 CRV shifting very odd
- Replaced Blower still no real air movement from vents
- Best A/C compressor for 2004 CR-V
- 99 CRV Passenger side water leak
- power steering question on CRV 2008
- bluetooth in CRV not working
- Low Offset Wheels on CRV
- 2006 Honda CR-V Intermittent No Crank Condition
- CRV B20B timing belt broke
- knocking noise - rear drivetrain
- Keyless Entry
- Problem with navigation system
- Need Help Removing This Bolt ADVICE ANYONE
- CR-V 1997 (UK) - ABS Indicator No DTC, but on.
- My 98 CRV 5spd rt4wd. H2B inside.
- 1st Gear...
- P0108 CODE after removing APEXI VAFC
- 99 crv squeak
- Honda Element Intermittent Starting
- 2001 honda crv edm bumper???
- newbie 2000 crv
- Finally dropped my V and threw my rims back on...
- CRV and Integra catalytic converter the same?
- Amsoil Power Steering Fluid
- 1999 crv doesnt want to start
- first gen crv sway bar
- Dorman window regulators ok?
- 1st gen Rear hub 4 lug Question
- smh
- Honda sold a NEW Element - March 2013
- 1999 CRV B20B eng. JERKY ACCELERATION
- b20 head?
- Willes ITR CrVtec Build
- anybody else running their cRv @H.D atco?
- crv automatic transmission fluid advice needed
- M/T CRV CLUTCH MOD FOR SOFTER PEDAL FEEL
- Crv 4wd Header. To Stay Away From.
- 1998 CRV Automatic problems
- Gen 1 CRV not starting
- 1st Gen CRV B20 Fluids brake coolant transmission differential oil
- newbie needing assistance. .
- Anyone heard of FCS?
- 2005 CR-V rear door remote
- My 5-speed 1g V
- Help! '99 CR-V key stuck in ignition
