PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24
  1. CRVs wheel galore
  2. Tell me about the 05-06 CRV AWD
  3. B20 low idle
  4. Smart awd
  5. whats needed for b20vtec on automatic crv awd?
  6. Honda CR-V 2002 Burns oil & RPM goes up when idling
  7. Mamba M 5 Wheels for 1st Gen CRV
  8. CR-V B20Z from Croatia
  9. buying 96-2001 crv what to look for?
  10. yonaka cheapy coilovers for cr-v are cheap-anyone used or feeling brave?
  11. 2008 SI wheels on an 09 CR-V..any problems?
  12. Wifes daily
  13. low rpm sputter on acceleration plz help
  14. '03 Element AWD rumble when sharp turns
  15. 5speed 2001 Honda crv transmission rebuild advice
  16. can some1 check how the pin colors go in speed sensor 99 crv
  17. Remote/FOB Instructions?
  18. Video of 97-2001 CR-V Front Strut Installation
  19. Regular operating temp
  20. Engine oil get in combustion chamber (fuel)
  21. Euro Bumper
  22. My 99 CRV
  23. Brake Fluid leaking, how bad is it?
  24. No torque converter lockup 2000 Honda CRV (1st generation)
  25. Propeller shaft assembly
  26. Air Conditioner Myth or fact from dealership?
  27. Looking for houston honda owners...
  28. Electrical Problem- 2002 CR-V
  29. Anyone figure out how to do rear disk on 1st gen crv yet?
  30. CRV EX VTEC AWD
  31. help with 98 crv. not starting!!
  32. 2003 CRV A/C Compressor Clutch will not engage, troubleshooting
  33. First Gen CRV high-beam/low-beam problem
  34. 1st gen crv turbo vs. civic si
  35. Best Spark Plugs
  36. 2002 CRV Serpentine Belt and Water Pump
  37. Replacing rack & pinion?
  38. CR-V Condensor and Radiator Fans inop
  39. b20b swap in my 99 cr-v will it work? What issues will I run into?
  40. CRV I HAVE A PULLEY ?
  41. 04 ELEMENT READING CEL CODES WITHOUT A CODE READER
  42. D2 Coilovers for 1st Gen CRV
  43. 2013 CR-V
  44. 2 gen crv with 20''s
  45. First Gen CRVs that are actually slammed?
  46. 99 CRV possible cylinder head problems
  47. 5th gear swap?
  48. Notorious 2nd Gen CRV AC problem
  49. ***FIRST GEN CR-V SWAP OPTIONS...HELP!***
  50. CAMSHAFT POSITION SENSOR ON 04 ELEMENT
  51. CR-V wacky overdrive.
  52. can't shift out of park after engine swap 03 honda element
  53. jdm b20b p8r-8 vs p8r-11
  54. CR-V Exhaust Pipe Photo - 1st Gen. ?
  55. What's the best year CR-V to buy?
  56. 1st Gen CRV Gas Mileage
  57. what the best individual throttle body for my b20b block b18c head?
  58. b20b p-75
  59. ABS only CV joints
  60. Fuel pump - Honda CRV - 2011
  61. 2wd or 4wd...Clearance issues?
  62. 17" steelies?
  63. Location for first gen side markers...?
  64. edm black housing f/s rare
  65. M4TA Automatic 97 CR-V
  66. 2002 cr-v light-on reminder chime
  67. What full coilover setups are reliable?
  68. how much oil to use on moroso pan
  69. 2002 Honda CRV Intake Manifold
  70. Check out my sweet new mods to my wifes Element "crash pics inside"
  71. DIY: 2005 CRV Fog Lights instal with no switch
  72. 1st Gen CR-V Exhaust Manifold
  73. CRV Running on two cylinders
  74. Passenger Side door Buzzing when Locked
  75. Having A hard time deciding
  76. SLAMMED CRV CLEARANCE AND RUBBING ISSUES
  77. my 1st gen crv
  78. Ironman Lift springs vs. Old Man Emu?
  79. Honda newbie, recommendations for what to look for in owning CRV
  80. Transmission Rebuild + Separate Radiator
  81. Modifying Shifter 2005 CR-V
  82. 2012 CR-V Part
  83. does any one need tyransmission parts or transfercases?
  84. Introduce myself and my 2005 CR-V EX AWD
  85. Replacing radiator core support on 97 CRV
  86. 1998 crv ball joint
  87. 2006 CRV
  88. Grille for '04 honda element?
  89. Where to buy Head Studs/Bolts for my 1999 CR-V
  90. 98 CR-V won't start help pls
  91. GSR B18C1 into a 2000 CRV
  92. 2006 Honda Element EX Keyless Entry Questions
  93. Turbo Integra to CRV- what is the weak link?
  94. 2003 element dx fuse for speakers
  95. What in Dash and Kit are you guys running?
  96. 98 CR-V 5speed Handle Better
  97. K20A and R20A transmissions
  98. cr-v build?
  99. honda crv 04 starting problem
  100. 2002-2006 Honda CRV Performance Thread
  101. correct tap size for b20b head bolts?
  102. B20B Compression test
  103. 2005 CR-V EX.. Is Regular fuel ok?
  104. b20b b20z info on crv
  105. Is it worth repairing my 99 CRV?
  106. 04 element starter
  107. civic strut will fit 1st gen cr-v?
  108. Intermittent no spark issues DRIVING ME CRAZY
  109. OBDII Codes for 1997 CR-V
  110. My 98 4dr beauty, any one wanna give some advice??
  111. 2001 CR-V Front Suspension Creaks Over Bumps Only When Cold
  112. I have a question about suspenion
  113. 98 CR-V CEL Comes on after Highway drive?
  114. 1st gen undercarrige question
  115. No power to radio/OBD II, pwr door locks, key fob, more
  116. d16 cr-v
  117. 2012 CR-V wins Comparison
  118. I'm new to the sight and here's my "VCR" story
  119. b18c5 headers will fit b20?
  120. 2003 Splash Shield
  121. Transmission model?
  122. Where can I find my V's Keyless entry Module?
  123. HELP! Check engine and blinking D4 light
  124. Starter problem
  125. crv trans and rear diff wtb
  126. 2007 CRV Instrument Panel Fail, HELP!
  127. 1st Gen 97 CRV powertrain problem
  128. Phantom Grip LSD in AWD CRV?
  129. Savannah Ga. 2001 CRV RT4WD 5sp
  130. Ways to Lift you 1st Gen Cr-V
  131. 2007 CR-V Door Lock Sticking
  132. 97-01 lower window trim replacement?
  133. Skunk2 Pro-c from my 2001 integra to Honda Cr-v
  134. My 2000 CR-V (^__^)
  135. 2003 honda element engine swap
  136. 99 CRV Project
  137. How much better is the AWD than FWD in CRV?
  138. 1999 CRV vss Wiring
  139. Ok, so I'm new here but....
  140. Might be parting out my CR-V
  141. New guy here! Was just given a '99 crv, need to know if the trans is failing?
  142. 25mm sway bar question
  143. oil life display
  144. 1st Gen Keyless entry
  145. What's the skinny on the 97 CR-V
  146. 04 crv dies after foot on gas
  147. Propeller shaft removed X 2
  148. b16 head and b20 intake will it work
  149. b20vtec swaping into crv
  150. Oil Level Problem need help......
  151. 97 CRV Idling Is Rough Despite A New AICV!
  152. 98 honda cr-v awd problem
  153. 08 CRV Locks not working
  154. Key won't turn in ignition.
  155. 2003 Honda element ignition cut relay buzzing
  156. Wind problem
  157. Slight shake in steering wheel at 60mph
  158. Pennzoil Synchromesh...yay or nay?
  159. crv se, gt edition
  160. blew a bulb now prob with drl
  161. Crv No Spark AFTER 5 speed Swap
  162. Benefit of bigger tires?
  163. crv 2007 ground level clearance
  164. Getting back into the Honda scene! Just got a 99 CRV!!
  165. Any Good Links To Rebuilt Motors?
  166. Crv AWD Question
  167. Strange Sound From My 97 Crv
  168. valve cover plug leak
  169. 99 crv maintenance light on
  170. Converting a 2wd to AWD 01 CR-V
  171. 2006 CRV at, K20 to K24 engine swap?
  172. identify if i have a high or low comp b20b
  173. couple questions on buying a 01 crv
  174. element idle issue fixed ?!?
  175. Honda Pilot Help
  176. 98 crv power locks stop working
  177. Flashing CEL... i am stumped
  178. My 07 CRV... The family car..
  179. Is a 99 CR-V head a p75-9?
  180. 1971 Land Rover with the heart of a CR-V
  181. Temperature gauge jumped into the red
  182. 99 crv
  183. 98,99 crv transmission diffrent from 00,01?
  184. Keyless entry question
  185. Check Enginer Light On: P0118
  186. 2001 CR-V Driver Side Door Lock Problem
  187. SRS light after visit to dealership
  188. CRV Lights and Painting
  189. Exterior Windshield Side Trim - 2008 CR-V?
  190. Pulling fuses while towing a CR-V w/ 4 wheels down?
  191. difference between 97-01 ex and lx
  192. It happened to me - don't let it happen to you...
  193. 03 crv hood stuck closed
  194. Need Tire Advice On My CRV
  195. civic wagon to crv?
  196. 97-01 CR-V leather!!
  197. crv overheating?....ugh
  198. Would you avoid AWD CRV's?
  199. Ls-V Sawp into my 00' Cr-v
  200. hey guys im looking for some specific help 94-97 accord tien full susp. 99 cr-v
  201. 2002 CRV Multiplex control unit
  202. 2008 honda crv parking lights wont turn off
  203. CR-V and weight reduction, how low can you go?
  204. Driving with rear window up
  205. 1998 2WD Honda CR-V. How to make it 4WD
  206. s2000 seats in my crv
  207. 97 CRV key getting stuck
  208. 2011/2012 Honda CR-V
  209. Check Engine Plug Location for 2 Prong Jumper?
  210. disc brake conversion on 1st gen crv?
  211. 1st Gen CR-V Rear Spring Rate
  212. 1st gen crv back handle
  213. 1st gen crv back handle
  214. elmoEF9's CRV project
  215. 1997 CR-V overheating! (new thermostat, new sending unit, fans working when shorted)
  216. Transmission fluid change
  217. Anyone used a liquid repair for coolant leak?
  218. Replacing Rear Door Small glass HELP..
  219. '03 CRV at PepBoys now and batt light still on after new alternator.
  220. Anybody knows this, pls help?
  221. P0135
  222. few problems with 2002 honda crv
  223. 2008 crv intake??
  224. Problem Bleeding CRV (put old Master back in, and it works)
  225. new wheels
  226. 2000 CR-V Motor Mounts?
  227. 98 cr-v not charging
  228. New tires 1st gen
  229. where can i buy 1st gen cr-v bumper with fog lights ready?
  230. 2011 CR-V iPhone problems
  231. Looking to buy an Element
  232. Another CRV TPS Issue
  233. 97-01 honda CRV rear cargo cover
  234. 2003 Honda Element sometimes won't start
  235. My turbo Crv Build in progress!!
  236. How do I check my timing?
  237. About time for my build thread I suppose.
  238. Rear suspension squeaks
  239. after market wheels
  240. Honda CR-V 2005 Internal FAN not working
  241. Wife's 1st Gen CR-V Build, Work in Progress/DD. Omaha NE.
  242. CRV maintenance
  243. Replacing CR-V Courtesy Lights
  244. rt4wd isnt what i expected
  245. 01 CRV temp gauge problems!
  246. New CR-V Owner
  247. 2003 Element Pass Electric Window failure
  248. Blown Ecu/Fi, radio/Backup fuses.
  249. CRV '01 Dash lights/oil pressure problem?
  250. Bonjour... c'est Hervé (crv... french humour... lol...no ? sorry)
