PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24
  1. Timing mark after timing belt change
  2. 1999 CR-V, Key at Bottom of the lake
  3. ac problems
  4. Cruise Control / Brake Pedal Switch
  5. Finally! Rear alignment - Compensator arm/bolt
  6. Comparing coilovers
  7. Weird Transmission/Electrical problems 1st gen CR-V
  8. 07 CRV Engine Shutdown
  9. EGR valve
  10. vacuum pressure
  11. CRV Lift & Tires?
  12. 97-01 CR-V Guys: MT Shifter Question
  13. Honda crv 2.2 diesel acceleration problem
  14. '06 crv a/c failure.....got a few ?'s
  15. 00' CRV A/C mystery problem
  16. No Spark 98 CRV!! Read Please!! Need Help!! :)
  17. help on my 97 crv climate control
  18. ac problem for crv 2008
  19. Rally Armor Mud Flaps! (with pics)
  20. B20z2 air resonance chamber
  21. Future 1st gen CRV purchase need advice
  22. Obd2 - Obd1 conversion questions
  23. Long time no post. cool build thread inside....
  24. 03 CRV LX - Oil leak issue
  25. 2004 crv ecu location?
  26. Signal problem
  27. Accord Motor into Crv?
  28. 99/00 HR-V drinking problem
  29. Front End Noises - First Gen CRV
  30. RD1 MT and A/C
  31. 2006 Element - After charging AC only blows cold intermittently
  32. Engine stuttering.. need help!! see pic
  33. Honda CRV Mk2 Facelift - Lumpy Manual Gear Shift?
  34. 1999 crv motor mount
  35. BWR Lower Control Arm: 1st Gen CR-V
  36. Low RPM cold stall. 07 Element
  37. 2005 Honda CRV
  38. Aftermarket rear lower control arm?!?
  39. Driver Door Issues...Window & Lock... 00 CR-V
  40. 2003 CRV A/C Compressor Seized?
  41. Official: Turbo CRV Thread
  42. Honda 1999 Horn is not loud
  43. Is anyone running longer CV boots?
  44. a/c high pressure on the suction side
  45. engine stall problem
  46. 08 Element Starter fob
  47. fullmark grilles
  48. what donut rims/compact rims would fit inside the hidden trunk of crv gen1
  49. 98 honda cr-v automatic transmission center differential
  50. 2003 CRV blinking D codes
  51. 2001 CR-V p0420 problem
  52. Need help to find part name or number of CR-V
  53. 98 honda crv cv replacement still popping
  54. 2005 CRV cooling fan concern
  55. How to install fog lights 2002 CRV
  56. Searching for parts, suzuka?
  57. Honda CR-V Performance
  58. 2003 crv radio
  59. First Gen CR-V Factory Alloy Rim Color Code?
  60. P1298 Engine Lite Code
  61. 2000 CRV overheating/Radiator and condenser fans not working
  62. Rack and Pinion Boot Service
  63. 2004 Honda Crv PCV?
  64. Accord springs?
  65. Replaced all the exhaust valves now getting DTC P0300, P0302 and P0304
  66. Testing....White rims on Black V
  67. 99-2001 CRV Bulb sizes for LED conversion?
  68. CR-Vicious Headlamp Projector Retrofit
  69. Radio code
  70. Door will nor open
  71. HOnda crv1998
  72. 2011 CRV oil
  73. anyone do led lighting on your cr-v?
  74. water pump on 2005 honda element
  75. Purchasing a 2006+ CRV: how to tell if it's awd or not?
  76. 07 cr-v heater core
  77. 2007crv moonroof
  78. CRV with unusual problem
  79. alignment question (also need rear struts)
  80. D2 RS coilovers for RD1
  81. 2003 k24a1 block, how to remove oil filter boos screw
  82. Cooling fan keeps blowing???
  83. Trying to understand 1st Gen CRV suspension...
  84. My Black 2000 CRV - ZZzzzz...
  85. Aftermarket OEM replacement headlights
  86. Another CRV overheating problem...???
  87. 2005 manual transmission
  88. (Discussion) Is the 1st gen CR-V susceptible to B-series engine theft?
  89. Coolant Leak
  90. 1st Gen CR-V Drivers Side Water Leak
  91. Shaking under Acceleration
  92. 2nd Gen CRV Lowering
  93. 1998 CR-V -Crank, No start Pulling hair out !
  94. 98 Honda has problem on acceleration
  95. Water in oil and coming out exhaust
  96. S2k rims on a CR-V 02
  97. front wheel bearing?
  98. Yonaka Crv Headers - FWD & RTAWD
  99. Error code 505 & 505pd
  100. New DVD Player
  101. Valve adjustment/other maintiance
  102. 98 AWD, Engine Trans Removal
  103. what model/year 1st Gen CRV came with sunroofs
  104. ac compatibility?
  105. help-cd changer
  106. RD1 SiriusXM Antenna Location
  107. tires question
  108. clunking noise coming from the front when starting to move from a complete stop
  109. Cruise Control Problem 2002 CR-V
  110. Slight squeaky noise when turning
  111. Aftermarket Radio Problems
  112. 03 element burning oil
  113. tire and rim question
  114. Oil Leak - maybe crank seal, maybe oil pan? What else?
  115. leaky diff
  116. Torque wrench confusion
  117. CR-V 2001 replacing front brakes and rear brake shoes
  118. 2001 CRV Head Job - to RTV or not to RTV?
  119. Throttle Body?
  120. 235 50 17 offset +60
  121. question about crv suspension
  122. 2002 Honda CRV Front Axel Replacementt
  123. Coilover Fitment
  124. hybrid racing shift cables on 95-01 CRV?
  125. High Mileage '06 Purchase
  126. CRV transmission problems
  127. 1998 CR-vicious frayed throttle cable -where to find?
  128. Bizzare issues after o2 sensor replacement
  129. Won't shift into reverse
  130. Annoying noise
  131. Purchasing used 2nd gen
  132. High compression B20?
  133. Help with 2003 CRV
  134. Any V's with EF rear spoiler fitted on?
  135. Affordable 1st gen CRV coilovers maybe coming soon..
  136. Anybody know what parts I should order for the picture shown?
  137. 1st gen crv rear middle seat belt?
  138. Honda crv 2009 turnlight issues
  139. Rd1 roof rack questions
  140. integra trans in crv???
  141. Yonaka Crv Exhaust PT II
  142. Radio antenna ( hate it )
  143. RSX Cluster Fit Into 03 CRV?
  144. About to check out a 99 CRV EX 5spd, what should I look for?
  145. High idle in 01 mt crv
  146. 2004 crv cruise control problem
  147. little drift in the snow this morning
  148. DC5 ITR Steering wheel
  149. 1st gen cr-v strut spacers
  150. Cold air flow
  151. help 03 honda element fan wont come when idle.
  152. 2003 Element Immobilizer light flashing and wont start
  153. First Gen automatic vs 5 speed
  154. Your favorite Gen 1 body color
  155. CRV 2002 Stalls right after starting
  156. 4wd j swap in crv?
  157. 2005 Honda CRV with Everything!
  158. 2005 CRV has shimmy at 25 to 30 MPH
  159. 2008 CRV Oil concerns?
  160. 06 Honda Element Stuck in Park
  161. Trailer hitch or bolt direct
  162. 1st Gen Honda CRV Engine Bay Noise w/ video
  163. Gts rear window visor?
  164. The Infamous Misfire codes...
  165. 03 CRV * Cooling Fan
  166. Buying 2001 CRV. Need help please!
  167. 17x8.5 Rims on lowered Cr-V
  168. turbo oil return line threw drain plug hole
  169. 98 Auto Trans Issues
  170. Brake Lights do not work but the middle brake light does
  171. 235/70/16 on 1st gen cr-v
  172. 01 CRV radiator leak
  173. Factory optional spoilers for first gen?
  174. New crv owner question...
  175. Yonaka CRV exhaust systems
  176. First gen Aluminum Radiator
  177. reversing map lights
  178. Differance in honda crv motors? please help
  179. 2005 crv rear suspension upgrade
  180. Plasti Dip or Bumper paint for a rear spoiler?
  181. Wasn't Idling this morning
  182. Sapre tire retrofit
  183. Trouble pulling the head off a B20
  184. 01 CR-V towing capacity and hitch?
  185. 98 crv map sensor
  186. 2003 CRV instrument cluster
  187. Upgrade 2nd generation to 3rd?
  188. Stock ride height/EX wheels offroad setup
  189. Inertia Switch on 2001 CR-V
  190. 1998 CRV with VTEC
  191. 2001 cr-v CEL turns on and off no symptoms
  192. wiper arm
  193. 99 CR-V misfire p0304 problem
  194. Power Steering Pressure Hose replacement
  195. Heated mirror retro fit
  196. I have an idea
  197. off topic. Anyone in the Chicago land area?
  198. Manual 1999 Honda CRV
  199. Where to buy GEN 1 roof rails?
  200. Odd CR-V distributor harness switch - Please help
  201. advice on brake fluid test strip
  202. 2006 CRV headlight alarm doesn't work
  203. DJs Build
  204. Leftover SRS problem after taking apart dash, where does it go?
  205. My Taffeta White AWD Autotragic RD1
  206. Cruise Control randomly shut off?
  207. anyone tried jdm p72 a/t ecu?
  208. What did I do wrong?
  209. 1st gen CR-V Trunk height question
  210. 2005 Honda crv rolling back on the incline?
  211. '03 Element has trouble running/starting in rain
  212. airbag
  213. CR-VTEC question for AutoBoxers
  214. RD1 top hat question
  215. 2000 CRV Shift Flare
  216. HELP ME INSTALLING REMOTE STARTER IN MY 2006 Honda Element EX 4WD Manual Transmission
  217. 98 CR-V Auto Transmission Issue
  218. Wheel suggestion for lifted rd1
  219. PRE-WIRED OR NOT
  220. Front Exhaust pipe issues with 99 crv
  221. 2010 crv exl dead battery
  222. Eg ek crossmember in rd1
  223. what to do with my V?
  224. Block Heater Cord Cap?
  225. I turn my key and it take 3-6 seconds for the engine to start
  226. 1st gen jdm front bumper foglights
  227. 1st gen CRV vs 1st gen Forester
  228. rd1 auto Shifter and weird feeling
  229. First Gen Honda Cr-V Suspension Bracing
  230. Starter replace
  231. OEM Spring Rates???
  232. Interior lights
  233. The most stumped I've ever been...please help :/
  234. Half shaft question
  235. Tough little b20 finally died! The build begins...
  236. LED stop lights
  237. 2005 Crv hyflo cat and exhaust
  238. cold engine idle problems
  239. Ignition issue; Ignition fires once then stops firing.
  240. Ignition issue; Ignition fires once then stops firing.
  241. largest size battery in first gen crv
  242. Changed Dizzy now car wont start - Crank No Start - Have Fuel Have Spark
  243. 01 CR-V vibration at 60+mph
  244. First Gen CR-V 4WD Torque Specs
  245. Rear sway bar needed?
  246. Share your Crv opinions/exp, May buy one
  247. Who here has painted their bumpers/side moldings? tips/tricks?
  248. Sputter/hiccup issue on RD1
  249. Higher seat
  250. 1st gen CRV rear seat removal
